Plastic Versus Metal Junction Box - Page 2 - Electrical - Contractor Talk
Old 10-03-2018, 07:13 AM   #21
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 3,006
Re: Plastic Versus Metal Junction Box
Originally Posted by John Valdes View Post
I take a very simple approach to this.
If you are using metal conduit or metal cable, metal boxes are the way to go.
I have seen some plastic boxes with KO's in them, but its far from an everyday item.
Romex/NM/UG - I use plastic.
Since is nm will go plastic or bakelite/equivalent.
artinall is offline
Old 10-03-2018, 11:43 AM   #22
John Valdes's Avatar
Trade: Electrical
Rewards Points: 140
Good. Not saying you cannot use a metal box, but plastic is less money and you will not need a connector.
John Valdes is offline
Old 10-05-2018, 03:14 PM   #23
artinall's Avatar
Originally Posted by 480sparky View Post
You need three things to start a fire.
1. Fuel
2. Oxygen
3. Source of ignition
By agent, I meant fuel. The other two are a given. Oxygen exists in the structural atmosphere and ignition was described as live exposed electric.
In many cases, you may not be able to tell the makeup of certain materials, like aged insulation. Though I have heard "if it has fiber. technically it can burn". So are there "norms" to consider for possible fuel?
artinall is offline
Old 10-05-2018, 04:22 PM   #24
rrk's Avatar
Rewards Points: 390
live exposed electric is not ignition if so every bare conductor would be ablaze, ignition would be when that live conductor gets grounded or shorted to neutral. At that point the circuit breaker should trip.
Even the screws on outlets are exposed.
There are live exposed conductors in your main panel and that is not on fire
rrk is online now
Old 10-05-2018, 05:29 PM   #25
avenge's Avatar
Rewards Points: 276
So who's house is going to burn down yours or your client's?
avenge is online now
Old 10-05-2018, 06:03 PM   #26
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 11,184
"Live exposed electric" is NOT a source of ignition. If it were, every switch and outlet in your house would burst into flame due to the 'live exposed electric' terminals attached to the drives. Your panel would do the same, since the 'live electric terminals' are present.
What IS a source of ignition is an arc caused by the flow of current across a gap.
If there's a highway to hell and only a stairway to heaven, that pretty much tells you what the traffic patterns are expected to be.
480sparky is offline
The Following 2 Users Say Thank You to 480sparky For This Useful Post:
artinall (10-05-2018), rrk (10-05-2018)
Old 10-05-2018, 06:43 PM   #27
artinall's Avatar
Alright, I misspoke...
So what specific type of thing/factor might cause a flow of current across a gap?
artinall is offline
Old 10-05-2018, 06:50 PM   #28
artinall's Avatar
Neither, it was done right. Connections were placed in a sealed box with 3/8 romex connectors and grounded. Wire nuts taped shut. Not a chance of anything happening.
At this point, I'm trying to finish answering this practical question in my mind...
But thanks for your concern.
artinall is offline
Old 10-05-2018, 07:04 PM   #29
480sparky's Avatar
Current has to flow to something that is at a voltage potential different from the voltage present.
Old 10-05-2018, 07:16 PM   #30
artinall's Avatar
You say it has to flow to, but is it caused by the difference in voltage potentials in and of itself? What catalyzes the act of transference?
artinall is offline
Old 10-05-2018, 08:06 PM   #31
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 325
Of course. If there was no difference, no current would flow.
The potential for fire happens when current flows through a resistance. That causes heat. The resistance of a properly wire-nutted connection is negligible, so it would take an enormous amount of current to produce significant heat.
Tinstaafl is online now
Metal patch kits safe over ceiling junction boxes? artinall Drywall 35 08-01-2016 02:54 PM
Metal to Plastic Connections? DemRem Plumbing 14 10-10-2013 08:58 PM
Old Metal Shed Roof Leak Dustincoc Roofing 19 10-08-2013 06:02 PM
sub panel ground bars and grounding metal boxes jkfox624 Electrical 6 04-18-2010 02:01 PM
screws spinning when screwing drywall to metal ceiling furring ajpepe72 Drywall 17 02-09-2010 10:25 PM
