One Little GFCI - Electrical - Contractor Talk
One Little GFCI
Old 03-21-2015, 04:26 PM   #1
cwatbay's Avatar
Trade: Electrical Contractor
Rewards Points: 2,566
One Little GFCI
Working on a multi-million dollar property, and, I am installing an LED back yard lighting system that lights up the back yard at night. So you have 5 - 50watt LED floods. Anyway, lots of conduit, trenching, back boxes, supports and so forth.
The only circuit I find out there is a 4 x 4 box with non-GFCI outlets in it that has the plug for the pool pump mounted to a retaining wall across the lawn. The yard itself is 100' x 100' with half of it at a fairly steep slope.
So, got everything in, lights, enclosure with timer and override switch, wall penetrations, back boxes, extra boxes and outlets at some of the lights. Not bad, looks good, and, it's going to light up the back yard like Yankee Stadium.
During the installation, everything was fine (3+ days to install), periodically checked power, tested light, so forth. Final test, no power. Go back to the original box, no power. What??
Check the breaker, it's on. I mention this to the owner and he says that sometimes when the power goes out in back, he has to press this button on an outlet. I ask which one. It's in the kitchen next to the disposal switch. I open it up.
So, the whole back yard, sprinkler system, pool pump, lighting and outlets are run off the back of a 15amp GFCI in the kitchen, which is also used for the toaster and coffee maker. WTF !!!
To check, I hit the reset, and, yes, everything comes on. I take the wiring off the breaker and just have the GFCI wired in parallel with the circuit (which BTW is labelled Kitchen Outlets).
Ok, test everything again. No power...I am using the MF word a lot now, in reference to whoever wired this in the first place...the developers electrician. So now I trace everything to another GFCI on the outside of the house, on the other side of the wall from the kitchen. So, they wired the GFCI in the kitchen to the GFCI on the outside of the house in the back yard. So now I wire this GFCI in parallel with the circuit and move the timer for the pond pump out to the pond area and plug it into one of my new outlets.
Now everything works. But the guy really needs at least two dedicated circuits for the backyard.
cwatbay is offline
Old 03-21-2015, 04:44 PM   #2
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Re: One Little GFCI
How ever did that pass inspection ?. But who the f&%k doe's that kind of c%ap.
Its a shame some times a home owner thru no fault of their own gets f&^ked.
sunkist is online now
Old 03-21-2015, 04:52 PM   #3
cwatbay's Avatar
Re: One Little GFCI
Oh, you want an inspection.......... Excuse me !!!!!!
What likely happened was the landscaper found the GFCI on the outside of the house, and, figured that's where the power is. So he digs up the backyard, and runs conduit: puts in a BBQ (with power), Pond and waterfall (with power), puts in 3 locations on the retaining wall with non-GFCI outlet (cus the feeder is a GFCI.....this happens a lot in tract home construction especially in the garage), Sprinkler system (with power), outdoor lighting throughout (with power).
No inspections.
cwatbay is offline
Old 03-21-2015, 04:55 PM   #4
GettingBy's Avatar
Rewards Points: 6,486
Re: One Little GFCI
One GFCI was downstream of the other?
GettingBy is offline
Old 03-21-2015, 04:59 PM   #5
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Re: One Little GFCI
Stuff like this ceased to surprise me many years ago.
Inner10 is offline
Speedy Petey (03-26-2015)
Old 03-21-2015, 05:05 PM   #6
cwatbay's Avatar
Re: One Little GFCI
Yes
cwatbay is offline
Old 03-21-2015, 05:08 PM   #7
cwatbay's Avatar
Re: One Little GFCI
Don't do that much resi. Seen the same thing in upscale housing garages. 4 to 5 reg receptacles wired to one GFCI. Then the HO wonders why suddenly, none of the outlets work.
Not surprised, just pissed that they did it this way.
cwatbay is offline
Old 03-21-2015, 05:09 PM   #8
Inner10's Avatar
Re: One Little GFCI
At least you can make some money off it.
Inner10 is offline
Old 03-21-2015, 05:15 PM   #9
GettingBy's Avatar
Re: One Little GFCI
Yes
You'd think the more sensitive one would always trip first but that may not happen.
As long as GFCIs cost more than receptacles, yes.
Our kitchen is now wired that way, and finding out which box was upstream of the others was a bit tricky. You need a DVM and a 10A load.
Our screened porch was wired incorrectly by a sparky but the GFCI test button worked.
A 7-1/2w bulb from hot to ground found the mistake. The GFCI stayed latched despite this ground fault.
Old 03-21-2015, 05:15 PM   #10
cwatbay's Avatar
Re: One Little GFCI
True. Did make money off the $12k camera system (Mobotix) that I put in (didn't design it....but had to figure out location, power, trenching, conduit ,wiring and so forth....sister company did the selection of cams and views)
And, I will make money off the LED lighting system for this guy's backyard basketball court.
