Installing A Hunter Ceiling Fan On A Concrete Ceiling - Electrical - Contractor Talk
Old 07-01-2012, 06:44 PM   #1
dale rex's Avatar
Trade: painting and carpentry
Rewards Points: 187
Sister- in- law needs a Hunter ceiling fan mounted to a concrete ceiling in her apartment.I really dont want to do the job , but the wife insists I help her out since she cant afford to hire somebody. Im going to use a swag kit to run the power from a switched wall outlet up to the fan. My only concern is mounting the fan bracket safely to the concrete ceiling. The Hunter bracket is heavy and large with 8 slots and some holes for mounting. It also has the rubber pads on the top to help with vibration. Im wondering if I should let the pads on and mount the bracket directly to the ceiling (since Im using a swag kit I wont need an electrical box). What would the best method be for attaching the bracket? I can probably get 8 Tapcons(1 3/4" long) in the ceiling. Any other method better than Tapcons? Plastic plugs and pan head screws be sufficient? Maybe some 1/4" dia. wedge anchors?
dale rex is offline
Old 07-01-2012, 08:06 PM   #2
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Re: Installing A Hunter Ceiling Fan On A Concrete Ceiling
tapcons will be fine, rubber mtg ? balance the fan no vibs, swag kit or wire mlg only choice, but you can get stands to hang fans somelook ok.
sunkist is offline
Old 07-01-2012, 08:13 PM   #3
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,652
Say what?
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
The Following 2 Users Say Thank You to 480sparky For This Useful Post:
rselectric1 (07-01-2012), woodchuck2 (07-01-2012)
Old 07-01-2012, 11:22 PM   #4
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
I am going to agree with tapcons with the rubber mount kit. Tighten the tapcon by hand and not with an impact tool, the shock of the impact tool will actually loosen the concrete giving a false sense of being tight when it is about to strip out and slip by possibly dropping the fan.
The rest of that fella's response is up to interpretation, to late to put any more thought into that.
woodchuck2 is offline
The Following 2 Users Say Thank You to woodchuck2 For This Useful Post:
MALCO.New.York (07-16-2012), Red Adobe (07-05-2012)
Old 07-01-2012, 11:25 PM   #5
Fire up the BBQ
griz's Avatar
Rewards Points: 1,900
just make sure you don't hit anything in the ceiling...
get a permit & approval from the complex manager...
griz is online now
thom (07-02-2012)
Old 07-02-2012, 01:00 AM   #6
Thom
thom's Avatar
Rewards Points: 4,748
Double on Griz statement.
Insure there are no post-tension cables, then check again. Make sure this is fine with building management, in writing. A typical lease says NO modifications without written approval. Hit a post tension cable and you and she will find out how expensive that "free" install can be.
Patriotism is being loyal to your country all the time and your government when it deserves it. Mark Twain
thom is offline
Old 07-02-2012, 04:51 AM   #7
dale rex's Avatar
Rewards Points: 187
do you think the post tension cables would be that close to the surface?
dale rex is offline
Old 07-03-2012, 01:31 AM   #8
General Contractor
Doctor Handyman's Avatar
Rewards Points: 418
Do you think it is that easy to drill through a p-t cable with a 1/4" masonry bit?
Doctor Handyman is offline
Old 07-03-2012, 01:44 AM   #9
chewy's Avatar
Trade: Electrical Apprentice and Data Technician.
Rewards Points: 1,208
They are generally where you think they arent but sometimes appear where you dont want them aswell.
It can be sometimes difficult to ascertain if you have hit steel, most screwdriver bits are magnetized slightly with use so if you stick one in the hole it will tell you if you have hit steel or a piece of aggregate by the filings sticking up off it.
