Need Advice Quick Thanks - Page 2 - Electrical - Contractor Talk
Old 04-16-2012, 10:41 PM   #21
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
Re: Need Advice Quick Thanks
Originally Posted by 480sparky View Post
Since when is egress requirements tied to smoke detector requirements?
They're not, I was just concerned for the kids safety.
Actually, if the smoke detector goes off and there is a fire, the bsmt. window may be the only way out.
katoman is offline
Old 04-17-2012, 07:51 AM   #22
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,864
I understand that. I was just wondering how egress & operating windows & firefighters with gear got involved from smoke detectors and AFCIs.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
Old 04-17-2012, 08:02 AM   #23
Shonda Meitler
WorldPest's Avatar
Trade: Pest Management Professional
You should also practice a fire drill at your home. I know they are only 1 & 2, but this way they may not be as afraid if something does happen. It's always better to be safe than sorry.
WorldPest is offline
Old 04-17-2012, 08:07 AM   #24
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,024
Wait till we bring in the lions and tigers and bears.
Tinstaafl is offline
Old 04-17-2012, 08:25 AM   #25
480sparky's Avatar
Oh my!
Old 04-17-2012, 08:47 AM   #26
Clark Bilston's Avatar
Trade: Renovations
Rewards Points: 150
Clark Bilston is offline
Old 04-17-2012, 09:58 AM   #27
cwatbay's Avatar
Trade: Electrical Contractor
Rewards Points: 2,566
Just did wiring in a house here Calif. Depends on the local building/permit dept. We had to put in new breakers, either Arc-Fault - AFCI for everything (including lights) except Baths, kitchen and Garage. In the baths, kitchen and garage, we put in GFCI's as per code.
Also, had to make sure the house has hard wired Smokes and CO's (which were combination Smoke/CO). Luckly these were installed by the last electrician.
That's the way it is. Some jurisdictions want everything up to current code regardless of what kind of work you are doing (ie: replacing a few circuits, remodel, additions, whatever), while some others only want to see new breakers on only what you are replacing.
cwatbay is offline
Old 04-17-2012, 09:44 PM   #28
SemiRetiredEL's Avatar
Trade: Electrial Contractor (master)
Rewards Points: 75
True, the smoke/CO/heat detector requiremets won't be found in the NEC, but around here they're inspected by the electrical AHJ.
The exact requirements can be found in the IRC Codebook, around here, but varies jurisdiction to jurisdiction, depending on what code they adopt.
The combo units are required in the area outside of every bedroom.
Smoke & heat detectors are required in attached garages. The list is extensive.
Good Luck from Columbiana, Alabama
Maurice Turgeon,http://thesemi-retiredelectrician.com
SemiRetiredEL is offline
Old 04-17-2012, 10:08 PM   #29
canadianwhite's Avatar
Trade: drywall/plastering
Rewards Points: 25
i find there are some rude people in b.c since iv lived here. just coz i cant spell you post on here. very sad. another b.c person with nothing better to do. then stick there nose in. have a good day
canadianwhite is offline
Old 04-17-2012, 10:14 PM   #30
Fire up the BBQ
griz's Avatar
Rewards Points: 2,450
It would be helpful if you did use the Caps key.
One's written word is very important how it is perceived.
I can't instantly reproduce what you said...
but I can sure as he!! copy & paste what you wrote...
It is a pet peeve of mine...
griz is online now
Old 04-17-2012, 10:29 PM   #31
480sparky's Avatar
Actually, it's called the Shift Key.
The Following User Says Thank You to 480sparky For This Useful Post:
griz (04-17-2012)
Old 04-17-2012, 10:33 PM   #32
Capra aegagrus
Tinstaafl's Avatar
While the post that prompted that remark may have been a bit gratuitous, you are also guilty of rudeness by not taking the time and effort to type clearly readable messages. Surely you know the basic rules of capitalization, and spell checking is easily done with the very software you are using to place posts here.
You will most certainly fare better at obtaining free advice if you make it easy for others to understand what you're asking.
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
canadianwhite (04-17-2012), griz (04-17-2012)
Old 04-17-2012, 11:03 PM   #33
Rewards Points: 25
i will spell check all my new posts
The Following User Says Thank You to canadianwhite For This Useful Post:
Tinstaafl (04-18-2012)
Old 04-17-2012, 11:05 PM   #34
Fire up the BBQ
griz's Avatar
AND USE THE DAM SHIFT KEY & APPROPRIATE PUNCTUATION...
griz is online now
Old 04-17-2012, 11:46 PM   #35
Trade: Renovations
Rewards Points: 150
Regrettably I honestly had zero intention of being rude. In retrospect, it was a crass comment. I meant no offence, just saying what was on my mind. Sorry guys.
The Following 2 Users Say Thank You to Clark Bilston For This Useful Post:
griz (04-17-2012), Tinstaafl (04-18-2012)
Professional Salesmen I need your advice. Grumpy Marketing & Sales 46 01-08-2011 09:10 AM
Looking for Advice on Roof Cleaning - Products & Procedures cosmoto Pressure Washing 4 07-01-2010 02:57 PM
Need advice on roof cleaning business cosmoto Roofing 5 02-18-2010 08:00 PM
Advice on a New Hire CookeCarpentry Business 69 08-03-2009 10:06 PM
New to US need some advice. BCConstruction Construction 62 07-27-2009 02:23 PM