And, with my suggestions, make money off the additional circuits for the backyard. Lots of trenching and conduit for that. Probably a sub-panel for the back yard.
cwatbay is offline
Old 03-21-2015, 05:17 PM   #11
hdavis's Avatar
Rewards Points: 1,262
Re: One Little GFCI
I anticipate problems, but they still surprise me. Slogging through them is still not fun.
Pool really should have it's own circuit, IMO. At least it isn't being run off a toaster circuit any more.
hdavis is online now
Old 03-21-2015, 05:21 PM   #12
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 992
Re: One Little GFCI
That's more common than one would think. Usually a result of multiple jobs pretty much the way you described it.
I'd say my personal ratio of "no power" troubleshooting runs about 100:1 GFCI vs any actual connection issues.
Tinstaafl is offline
Old 03-21-2015, 05:22 PM   #13
Inner10's Avatar
Re: One Little GFCI
I haven't touched a mobotix camera in years, they were a nice product to work with.
Inner10 is offline
Old 03-21-2015, 05:27 PM   #14
cwatbay's Avatar
Re: One Little GFCI
My sister firm ( I own 20% and I license them ) loves the Mobotix cams for residential. They love the door bell cams - none of which have worked right yet.
I have gone through Mobotix training and have put them in. To me though, they are like a $1000 solution to a $100 problem.
I still prefer Arecont, Axis, Sony, DRS, and, a few low end cams like: Digital Watchdog, Hikvision, and LTS.
cwatbay is offline
Old 03-21-2015, 05:30 PM   #15
Inner10's Avatar
Re: One Little GFCI
I gotta say, the residential front door camera intercom solution is the one damn product I hate from all manufacturers. No one offers a panacea.
I'm all Axis and Hik unless the products are speced out for me.
Inner10 is offline
Old 03-22-2015, 10:26 AM   #16
cwatbay's Avatar
Re: One Little GFCI
Here is a pic from the client
cwatbay is offline
The Following User Says Thank You to cwatbay For This Useful Post:
hdavis (03-22-2015)
Old 03-22-2015, 02:49 PM   #17
rrk's Avatar
Rewards Points: 4,922
Re: One Little GFCI
There are many houses that I work in which were built in the 80's that have outside GFCI's wired to the 2nd fl bathroom. Over the years home inspectors noted no outside GFCI present, h/o installs them. And the head scratching begins for the next h/o.
rrk is offline
hdavis (03-22-2015)
Old 03-22-2015, 04:42 PM   #18
GettingBy's Avatar
Re: One Little GFCI
Just mapping out the breakers and their outlets is a tedious job. I have designations like Upper NE room, 2nd outlet, etc. and then you've got the overhead light fixtures and switch controlled outlets.
You can find out if there is a GFCI on a breaker by looking for a few mA being drawn on that line by the internals of the GFCI but you first have to unplug all appliances from that line that are never totally 'off'; TVs, VCRs, copy machines, printers, etc..
Also, with a GFCI, both the hot and the neutral no longer have continuity back to the panel, unlike with most SPST switches.
Old 03-22-2015, 07:53 PM   #19
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
Re: One Little GFCI
No better time then now to upsell two new circuits since the problem has been found. Leave it until later and they will forget there was a problem or you will be getting called back when GFCI's are getting tripped.
woodchuck2 is offline
Old 03-23-2015, 08:49 AM   #20
cwatbay's Avatar
Re: One Little GFCI
That is true. Although I think the lighting for the basketball court is next. These million dollar two story homes were all built on slabs. The service is in the garage on the house to garage wall. There would be a lot of work with opening up the wall to run conduit to the side of the garage, then trenching to the back yard...and under walkways. I think that if we put a sub-panel out in the backyard, this will solve a lot of current and future issues.
Apparently the house was built. Then the developer offered a lot of additions to the back yard: pool, ponds, lighting, sprinklers, etc. I was told there was a big push to sell these places and get the backyards finished ASAP. Which kind of explains why there are no breakers or circuits dedicated to the back yard. All the circuits going back to the yard end at the kitchen.
cwatbay is offline
hdavis (03-23-2015)
GFCI receptacle yonexwood Electrical 6 06-11-2013 06:57 PM
GFCI trips only on one location MinConst Electrical 2 07-14-2012 09:39 PM
GFCI breaker - that sensitive? geospec Electrical 14 07-24-2010 10:05 AM
weird gfci issue. im a noob! mechanix Electrical 24 08-04-2009 09:42 PM
Kitchen - use 20A GFCI at start w/ 15A outlets??? tmdelisle Electrical 25 07-28-2009 12:38 AM
