Motor Start Problem - Electrical - Contractor Talk
Motor Start Problem
Old 11-26-2018, 01:28 PM   #1
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,588
Motor Start Problem
Motor is 1/2 HP, 120V.
There is a start capacitor, rated at 145-175 mF.
The capacitor failed, so I replaced it. Exact same specs. Now, the motor starts as it should, except, that if there is even the smallest amount of product is the machine, the motor won't start.
It used to start fine, no matter how much load was on it.
The manufacturer said that he has started putting a different motor into these machines, "due to problems with the motor".
Could this be a separate problem, or still a capacitor problem?
Old 11-26-2018, 04:36 PM   #2
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,763
Re: Motor Start Problem
Belt/chain too tight? Bad bearing on armature?
Bad centripetal?(closed at stop, opens @ % of top RPMs) starter switch bad? If its a little dirt/spider, a gentle tapping might fix it near the switch...
Usually the starter switch will make a very audible 'Click'.
remove capacitor from wiring, Ohm out the starter wire, unplugging the motor first of course. It is possible the starter winding has failed open....
Over greasing or water exposure ruins most Starter switches....
Have the "new" cap tested... Some come bad like light bulbs... Test the next one at the store....
More hours run on invertor power supplies = more likely to have winding shorted by dirty sine waves...
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
Seven-Delta-FortyOne (11-26-2018)
Old 11-26-2018, 04:39 PM   #3
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Duraspin deck screw problem HandyHails Decks & Fencing 9 06-04-2012 05:33 PM
Floor joist squeak problem MuttMutt Flooring 9 05-12-2012 01:17 PM
Major problem spraying "SW All Surface Enamel" in Black. GHPJerry Painting & Finish Work 19 08-01-2011 09:15 PM
Existing addition on slab drainage problem dberkey1 Construction 4 08-21-2009 05:41 AM
