NEC And Splicing Wiring - Electrical - Contractor Talk
Old 07-21-2006, 05:30 AM   #1
mtplus's Avatar
Trade: remodeler
Rewards Points: 25
Question
Is there any scenario allow under the NEC where one could splice wiring (220) and not have a junction box which is exposed? In other words, I do not wish to have a blank wall plate. Is there any type of splicing kit which can be put in a junction box and buried behind the drywall?
mtplus is offline
The Following User Says Thank You to mtplus For This Useful Post:
Mike Cherr (01-22-2009)
Old 07-21-2006, 06:19 AM   #2
CE1's Avatar
Trade: Electrical
Re: NEC And Splicing Wiring
Nope.
Are you still havin problems with the Radiant Heat in Ceiling wiring? Try being creative about the ceiling j box. How about installing a light fixture, smoke dector, CO2 dector, in the spot where you need to splice the heating cable. Just make sure that the j box is big enough to handle all the wires per NEC 314.16.
Carry On!
CE1 is offline
Old 07-21-2006, 09:52 AM   #3
mtplus's Avatar
Trade: remodeler
Rewards Points: 25
CE1,
Yep, still trying to figure it out. That is a good suggestion. Is there a copy of the NEC on-line somewhere. I had no luck finding one.
mtplus is offline
Old 07-21-2006, 10:20 AM   #4
cptkinguru's Avatar
I usually do as CE1 has suggested and add a smoke detector to the room. Most places I work on don't have smokes and it doesn't have near the "afterthought look" so it's a win-win for the homeowner.
cptkinguru is offline
Old 07-21-2006, 12:23 PM   #5
CE1's Avatar
Trade: Electrical
Originally Posted by mtplus
CE1,
No there is not. I do not have the software version but there will be somebody arriving shortly that will. Hang in there.
CE1 is offline
Old 07-21-2006, 03:33 PM   #6
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Rewards Points: 1,244
Yes there is.
Go to:
http://www.nfpa.org/freecodes/free_a...ookie%5Ftest=1
..click on: "I agree", then on the next page click on: "Open National Electric Code Softbound...."
Speedy Petey is offline
Old 03-07-2019, 03:29 PM   #7
ds1282's Avatar
Trade: Electrician
Rewards Points: 2
You are permitted to use a listed NM connector such as the one at Menards.com
https://www.menards.com/main/electri...4445332929.htm
They are UL Listed for splicing romex, without a box, either exposed or concealed, and permitted by the National Electrical Code 334.40(B).
ds1282 is offline
Old 03-07-2019, 03:35 PM   #8
I own stock in FotoMat!
480sparky's Avatar
Everything I've read tells me it's legal. I know a lot of double-wide mobile homes use them to span circuits from one half to the other.
Would I use one? Only if that's the last option available. I wound never routinely install them. Exception to that would be for wiring installed in sacrificial walls installed in a flood plain.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
Old 03-08-2019, 07:07 AM   #9
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
BTW, this thread is 13 years old
C'est Moi is offline
Old 03-08-2019, 07:51 AM   #10
hdavis's Avatar
Rewards Points: 22
And apparently still legal even with code revisions...
hdavis is offline
Old 03-08-2019, 01:35 PM   #11
480sparky's Avatar
So..... how old does a thread have to be before we're not allowed to answer questions in it?
Old 03-08-2019, 02:20 PM   #12
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
I only mentioned it because the op has his answer. I could care less if you want to respond to an old thread. Just thought you might want to know... Oh, Ken --- LOL
Old 03-08-2019, 02:25 PM   #13
480sparky's Avatar
The question I answered is only a day old....
Old 03-08-2019, 02:38 PM   #14
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
yup. Somebody had to dig for this one.
SmallTownGuy is offline
Old 03-08-2019, 08:17 PM   #15
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,840
I decided to join this site because time and time again when I googled something, this site had the answer. When I saw this thread today I knew that the next time I was at Menard's I would be buying a couple of splice kits so the next time I sawzall through a wire I can repair it easily.
Thank goodness for the 13 year old threads!
Home Designer Series Software
B.Johnson is offline
The Following 3 Users Say Thank You to B.Johnson For This Useful Post:
hdavis (03-09-2019), Idothat (03-08-2019), Philament (03-09-2019)
