Need Help To Re-connect Bathroom Fan/light Box - Electrical - Contractor Talk
Old 05-26-2012, 01:14 PM   #1
otch's Avatar
Trade: carpentry
Hi everybody,
I'm doing a bathroom reno. And need to replace existing ceiling light box with a new fan/light unit.
When I opened up ceiling there were three wires connected to the light box. Two hot wires and one from the switch.
I have no idea where come these two hot wires.
When I connected all three to the fan/light box, the fan/light is on constantly. No reaction to the switch.
How should I re-connect the wiring, so that the box works from the switch.
I would greatly appreciate any help.
Thank you.
otch is offline
Old 05-26-2012, 01:20 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,348
Re: Need Help To Re-connect Bathroom Fan/light Box
Time to call an electrician.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
Old 05-26-2012, 03:28 PM   #3
SemiRetiredEL's Avatar
Trade: Electrial Contractor (master)
Rewards Points: 75
Originally Posted by otch View Post
Hi everybody,
Thank you.
Be sure to turn off the breaker when handling wires!
You must have power (hot & neutral) available at the ceiling box because the light worked OK before. Separated all 3 wires and using an ordinary incandescent lamp with insulated alligator leads connected, determine if the light will work at the ceiling box.
If so one of these leads (usually white) is the neutral. Later, connect it to the white on the fan/light.
Now, leave the test lead connected to the neutral and test the leads coming from the switch. One of them should light up your test lamp depending on the switch position. This is called a switched lead.
I suspect you only have one switch so both the exhaust fan and the light will have to be connected to the switched lead and come on together.
If you still have an extra wire in the ceiling after everything is working, check to see if other lights or receptacles are working.
If power is fed to the ceiling first, only two wires to the switch are needed to make the light work.
Report back what you see maybe we can do even better on this project.
SemiRetiredEL is offline
Old 05-30-2012, 06:09 AM   #4
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Rewards Points: 1,244
Best to leave this to an electrician.
There is NO reason that you need to be messing with this stuff.
Speedy Petey is offline
Old 05-30-2012, 06:13 PM   #5
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 550
Semi, you may want to watch giving advice to someone without knowing anything about their abilities. The OP stated he has" no idea where come these hot wires". If he is not able to even find that out I think 480 offered the best advice.
I'm all for helping someone if they have proven themselves capable, but not with a one time poster.
TxElectrician is offline
Old 05-30-2012, 06:23 PM   #6
Fentoozler
Celtic's Avatar
Rewards Points: 2,000
Call an electrician before you set something on fire....could be the house....could be yourself....etc.
Celtic is offline
Old 05-30-2012, 06:55 PM   #7
480sparky's Avatar
Old 05-30-2012, 07:08 PM   #8
rselectric1's Avatar
Rewards Points: 874
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed. ____________
rselectric1 is online now
Bathroom Walls weeping... HELP hbl164 Painting & Finish Work 19 09-08-2016 11:40 AM
Connect sewer drain to house cincyoh Plumbing 1 03-18-2012 07:32 AM
dripping bathroom fan.... ApgarNJ General Discussion 37 12-10-2011 11:45 AM
Bathroom Odor? ChicagoBaths Remodeling 20 01-02-2010 05:50 AM
