How Many Amps From The Xfrmr? - Electrical - Contractor Talk
Old 11-28-2009, 03:00 PM   #1
DetailHandyman's Avatar
Trade: Professional Handyman
Driving by a recently renovated building in town today got me wondering...
This building was converted to 4 apartments, so there are five meters on the side.
Assuming that each service is 100A, the building could, in theory, pull 500A from the pole.
So, what's the max amperage one of these standard sized pole transformers will supply?
The cat box ain't gonna clean itself.
DetailHandyman is offline
Old 11-28-2009, 03:24 PM   #2
rselectric1's Avatar
Rewards Points: 818
Re: How Many Amps From The Xfrmr?
Tree Fiddy
Oops-wrong thread just kidding!
Actually I am curious too!
rselectric1 is offline
Old 11-28-2009, 03:38 PM   #3
13 Licenses & Counting
piercekiltoff's Avatar
Trade: Water well drilling & pumps
Rewards Points: 168
Dependent more on the size of the wire to them, the voltage to them, etc.
The size of the transformers are just a function of the number turns that the wire makes in the transformer. At least, that's what I recall from physics.
For example, a 20kv line leading into a transformer that turns it down to 230 volt will have more 'turns' in the transformer than one that converts 10kv down to 230v. Higher amperage can be obtained at the users end with the same size cables between the PUD & the transformer by running higher voltage into the transformer, and then just larger wire from the transformer to the meter bases.
So...I think the question comes to - what's the largest practical wire size to run between the transformer and the meter base, based on a realistic length between the two places? Copper 1000 wire is rated to 545 amps @ 75 deg. Celsius. This may be the largest wire commonly available, based on the chart I'm looking at.
Pierce Kiltoff, CWD/PI, JKA Well Drilling and Well Pumps & Filter Supply - Map Facebook
Monroe, Washington, (360)-794-7300
Serving the Entire Seattle Area, including King, Snohomish, & Pierce Counties, WA
piercekiltoff is offline
Old 11-28-2009, 04:46 PM   #4
Originally Posted by rselectric1 View Post
Tree Fiddy
Maybe Five Fiddy?
Old 11-28-2009, 04:51 PM   #5
Valid point there.
I'm just thinking that there must be a Model XYZ transformer that is typically installed in residential usage. How many amps can that supply?
Old 11-28-2009, 05:36 PM   #6
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Rewards Points: 2,002
First we need to know if the service is single-phase or three-phase.
Second, we need to know square footage of the building and some of the appliances that'll be used so we can define a calculated load.
Last but not least, (5) 100 amp service disconnects does not constitute a 500 amp load. In fact, you could have as many disconnects rated at 100 amps as you'd like but after (6) of them you'll need (1) main disconnect so the fire department can quickly disconnect power to the building in the event of a fire.
Magnettica is offline
Old 11-28-2009, 06:41 PM   #7
Oh damn...this is getting complicated.
I thought I had a simple question that someone was going to answer "Geez dumbass...you can only get X amps out of that".
I'm not looking to do a load calc on the apartment, I just want to know how many amps you can pull from a typical residential pole transformer before it starts to melt.
But, it could draw 500A in our hypothetical world, correct?
Old 11-28-2009, 06:57 PM   #8
Master Electrician
Bubbles's Avatar
Trade: Electrical
Rewards Points: 250
400
Bubbles is offline
Old 11-28-2009, 09:22 PM   #9
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 11,450
Originally Posted by DetailHandyman View Post
Valid point there.
22,000.
No joke. That's probably the short-circuit current rating.
If there's a highway to hell and only a stairway to heaven, that pretty much tells you what the traffic patterns are expected to be.
480sparky is offline
Old 11-28-2009, 09:32 PM   #10
Originally Posted by 480sparky View Post
22,000.
I believe.
Old 11-28-2009, 10:16 PM   #11
480sparky's Avatar
I believe.
Especially when you've witnessed the Big Blue Zot.
Old 12-02-2009, 12:31 AM   #12
Rewards Points: 168
Amps..
+ YouTube Video
Old 12-02-2009, 09:16 PM   #13
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Well, it depends... but let's say it is single phase.
At 240 volts, a 50kva transformer can provide 208 amps.
A 75kva can give you 312.
Ohm's law = P/ E = I or watts divided by volts equals amps.
The type they use on the street vary dependent upon the actual connected load. Transformers also look different from state to state, believe me, I know because I look at them.
Old 12-04-2009, 03:53 PM   #14
Philadelphia electrician
RobertWilber's Avatar
Trade: Electrical contractor
Rewards Points: 250
Amps..
+ YouTube Video
That was amazing!
I saw a back-hoe grab 13.2 once on a job-site near a pad-mount transformer. The machine had every joint welded together by the time power was shut down, like a huge sculpture.
Best one I ever saw was a phase-to-phase fault on a 2000 kva 2-phase transformer. It burned back from a connector and puddled the conductors, creating an arc furnace in a duct under 16th street in Philadelphia. It was spewing molten copper out an uncovered end-box. The faces of the firemen who responded were completely WHITE because the copper was spraying onto a bank of gas meters.
Anyway, available short circuit current is also a function of tansformer impedance. You can get hellish currents for short periods.
RobertWilber is offline
all 30 amp fuses from the inside handyman99 Electrical 11 09-05-2009 08:49 PM
Low amps kills skill saw? Bill Electrical 32 12-13-2008 04:14 PM
100 amps or 200 amps ? Miss Sunshine Electrical 21 09-10-2008 10:09 PM
Adding 400 amps to Commercial Bldg Bubbles Electrical 10 08-22-2008 05:39 AM
volt amps vs watts Bkessler Electrical 10 11-26-2006 05:21 PM
