Grounding New Service - Electrical - Contractor Talk
Old 11-10-2014, 12:00 AM   #1
bluebird5's Avatar
Trade: Licensed G. C. carpenter, flooring, remodeling
Rewards Points: 694
I am building my personal house and will be pulling a self permit for the electrical. I worked for an electrician for a couple years several years ago, but codes have changed since then. We used to drive ground rod connect meter base to ground rod and then panel to cold water pipe.
My current municipality has adopted the 2011 NEC. I have installed the "ufer" rebar coming out of the footing. I have a meter base, then my 200 amp service disconnect and then my panel in the house which is now a sub panel because the service disconnect is the panel.
Now do I just drive a ground rod and bond the ground rod to the ufer and run #4 copper from meter base to the ufer with acorn clamp or do I not even need the ground rod anymore because I have the ufer?
Thank you
bluebird5 is offline
Old 11-10-2014, 11:30 AM   #2
Red Adobe's Avatar
Trade: Metal Roofs, Sparky , Remodels and beer specialist
Rewards Points: 92
Re: Grounding New Service
Here you need 2 ground rods 6' apart , continuous ground wire to and thru meter and into new panel.
Easiest thing is to call your local inspector and ask him what he wants to see.
Red Adobe is offline
Old 11-10-2014, 07:31 PM   #3
luckyshadow's Avatar
Trade: electrical professional
Rewards Points: 33
Based on the National Electrical Code - You do not need a ground rod.
Seeing how you installed the Concrete encased electrode ( uffer) there is no requirement to supplement it with another grounding electrode. I would double check with your local Jurisdiction to verify as they may have a local amendment that requires one.
luckyshadow is offline
The Following 3 Users Say Thank You to luckyshadow For This Useful Post:
bluebird5 (11-11-2014), Meadow (12-01-2014), Red Adobe (11-29-2014)
Old 11-22-2014, 11:14 AM   #4
Expeditious Member
JohnR's Avatar
Trade: Electrician
Rewards Points: 26
I agree with Luckyshadow, but you do need to bond the water piping still. Also if you have gas piping you will need to bond that as well.
As far as ;hitting the meter with the ground, My local utility would not allow that. You might want to check with you local utility or inspector as to what is expected with that. Here we have to ground at the first point of disconnect- usually the panel with a main breaker. Once in a while it will be at the meter so long as there is a main breaker there.
JohnR is offline
Old 11-28-2014, 07:43 PM   #5
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
with the water and gas going to plastic pipe what good is it to ground to them
pappagor is offline
The Following User Says Thank You to pappagor For This Useful Post:
Old 11-29-2014, 12:46 PM   #6
Mark122's Avatar
Rewards Points: 464
They allow G.C's or homeowners to pull Electrical permits?
Mark122 is offline
Old 11-29-2014, 05:46 PM   #7
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,426
In my state , don't know about GC, but a HO can pull the permit and do his own wiring, it has to pass inspection though. Not suppose to pull it and have some one else wire it for you as a HO , but it happens all the time.
Randy Bush is offline
Old 11-29-2014, 07:54 PM   #8
Red Adobe's Avatar
Rewards Points: 92
In NM you can pull a HO permit and hire people......do need inspections as well. They are real watchfull of the work being done.
We had a mess on a house when our inspector (electrical ) saw a bunch of new pex and that the house was re plumbed, Plumbing wasn't on the HO permit. SWO on entire project for 2 weeks untill they got more permits and paid 2x what it would have been. Moral if you pull a permit for 1 thing do it for everything LoL
Old 11-29-2014, 08:30 PM   #9
Mark122's Avatar
Rewards Points: 464
I live in Chattanooga, Tn. only about two hrs from the OP's jurisdiction.
Like in every state, every jurisdiction is different on what they adopt, allow and not allow.
Just surprised that being so close to Nashville he would not be governed by the same standards in the Nashville area.
Nashville and Chattanooga are both very similar. chattanooga does not allow a home owner or g.c. to even pull for a temporary pole. licensed electrician needs to. homeowners, gc or the pope, if not licensed for that trade can not pull trade permits.
Mark122 is offline
Dewalt Customer Service Tylerwalker32 Tools & Equipment 3 02-14-2013 08:16 PM
new company - first winter service wetbar General Discussion 2 10-03-2012 10:26 PM
Google Places - Address not in Service Area allcityexterior Marketing & Sales 4 06-17-2012 02:54 PM
