Help Out A Dummy - Electrical - Contractor Talk
Help Out A Dummy
Old 07-29-2012, 10:57 AM   #1
Still have all my fingers
Bergstrom's Avatar
Help Out A Dummy
I have a fuse type service panel in my old house and recently one of the circuits just went dead. I replaced the fuse with a known good replacement but it didn't help. I probed the fuse socket and it wasn't showing any incoming voltage. I checked my work against a different circuit just to make sure I was testing it correctly and it showed 120v.
The problem fuse socket is located in a 4 fuse distribution block and I am assuming that the problem is internal since there is voltage to the other fuse sockets in the block. Don't worry I am going to call a licensed professional and have the panel upgraded to breakers if need be but I would like to know if I'm barking up the right tree before I make the call. Thanks!
Killing the Earth, one raised panel at a time.......
http://bergstromcabinets.com
http://minneapoliscabinets.biz
http://maplegrovecabinets.com
Bergstrom is offline
Old 07-29-2012, 11:10 AM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,978
Re: Help Out A Dummy
Are your fuseholders been converted to tamper-resistant?
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
Old 07-29-2012, 11:31 AM   #3
Bergstrom's Avatar
Yes, they are type S
Old 07-29-2012, 12:25 PM   #4
480sparky's Avatar
Are you using the proper sized fuse in the fuseholder? A 20a S fuse won't work in anything other than a 20a adapter.
Old 07-29-2012, 12:47 PM   #5
Bergstrom's Avatar
I think so, just to make sure I pulled the 20A out and tried a 15A but it only screwed in a couple turns. The 20A screws in smoothly and bottoms out in the holder.
Old 07-30-2012, 09:38 AM   #6
Bergstrom's Avatar
Anyone?
Old 07-30-2012, 09:47 AM   #7
480sparky's Avatar
Then I'd start looking downstream.
Old 07-30-2012, 09:55 AM   #8
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
For your paddle
Gus Dering is offline
The Following User Says Thank You to Gus Dering For This Useful Post:
Windwash (07-30-2012)
Old 07-30-2012, 10:48 AM   #9
Bergstrom's Avatar
Originally Posted by Gus Dering View Post
For your paddle
Leave me alone Gus, I never said I knew anything about electrical cabinets
Old 07-30-2012, 10:53 AM   #10
Bergstrom's Avatar
But shouldn't the fuse holder show incoming voltage? I removed the fuse and checked voltage, 0. I then pulled out another fuse and did the same thing and it showed 120v
Old 07-30-2012, 11:11 AM   #11
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 14,659
That's the only circuit dead?
Is the tab still attached, they can break off and dangle. Never seen it in a fuse, but have seen it in a light socket.
Been so long since I've seen the old fusebox. I had an 8 circuit one in my house for 15 years. Used the circuit breaker fuses.
You need to find out if its the neutral or the hot that's dead. The inside is the hot and the thread is the neutral(/ground). Put one lead of the meter on the thread of the suspect holder and go into another holder and put the probe on the hot (center), see if there is voltage. Try it on a couple if you don't find voltage. Do the same thing for the center of the suspect holder and that way it will determine what is bad, the hot or neutral. I'm guessing the hot.
Other than that....hit it with a hammer. Sometimes it works.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 07-30-2012, 11:28 AM   #12
Bergstrom's Avatar
Thanks Leo,I'll check it out but I'll bring my 10# sledge with just in case
Old 07-30-2012, 11:47 AM   #13
480sparky's Avatar
I forgot that part.
Then start looking upstream.
Old 07-30-2012, 11:57 AM   #14
LRG WoodCrafting
Leo G's Avatar
Be gently with the sledge. Part of it still works. You don't want to break the whole thing.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 07-30-2012, 01:55 PM   #15
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 1,056
don't know how common fuseboxes are around you, but I say pull out that POS and install a panel.
TxElectrician is offline
Old 07-30-2012, 06:02 PM   #16
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,020
Fuse panels like that are physically very simple. Cut the power to it and tear it apart, and you probably won't even need a meter to find the problem.
Whether it's easily correctable with a hammer & chisel is a different question.
Since you admit to being a bit shy on the sparky side, probably best to just bite the bullet and have a modern panel installed.
Tinstaafl is offline
Old 07-30-2012, 07:40 PM   #17
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Did you check both legs?
Inner10 is offline
Old 07-30-2012, 07:45 PM   #18
Gus Dering's Avatar
Heck yeah and they were awesome
They had feet on the bottom and something else on the top
Get a new panel Bergy
Old 07-30-2012, 07:53 PM   #19
LRG WoodCrafting
Leo G's Avatar
Yes, yes I did
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 07-30-2012, 08:14 PM   #20
Gus Dering's Avatar
Originally Posted by Leo G View Post
Yes, yes I did
Thats what I call call "two hot legs"
But It lends no help to jog my memory.
Something is up there and I know it can be energizing. May be the power source.
Article Submission by Footbridge Media! PGD Marketing & Sales 34 07-13-2012 08:49 AM
tile shower pan Mcdonoughman Tiling 63 11-29-2011 05:22 PM
California Framing Questions MTN REMODEL LLC Framing 33 09-04-2010 11:41 AM
Dummy used anchorseal for deck finish deckman22 Decks & Fencing 2 09-30-2009 06:54 PM
recessed lights choice/tips (for dummy) dainova Electrical 10 01-18-2008 08:41 PM
