Need Help With Saw Switch - Electrical - Contractor Talk
Old 04-01-2013, 11:10 PM   #1
back doors to hell put in
Irishslave's Avatar
Rewards Points: 26
so replacement switch arrives from e replacement parts. 4 terminals, 2 for line 2 for load I hook it up same way as old switch...line in the top load out the bottom, plug it in hit switch. i hear dreaded surge and lights go dim, so I reverse line in bottom load out the top same thing. I am obviously sending current back to the recepticle when I close the switch. Right? should I try line in the side and load out the other side? I don't want to damage anything
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site.
Irishslave is offline
Old 04-01-2013, 11:27 PM   #2
Dirtywhiteboy's Avatar
Rewards Points: 11,720
Re: Need Help With Saw Switch
I don't know whats going on, maybe dig around on the E-Replacements site. Sometimes you can find a video of how to do things or they have a ask how forum if you sing up. I've asked things there and nobody seems to respond
Dirtywhiteboy is offline
Old 04-02-2013, 06:39 AM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,677
You need to stop guessing and ring out the switch contacts with a continuity tester. Assuming there's nothing wrong with the saw itself, it sounds like you were laying a dead short across the line.
Tinstaafl is online now
Old 04-02-2013, 08:56 AM   #4
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 834
Which saw? Last year I replaced the switch in my wormdrive, and found out that the terminals were not in the same position between the old and new switch. Seems like they were spun 90 degrees??? don't remember exactly but, they weren't in the same position.
dsconstructs is offline
Old 04-02-2013, 10:00 AM   #5
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
X2, new switch may show line on top and load on bottom but if you check the old switch it may be line on one side and load on the other side. Testing will verify which wires are for what field.
woodchuck2 is offline
Old 04-02-2013, 11:47 AM   #6
iggy's Avatar
Trade: electric
Rewards Points: 150
Why are you replacing the switch? Did it just stop working? Sounds like you may have a motor issue if you shorted the switch you should have tripped the breaker if the breaker did not trip you have another issue.
iggy is offline
The Following User Says Thank You to iggy For This Useful Post:
MTN REMODEL LLC (04-02-2013)
Old 04-02-2013, 03:57 PM   #7
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
I'm a little confused.... what kind of saw.... is this just a "contact" switch or does it incorporate a relay and a magnetic shut-off.....
If it is a just a contact switch, it must be a DPST (double pole single throw) for a 240 setup so you can break both hots. If you're not running a 240, you just need one of the poles for your hot leg. Are you running 240 or 120. Do you know or is your motor hooked up incorrectly for feed. But if it is this type switch, line/load direction is not the important issue, it is the poles (pole1 pole2) that is important. If those are crossed, you'll have a 240 volt short inside your switch and you would sure as hell know that.
IF it is labelled line and load, it may be a magnetic switch that operates so that if power is interupted (like becomes unplugged or a breaker trips and you haven't shut off the switch) the saw will not start when you replug it back in ... done as a safety measure. I am not sure exactly as to that electrical scheme, but line/load sides may be significant.
Why were you reeplacing the switch... why'd you think the old one was bad... are you sure it's not the motor... try wiring straight thru/around the switch and see if the saw strats/runs ok.
Good luck
PS: with 4 terminals (2 poles) this must be a table saw, or so I assumed. I would assume the switch you ordered had an amp rating, what was it's rating verse your motor... both items should have it stamped on them somewhere.
MTN REMODEL LLC is offline
Old 04-02-2013, 07:51 PM   #8
It's a Porter Cable 6" Saw Boss
All the switches I replace have 4 poles on them although I only use 2 of them
Irishslave (04-02-2013)
Old 04-02-2013, 08:56 PM   #9
Interesting.... what do ya think the other two terminals are for?????
I've never seen a DPST on a hand tool... or ... one/two terminals were not switched and just a connector for the neutral that appeared to be part of the switch assembly.
Peter
Just realized you said you only used two of them... so I guess that the terminals you are refering to could not be just a neutral bar.
So what are the 4 terminals?????
Peter
Last edited by MTN REMODEL LLC; 04-02-2013 at 09:00 PM. Reason: didn't read correctly
Old 04-02-2013, 08:59 PM   #10
My guess is so the switch can be used for more than one tool or in more than one country
Old 04-02-2013, 09:07 PM   #11
Ah Ha...Maybe... probably... I have no idea... but sorta interesting to know if anybody knows.
Peter
Old 04-02-2013, 09:09 PM   #12
Irishslave's Avatar
Rewards Points: 26
Thanks, that's exactly what it was. Up and runnin
The Following User Says Thank You to Irishslave For This Useful Post:
Dirtywhiteboy (04-02-2013)
Old 04-02-2013, 09:13 PM   #13
Any body understand why?
Old 04-02-2013, 09:45 PM   #14
Irishslave's Avatar
Rewards Points: 26
Thanks everyone nice to know I can come here for some help and suggestions when I need it. Line came in one side Load went out the other, not top and botttom this made logical sense because when closing the switch I was feeding power back to the recepticle
Old 04-02-2013, 10:02 PM   #15
Old 04-02-2013, 11:02 PM   #16
Irishslave's Avatar
Rewards Points: 26
Originally Posted by MTN REMODEL LLC View Post
Simple imagine this A B
-------------------C D
Instead of line wires (black and white) connected to A and B and load wires connected to C and D......which is what you would think with switch in it's operating position the line wires actually get connected to B and D and the load wires get connected to A and C. Best explanation I can give
I need to add a ceiling light to a switch that activates an outlet supafly917 Electrical 23 12-10-2012 05:03 PM
High limit switch JCValois HVAC 2 10-20-2012 10:30 AM
Multiple fixtures on switch loop KenHaynes Electrical 2 12-05-2007 03:15 PM
smart light switch circuit toastermaker Electrical 7 12-07-2005 11:45 PM
