Oven And Cook Top Whips - Electrical - Contractor Talk
Old 12-24-2008, 09:27 PM   #1
Electrician
jrclen's Avatar
Trade: Electrical Contractor
Rewards Points: 250
How do you guys connect the flex whips for cooktops and free standing or built in ovens?
A flush mount box with a 90 degree flex connector in the blank cover? Surface mount box? Box inside the cabinet?
John
jrclen is offline
Old 12-24-2008, 10:19 PM   #2
Speedy Petey's Avatar
Trade: Electrical
Rewards Points: 1,244
Re: Oven And Cook Top Whips
A flush mount box with a 90 degree flex connector in the blank cover? Yes. Not very often though.
Surface mount box? Yes.
Box inside the cabinet? Yes, most often.
Speedy Petey is offline
Old 12-24-2008, 10:24 PM   #3
mdshunk's Avatar
Rewards Points: 2,002
[quote=jrclen;564009]How do you guys connect the flex whips for cooktops and free standing or built in ovens?
A flush mount box with a 90 degree flex connector in the blank cover? Yes, but rarely. Normally when the oven is 23" deep and the cabinet is 24" deep. Surface mount box? About 49% of the time. Box inside the cabinet? The other 49% of the time.
mdshunk is offline
Old 12-25-2008, 01:52 AM   #4
CNC's Avatar
Trade: Electrician
Rewards Points: 152
i use a NM adjustable box during rough in, then to an appropriate sized 4-0 extension ring, and flex into that. but it does depend on install, try to avoid the coverplate method if i an get it in a cab with more space.
CNC is offline
Old 12-25-2008, 10:19 AM   #5
Electrician
jrclen's Avatar
Rewards Points: 250
Thanks guys. Merry Christmas.
John
jrclen is offline
Are you a Jen Air electric range, a GE Double Oven or a Viking Range? Mike Finley Business 8 02-25-2007 08:35 PM
