LED Ballast Disconnect - Prior Flourescent Ballast - Electrical - Contractor Talk
Old 11-29-2018, 01:51 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 4,376
Going to a ceiling mount Cooper / Metalux WNLED-WSNLED, wondering what to do with the paired whites/blacks with the common ground attached on the new fixture.
Since this disconnect only seems to accommodate single wires, must the second set for the lamp that follows be pigtailed and wire-nutted? What other way could there be to do this?
In the event the fixture needs taken down, seems the disconnect won't clear the romex connector so that would need to come off 1st in addition to the wire nuts. Is this really an efficient system?
Also, right or wrong, dealer tells me once the wires are inserted they can't be backed off. So do the wires need stripped and if so, how far roughly?
Any help valued.
LED Ballast Disconnect - Prior Flourescent Ballast-cooper-led-disconnect-11.29.18.jpg
artinall is offline
Old 11-29-2018, 02:04 PM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,457
Re: LED Ballast Disconnect - Prior Flourescent Ballast
Usually there is a small keyway for a screwdriver to push a release so you can remove the wire. If not you buy a new connector or just cut the wire and reconnect the new with a wirenut.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
artinall (11-29-2018)
Old 11-29-2018, 02:43 PM   #3
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 11,618
The disconnect is not there 'in case the fixture needs to be removed'. It's there to make it safe to replace the ballast withou having to shut down all the lights. If there's both a line and load in the light, they can be wire-nutted together and a pigtail taken to the disconnect.
If there's two ballasts, then they can be wire-nutted and pigtailed on the downstream side of the disconnect.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
Old 11-29-2018, 03:44 PM   #4
artinall's Avatar
A line and load in the light.
Is another way of saying that..."white to white" "black to black" where both the whites and blacks service this and the downstream fixture? My inexperience obviously trying to clarify (for a family favor).
artinall is offline
Old 11-29-2018, 04:20 PM   #5
480sparky's Avatar
"Line" is 'upstream', towards Hoover Dam. The power coming in.
"Load" is 'downstream, towards the end of the circuit and other loads.
The Following User Says Thank You to 480sparky For This Useful Post:
Old 11-29-2018, 06:00 PM   #6
artinall's Avatar
Got it, there's only one ballast. I'll twist and cap each onto a pigtail leading to disconnect.
But you have me thinking on this. How can downstream be separate from Hoover Dam and the Colorado River tied right there together?
We dare not head further up toward Las Vegas Bay. Do we designate the Colorado some new and unmapped outflow?
artinall is offline
Old 11-29-2018, 09:50 PM   #7
tjbnwi's Avatar
Rewards Points: 3,056
Sad story--3 weeks before a very good friends daughters wedding her finances best man was electrocuted swapping a 277 volt ballast in a commercial fixture. The circuit was shut down, there was a shared neutral in the fixture. He broke the connection and that was the end of his life.
These type of incidents are the reason for the ballast connector shown in the first post. It allows you to service the ballast by simply unplugging it.
Make sure the circuit is shut down and be very carful with the neutrals.
tjbnwi is online now
artinall (11-30-2018)
Checking flourescent ballast bhiggins Electrical 2 10-03-2014 07:13 AM
Panasonic bathroom fan light ballast troubles dale rex Electrical 3 02-15-2014 11:37 AM
Sub-Panel Disconnect Seven-Delta-FortyOne Electrical 2 01-14-2013 11:29 PM
Ballast troubleshooting DIY General Discussion 4 11-16-2010 01:06 AM
Ballast for three F117T12CWHO lamps ? bobbyp Electrical 3 09-16-2006 12:50 PM
