Measuring Amps On 220v Generator Feed - Electrical - Contractor Talk
Old 03-23-2019, 12:31 PM   #1
King of Caulk
asbestos's Avatar
Trade: Rot warrior
Rewards Points: 170
I searched through old posts and got some good information. But it brought up some questions I have a good quality generator for the house (gillette 10/13 kw) I wanted to get a pair of meters to measure the amps on each leg to make sure we're not overloading it. My question revolved around how to arrive at the total draw. Seeing as this is dependent on the types of loads, and they will be mixed (fridge, water heater, range etc) I am unsure of how to measure the load (both legs added, highest leg) not concerned about getting highly accurate readings Just a reasonable picture of how close we are to the capacity of the generator.
This also made me wonder if I should be concerned about balancing the load. on each leg. I was not because the big items are all 220.
I am the Sultan, The Sultan of sealants
asbestos is offline
Old 03-23-2019, 02:27 PM   #2
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,578
Re: Measuring Amps On 220v Generator Feed
There are plenty of Ammeters / Voltmeters for generators on Amazon, Ebay start at $10. Just an induction coil wired to a read out.
Steve
We Fix Houses is online now
Old 03-23-2019, 04:33 PM   #3
King of Caulk
asbestos's Avatar
Trade: Rot warrior
Rewards Points: 170
Yup I am getting a pair of those, one for each leg
asbestos is offline
Old 03-26-2019, 03:52 PM   #4
Electrical Contractor
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
I assume you are using a manual transfer switch. One way to be certain is to make sure your overcurrent protective device is not larger than what the generator can handle. If you overload it the load will trip the breaker. The other way is to just use an standard amp meter and test each leg. You could do a calculation but you would have to itemize all loads to phases A and B (yes I know that they are not truly different phases) but that is not feasible as the loads are not all on at the same time. Normally one would do a calculation.
The biggest problem you may have is with a/c or electric heat... a/c units bog down a genset a lot so depending on the size it could be an issue. 10 kw is a fairly generous size genny except in all electric houses.
C'est Moi is offline
The Following User Says Thank You to C'est Moi For This Useful Post:
asbestos (04-01-2019)
Old 07-15-2019, 04:07 AM   #5
theotherone's Avatar
Trade: Plumbing
Rewards Points: 200
Straightforward. Go with this
theotherone is offline
Measuring DC 'barrel' connectors 480sparky Off Topic (Non Trade) 11 04-06-2017 10:25 AM
Measuring a house job dui_man Flooring 11 09-03-2016 06:54 PM
Distance Measuring Device bower4311 Tools & Equipment 5 05-30-2014 10:54 AM
220v well pump philner Electrical 4 04-14-2014 07:36 PM
100 amps or 200 amps ? Miss Sunshine Electrical 21 09-10-2008 10:09 PM
