Location Of Disconnect? - Electrical - Contractor Talk
Old 09-18-2008, 03:59 PM   #1
jimb317's Avatar
Trade: electrician
Rewards Points: 25
I am mounting two transformers up on the wall aprox 16 feet. Do I need disconnects for the line side of the transformers? The panel feeding the transformers is NOT in site. Can the disconnects be mounted up next to the tranformers? I will mount them 6 foot to the top, but this is a question that came up today.
jimb317 is offline
Old 09-18-2008, 05:00 PM   #2
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Rewards Points: 2,002
Re: Location Of Disconnect?
Of course you need overcurrent protection on your line side. I'm not sure of the article but I suspect that it would dangerous be to have the only disconnect for the transformer 16' up in the air. I believe it would need to be not accessible, but readily accessible.
Magnettica is offline
Old 09-18-2008, 05:14 PM   #3
pat c's Avatar
Trade: ELECTRICAL
Rewards Points: 75
u have to put it, if ur line is protected put a disconect NF.
pat c is offline
Old 09-18-2008, 05:20 PM   #4
mdshunk's Avatar
Just put a lockoff device on the breaker that feeds that transformer, where ever that might be. Problem solved.
mdshunk is offline
Old 09-18-2008, 06:00 PM   #5
jimb317's Avatar
Trade: electrician
Rewards Points: 25
as far as overcurrent protection. The transformers are being fed from individual breakers to each transformer, the breakers are about 60' from location but around a corner.
jimb317 is offline
Old 09-18-2008, 06:38 PM   #6
pat c's Avatar
Trade: ELECTRICAL
Rewards Points: 75
i always put a disconect
pat c is offline
Old 09-18-2008, 06:52 PM   #7
listen twice talk once!
Bkessler's Avatar
Trade: electrician
Who's money are you spending?
Bkessler is offline
Old 09-18-2008, 07:09 PM   #8
pat c's Avatar
Trade: ELECTRICAL
Rewards Points: 75
lolll maybe thats why hes asking , always calculate it in ur price, then its up to u
pat c is offline
Old 09-18-2008, 07:12 PM   #9
pat c's Avatar
Trade: ELECTRICAL
Rewards Points: 75
how do i put an avatar ?
pat c is offline
Old 09-18-2008, 07:38 PM   #10
Licensed Electrician
knothole's Avatar
Trade: Licensed Electrictian
Rewards Points: 150
Click on user CP (upper left in blue line) then click on edit avitar and follow directions.........
Follower of Jesus Christ
knothole is offline
Old 09-18-2008, 08:03 PM   #11
pat c's Avatar
Trade: ELECTRICAL
Rewards Points: 75
thanks
pat c is offline
Old 09-18-2008, 08:09 PM   #12
mdshunk's Avatar
It would be great if you could type out actual sentences, and not these silly IM abbreviations my teenagers use.
mdshunk is offline
Old 09-18-2008, 08:13 PM   #13
pat c's Avatar
Trade: ELECTRICAL
Rewards Points: 75
ok...
pat c is offline
Old 09-18-2008, 08:14 PM   #14
pat c's Avatar
Trade: ELECTRICAL
Rewards Points: 75
I mean Okay
pat c is offline
Old 09-18-2008, 09:33 PM   #15
220/221's Avatar
Trade: electrician Phoenix AZ
I mean Okay
Mark....you gotta admit, THAT was funny.
Just because it's within code doesn't make it safe.
Just because it's against code doesn't make it unsafe.
220/221 is offline
Old 09-19-2008, 03:58 PM   #16
Service & Repairs
Magnettica's Avatar
Trade: Electrician
TWPF (that was pretty funny!)
Old 09-19-2008, 04:01 PM   #17
berci electric's Avatar
a lock-out is legal, but not really safe. an "is sight" disconnect would be the safest way to go.
berci electric is offline
sprinkler head location code AustinDB Commercial Construction 7 01-28-2008 06:43 PM
Is a main disconnect code requierment? pitterpat Electrical 25 11-11-2007 10:58 AM
what type gravel for wet location AustinDB Concrete & Paving 4 05-17-2007 07:31 PM
Seperate Location VS Home Office realpurty2 General Discussion 20 05-10-2006 05:10 AM
Location Location Location Tom R Off Topic (Non Trade) 3 11-06-2005 10:50 PM
