Plastic Versus Metal Junction Box - Electrical - Contractor Talk
Old 09-30-2018, 07:36 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 3,000
Is plastic any safer than metal?
Three wire capped connection in an attic space, if that would matter...
artinall is offline
Old 09-30-2018, 07:48 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 11,184
Re: Plastic Versus Metal Junction Box
Properly installed, it's six of one, half-dozen of the other.
If there's a highway to hell and only a stairway to heaven, that pretty much tells you what the traffic patterns are expected to be.
480sparky is offline
Old 09-30-2018, 07:52 PM   #3
artinall's Avatar
Lets just say a cap drops, live current makes contact with metal. Is this a problem?
artinall is offline
Old 09-30-2018, 08:01 PM   #4
480sparky's Avatar
A properly installed metal box will be grounded.
The Following User Says Thank You to 480sparky For This Useful Post:
hdavis (10-01-2018)
Old 09-30-2018, 08:03 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 303
That's why, being a lazy bum, I prefer plastic. Don't have to ground it. :
Tinstaafl is offline
TheConstruct (09-30-2018)
Old 09-30-2018, 08:10 PM   #6
480sparky's Avatar
Old 09-30-2018, 09:39 PM   #7
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 303
Cute, but that has nothing to do with grounding the box.
Old 09-30-2018, 09:42 PM   #8
Fire up the BBQ
griz's Avatar
Rewards Points: 758
what kind of wire you dealing with?
griz is online now
artinall (10-01-2018)
Old 10-01-2018, 07:40 AM   #9
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 2,412
In Canada they all have grounds, with a bond strip to the device screw:
Inner10 is offline
Old 10-01-2018, 10:37 AM   #10
artinall's Avatar
romax 3 wire. don't have the gauge. assume is shielded.
off-white and more recent yellow. how's that for being green with electric? maybe spoken like more of a painter?
artinall is offline
Old 10-01-2018, 10:38 AM   #11
artinall's Avatar
isn't there another option. not plastic but a fiberglass of sorts? greyish...don't see it any more around here much anymore.
artinall is offline
Old 10-01-2018, 01:57 PM   #12
480sparky's Avatar
Shielded NM?
hdavis (10-01-2018)
Old 10-02-2018, 02:44 AM   #13
artinall's Avatar
So a fiberglass or plastic box would be "safer" in the event live current comes in contact with the inner box? They may melt but not burn?
What about if live current comes in contact with wood studs or fiberglass insulation. Is this a danger?
artinall is offline
Old 10-02-2018, 05:33 AM   #14
rrk's Avatar
Rewards Points: 382
I sincerely hope you are not doing any electrical work yourself
rrk is offline
Old 10-02-2018, 06:55 AM   #15
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 418
Metal boxes for me , the plastic ones are flimsy. I donít like how they move when plugging in a cord. Screws donít feel right when installing fixtures and so on. The old fiberglass type ones break ,when working around them
Idothat is offline
The Following User Says Thank You to Idothat For This Useful Post:
Lettusbee (10-03-2018)
Old 10-02-2018, 09:20 AM   #16
rrk's Avatar
Rewards Points: 382
They were Bakelite I believe, not fiberglass
rrk is offline
artinall (10-02-2018)
Old 10-02-2018, 12:10 PM   #17
John Valdes's Avatar
Trade: Electrical
Rewards Points: 140
I take a very simple approach to this.
If you are using metal conduit or metal cable, metal boxes are the way to go.
I have seen some plastic boxes with KO's in them, but its far from an everyday item.
Romex/NM/UG - I use plastic.
John Valdes is offline
The Following User Says Thank You to John Valdes For This Useful Post:
Old 10-02-2018, 02:24 PM   #18
artinall's Avatar
Was asking about what type of external 'agent' must be present to cause fire, in the event it goes live exposed.
artinall is offline
Old 10-02-2018, 02:57 PM   #19
480sparky's Avatar
You need three things to start a fire.
1. Fuel
2. Oxygen
3. Source of ignition
Old 10-02-2018, 03:58 PM   #20
rrk's Avatar
Rewards Points: 382
I sincerely hope you are not doing any electrical work yourself <img src="http://img.contractortalk.com/smilies/blink.gif" border="0" alt="" title="Blink" class="inlineimg" /> <img src="http://img.contractortalk.com/smilies/blink.gif" border="0" alt="" title="Blink" class="inlineimg" />
Like I said
rrk is offline
Metal patch kits safe over ceiling junction boxes? artinall Drywall 35 08-01-2016 02:54 PM
Metal to Plastic Connections? DemRem Plumbing 14 10-10-2013 08:58 PM
Old Metal Shed Roof Leak Dustincoc Roofing 19 10-08-2013 06:02 PM
sub panel ground bars and grounding metal boxes jkfox624 Electrical 6 04-18-2010 02:01 PM
screws spinning when screwing drywall to metal ceiling furring ajpepe72 Drywall 17 02-09-2010 10:25 PM
