Lead Shielded Cable. - Electrical - Contractor Talk
Old 03-25-2008, 01:14 AM   #1
220/221's Avatar
Trade: electrician Phoenix AZ
Anybody ever run across lead shielded cable?
I remember reading about it during my brief stint in the IBEW apprenticship program in the early 70's and I actually came across it ONE time soon after that, installed as underground feeders to a couple of outbuildings on a rural ranch.
I never saw it again or heard anyone on the message boards mention it.
Anyone?
Just because it's within code doesn't make it safe.
Just because it's against code doesn't make it unsafe.
220/221 is offline
Old 03-25-2008, 12:57 PM   #2
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Rewards Points: 2,002
Re: Lead Shielded Cable.
Like you, I learned about it once in school. The teacher even brought in a sample, sort of like a show 'n tell. The MI cable was dirty and not very flexible.
Magnettica is offline
Old 03-25-2008, 01:51 PM   #3
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
I'm not sure if lead insulated is the same as Mineral Insulated (MI), but we've been installing a lot of MI cable lately being used as snowmelt for light rail platforms. It's a system made by Tyco and pretty pricey from what I heard and pretty fragile from what I've noticed.
If it's kinked it's ruined or as small as allowing an moisture to get on the 'cold joint' ends it's ruined.
Sparky Joe is offline
Old 03-25-2008, 04:58 PM   #4
mdshunk's Avatar
There's quite a bit of lead jacketed cable in my area. Forerunner to UF cable. I normally find it run to detached garages, post lights, fountains, and other places where we'd typically run UF cable today. It sure lasted a lot longer than UF. I use a UF splice kit when I have to fit the stuff. Works okay, since the repair will last as long as the rest of the cable considering the rest of the cable is probably on its last leg.
mdshunk is offline
Old 03-25-2008, 05:28 PM   #5
Old School Marine
randomkiller's Avatar
Trade: Union Journeyman Electrician
Rewards Points: 250
There is plenty of it under the sidewalks of Manhatten. But then again anything in the history of electric can be found in the city someplace.
"If we ever forget that we're One Nation Under God, then we will be a nation gone under." Ronald Reagan
randomkiller is offline
Old 03-25-2008, 10:27 PM   #6
goose134's Avatar
Trade: Union Electrician
Rewards Points: 75
Like Random, plenty of it in Chicago. Only time I've seen it is utility transformer vaults. Although I am working at a building (c.1913) that had a lead sheathed phone cable (about 100 pair). That, I'd never seen before. They couldn't pull it out to scrap it so they cut it flush with the floor. It was in a 2" GRC.
goose134 is offline
Old 03-31-2008, 11:14 AM   #7
cosmo's Avatar
Trade: Electrical
We've got plenty of it at the Federal Facility I work at. In fact we purchased a 500' of 8kv 500kcmil 3 conductor PILC, 500' of 22kv 350kcmil 3 conductor gas filled PILC, and 800' of 8kv 350 kcmil 3 conductor PILC last year. Splicing lead cable is somewhat of an art form.
cosmo is offline
Old 03-31-2008, 11:23 AM   #8
listen twice talk once!
Bkessler's Avatar
Trade: electrician
The recent death of a la firemen that you can read about in one of these posts involved lead lined medium voltage cable.
Bkessler is offline
What Internet lead services should do to corner the market Mike Finley Business 46 12-31-2014 06:46 PM
Troubleshooting ethernet cable gravtyklz Low Voltage 17 02-07-2008 04:39 PM
Cable Calc. sparkengineer21 Electrical 2 02-06-2007 07:01 PM
encapsulating lead paint lornmastro Painting & Finish Work 17 10-03-2006 08:50 PM