I would mark out all fixings holes and test drill providing there is a cowling that will cover them, Id also use a mechanical anchor, bolt and sleeve type instead of a lead or plastic plug which will fail in the event of a fire.
chewy is offline
Old 07-03-2012, 01:46 AM   #10
chewy's Avatar
Actually cant she just get a pedastal fan???
chewy is offline
Old 07-04-2012, 11:08 AM   #11
Old Timer
CCW's Avatar
Trade: Low Voltage
Rewards Points: 29
When dealing with a wife and sister-in-law, that's not a healthy solution
CCW is offline
Old 07-04-2012, 11:40 AM   #12
The Ultimate Wire Hider
tedanderson's Avatar
Trade: A/V & Home Theater Installation
Rewards Points: 2,116
I wouldn't feel too comfortable with the tapcons being that there will be vibration from the fan. You really need to secure it with one of those 3/8" steel concrete anchors that they use to attach allthread to ceilings in office buildings. And then use a thread locking compound to keep the bolts in the anchors.
Generally speaking, I can see that this is a tough situation. But personally I would stand my ground and not do it. I think that I'd rather deal with them being mad at me for refusing to do the work than trying to explain how the fan fell down when I wasn't sure that it could stay attached in the first place.
The second thing that would cause me to walk away from this job is that if she can afford the fan but can't afford to have it installed, she really can't afford the fan in the first place. And I say this because I doubt that having to pay the price of installation didn't come as a surprise to her.
tedanderson is offline
Old 07-04-2012, 02:40 PM   #13
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Just use a fastner that's designed for a dynamic load, typically it's 1/4 the tensile rating.
Inner10 is offline
Old 07-04-2012, 05:39 PM   #14
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,366
http://www.arcadianlighting.com/fm-f...FYao4AodIRWbFQ
-Dennis
WarriorWithWood is offline
Old 07-04-2012, 07:52 PM   #15
dale rex's Avatar
Rewards Points: 187
Ceiling fan on a stand? Who have ever imagined such a thing? A bit pricey, but nevertheless it does exist as Sunkist posted. I am thinking about using a 1/4" wedge or sleeve anchor in the middle plus several Tapcons around the perimeter of the base plate. I feel that would anchor it securely. I cant wiggle my way out of this one, I'm committed(or should be committed) Im sure you guys know what its like being the "contractor" in the family. Im the "go to" guy for everyone.
dale rex is offline
Old 07-05-2012, 12:11 AM   #16
Red Adobe's Avatar
Trade: Metal Roofs, Sparky , Remodels and beer specialist
Rewards Points: 92
tapcons should do just fine as long as you dont waller the holes and only go hand tight as said above.
Wing toggles would be more better tho
Red Adobe is offline
Old 07-10-2012, 09:43 PM   #17
mrcharles's Avatar
Trade: GC, Remodeling
Rewards Points: 1,652
How would wing toggles work in as concrete ceiling? They wont be able to spread.
mrcharles is offline
The Following User Says Thank You to mrcharles For This Useful Post:
Old 07-11-2012, 07:16 AM   #18
Inner10's Avatar
The concrete has to end somewhere.
Inner10 is offline
Old 07-11-2012, 10:33 AM   #19
WildWill's Avatar
Rewards Points: 504
Female threaded wedge anchors.
http://www.industrialhardware.com/sk...edgeAnchor.pdf
WildWill is offline
Old 07-11-2012, 07:38 PM   #20
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,598
Hilti makes drop in anchors that are made for tensioned concrete. Only 3/4" depth into the concrete. Works great
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Concrete Company delivered junk concrete. How best to pursue? marcomjl Concrete & Paving 47 06-03-2014 10:17 PM
?? About installing hardwood over concrete above grade?? maleko Flooring 16 03-03-2011 12:36 AM
4x4 posts in concrete vs. saddles Strongarm Decks & Fencing 20 08-31-2009 09:41 PM
installing a ceiling fan with light metiernan Electrical 25 04-05-2009 06:48 PM
Installing wallpaper on a ceiling ProWallGuy Wallpaper 3 06-28-2008 07:31 PM
