LED Wraparound Ceiling Flush Mount - Box Required? - Electrical - Contractor Talk
Old 11-30-2018, 07:53 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 4,376
I'm getting yes's and no's on this.
Replacing fluorescent tube fixtures 4' x 1' with LED's where the romex has been pulled through the ceiling. Plan on using a romex connector. And wire connections will be contained in the coverplate.
Is a ceiling box required?
With other old fluorescent fixtures remaining in the same area, and on the same switch, it will be easier to run the dedicated 1-10v dimmer without the attached boxes later. And I'd rather mount the housing to truss chords for support.
I'm trying to remember if I've ever seen fluorescent tube style fixtures with ceiling boxes...
artinall is offline
Old 11-30-2018, 08:30 PM   #2
tjbnwi's Avatar
Rewards Points: 3,062
Re: LED Wraparound Ceiling Flush Mount - Box Required?
Picture of the fluorescent fixture please.
tjbnwi is online now
Old 11-30-2018, 08:54 PM   #3
artinall's Avatar
Its at the jobsite.
Metalux 4WNLED-LD4-40SL
artinall is offline
Old 11-30-2018, 09:11 PM   #4
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,103
I'd use a wire protector through the hole (or snap in grommet or whatever they're called) and not worry about it.
MarkJames is offline
artinall (12-01-2018)
Old 12-16-2018, 06:08 AM   #5
caviepc's Avatar
Trade: electric
Rewards Points: 12
not if it's a single romex. Just use a romex connector. If it's a j-box, cut around matching hole to expose the box. Screw the fixture to the box.
caviepc is offline
Weather Proof Fan Mount Boxes tenon0774 Electrical 7 06-17-2013 10:43 PM
Weird wiring numbers on a ceiling fan? DemRem Electrical 15 04-17-2013 01:34 AM
Mount Prospect contractor E&D_Remodeling New Member Introductions 1 04-06-2013 09:29 PM
First time ZackyBundles Drywall Picture Post 155 02-07-2013 08:11 PM
3-way wiring- ceiling fan with remote for two-wire hookup hevnbnd Electrical 29 08-17-2009 10:28 PM
