Grounding A 2 Prong Outlet - Electrical - Contractor Talk
Thread Tools
Old 05-13-2020, 01:00 PM
aar0nhurst's Avatar
Trade: Laborer
Rewards Points: 42
Home built in 1961. Original fuse, 2 wire system, metal boxes still in place throughout home.
I had an electrician tell me that if I add a ground wire to the back of the metal box that would ground the outlet and I could replace it with a 3 prong receptacle. Additionally, if I place a GFCI at the beginning of a run of outlets, that subsequent receptacles would trip the GFCI if faults occur.
I disagree with the grounding method.
I agree with the GFCI statement but only if the subsequent boxes are grounded.
From what I've seen, the metal boxes have no grounding back to the panel. I can see wires in the attic running to metal junction boxes but the wires do not have conduit around them. I'll get a picture of one of the 2 prong boxes but I have attached a picture of the wires coming up to the attic.
So my questions are:
1. Is that an effective grounding technique for 2 prong outlets?
If not,
2. Can an ungrounded outlet trip a GFCI?
If so,
3. Do we agree that subsequent boxes would trip the GFCI?
aar0nhurst is offline
Old 05-13-2020, 01:21 PM
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 17,771
Re: Grounding A 2 Prong Outlet
Is the wire NM or BX/MC?
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
aar0nhurst (05-13-2020)
Old 05-13-2020, 01:33 PM
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 13,028
Originally Posted by aar0nhurst View Post
.....I disagree with the grounding method.
It may work, it may not. Depends on if the box itself is grounded.
...I agree with the GFCI statement but only if the subsequent boxes are grounded....
Is a common myth that GFCIs need to be grounded to function properly. They never have been, and they never will need to be in order to protect against electric shock..
Fact is, if you use a GFCI device to protect downstream ungrounded receptacles, you are PROHIBITED from grounding them. 410.3(D)(3):
(c) A non–grounding-type receptacle(s) shall be permitted to be replaced with a grounding-type receptacle(s) where supplied through a ground-fault circuit interrupter. Where grounding-type receptacles are supplied through the ground-fault circuit interrupter, grounding-type receptacles or their cover plates shall be marked “GFCI Protected” and “No Equipment Ground,” visible after installation. An equipment grounding conductor shall not be connected between the grounding type receptacles.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
The Following 4 Users Say Thank You to 480sparky For This Useful Post:
aar0nhurst (05-13-2020), Golden view (05-13-2020), Rio (05-13-2020), Sisyphus (05-15-2020)
Old 05-13-2020, 01:35 PM
LRG WoodCrafting
Leo G's Avatar
Works off the neutral. Trips on an unbalance current.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
The Following 2 Users Say Thank You to Leo G For This Useful Post:
Old 05-13-2020, 01:39 PM
480sparky's Avatar
GFCI's work off both the hot and neutral. If there's an imbalance, it will trip.
The Following User Says Thank You to 480sparky For This Useful Post:
Old 05-13-2020, 02:31 PM
aar0nhurst's Avatar
Trade: Laborer
Rewards Points: 42
Wow! Great information and I appreciate it.
So as it sits today, no grounds are present in the wall outlets. The only ground that exists is at the panel. If I understand what I've read correctly, I can install a GFCI outlet without a ground AND that same GFCI will protect downstream outlets if current fault occurs? All without a ground?
Old 05-13-2020, 03:28 PM
480sparky's Avatar
If you can locate the first receptacle in the line and know how to identify the line & load conductors, you're golden.
One caveat, however: You may end up protecting more than just receptacles. Anything can be on that circuit. Over the years, stuff gets added, changed, moved, extended etc. So you might end up with either nuisance tripping, or the GFCI may trip and you lose power to something you don't want power turned off to (freezer, fridge, sump pump etc.)
Old 05-13-2020, 04:18 PM
90%-er
onmywayup's Avatar
Rewards Points: 50
If this is your house, it's a great time to take an afternoon and map out/label your circuits. It pays you back over and over again in the future.
Sent from my SM-G973U1 using Tapatalk
onmywayup is online now
The Following User Says Thank You to onmywayup For This Useful Post:
Old 05-13-2020, 04:33 PM
LRG WoodCrafting
Leo G's Avatar
Well ya... Has to check the imbalanced from something.
And that's the hot.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 05-13-2020, 06:53 PM
aar0nhurst's Avatar
Trade: Laborer
Rewards Points: 42
I called another electrician and plan to replace the fuses with breakers, upgrade from 100amp to 200amp service, and put a new mast on the house. I asked if he would map the circuits and he told me he would...as long as there weren't any rogue wires they can't find. Y'all were right on the money. Thank you.
The Following User Says Thank You to aar0nhurst For This Useful Post:
onmywayup (05-13-2020)
Thread Tools
Rate This Thread
