Need Advice On How To Wire A Dishwasher - Page 2 - Electrical - Contractor Talk
Old 08-26-2018, 08:34 PM   #21
avenge's Avatar
Rewards Points: 614
Re: Need Advice On How To Wire A Dishwasher
Originally Posted by 480sparky View Post
That's assuming you took it apart in the first place. Sometimes, it's that way when you first arrive.
If I'm replacing something as the OP stated that means I'm removing the existing one. And since he had to refer to wiring directions I'm assuming he's never done this before, disconnected the wiring not realizing there's an extra wire and now doesn't know where it goes.
Regardless of my assumptions he now has to figure it out.
avenge is online now
Old 09-03-2018, 11:54 AM   #22
John Valdes's Avatar
Trade: Electrical
Rewards Points: 146
My thoughts are it is or was a MWBC, for dishwasher and disposal.
Find the breaker that turns off the black wire you said was hot. Is it a two pole breaker or a single pole breaker.
See if that black wire is in a cable with the red, white a bare ground.
If the red and black are in the same cable, this is a multiwire branch circuit and was most likely designed to power the washer and the disposal.
They should both land on a double pole breaker. Red and Black.
If this was my house I would fix it in the panel if its not done properly now and cap the red wire in the j-box under the counter.
Mark the red as disposal or hot, cap it off and leave it in the box.
If you dishwasher stops working, you will know where the red goes.
The white serves both appliances as does the ground.
John Valdes is offline
Old 09-04-2018, 12:55 PM   #23
Trade: Electrical
Rewards Points: 146
Originally Posted by John Valdes View Post
If your disposal stops working, you will know where the red goes.
Sorry guys I meant disposal.
Im bidding for a commercial painting job. any advice? BaranG Painting & Finish Work 13 02-25-2014 01:54 AM
Sealer removal advice over exposed aggregate and stamped? oktex56 Concrete & Paving 10 01-14-2013 03:57 PM
Need some advice on dealing with a possible client MP CONST Business 11 07-19-2012 12:16 AM
Best paint / advice for aluminum siding? Jdub2083 Painting & Finish Work 15 07-12-2012 01:15 AM
Looking for advice on beams/joists for unique roof... vella Carpentry 9 04-10-2012 11:37 PM
