GFCI Receptacle - Electrical - Contractor Talk
GFCI Receptacle
Old 06-06-2013, 07:31 PM   #1
yonexwood's Avatar
Trade: Floors and Interior Walls
GFCI Receptacle
I have a water softener installed outside the house under the eves. It is plugged into an outside receptacle by way of a GFCI which has a cover on it. The water softener is converted to 12v by way of a transformer plugged into the GFCI.
I have had the WS for 10years & 3 GFCI have gone bad. The last one lasted 1year. Do I need a GFCI or can I go with a regular receptacle & do you have any ideas on the poor GFCI performance. (The GFCI in the bathroom does not trip when the outside one does)
Yonexwood
yonexwood is offline
Old 06-06-2013, 07:40 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,826
Re: GFCI Receptacle
Get a GFCI that is WR rated, and install an in-use cover.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
MTN REMODEL LLC (06-06-2013)
Old 06-06-2013, 10:43 PM   #3
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,366
Re: GFCI Receptacle
I bet a GFCI breaker will last longer but this is only a guess.
-Dennis
WarriorWithWood is offline
Old 06-07-2013, 06:11 PM   #4
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Re: GFCI Receptacle
Wall worts often don't fit in them. Put the transformer inside and run a low voltage wire out to the unit.
Inner10 is offline
Old 06-07-2013, 06:21 PM   #5
480sparky's Avatar
Re: GFCI Receptacle
I guess I missed the wall wart being mentioned.
Old 06-07-2013, 06:23 PM   #6
Inner10's Avatar
Re: GFCI Receptacle
I figured if it was outside it wouldn't be a brick.
Inner10 is offline
Old 06-11-2013, 06:57 PM   #7
yonexwood's Avatar
Re: GFCI Receptacle
If the 12v transformer is a wall wart? It is out side plugged into the GFI inside a WR cover.
yonexwood
GFCI breaker vs GFCI Receptacle gravtyklz Electrical 15 11-06-2019 05:42 PM
What will kill a GFCI receptacle? thom Electrical 7 03-31-2011 02:30 PM
GFCI Receptacle Thomp Electrical Picture Post 18 11-23-2010 11:30 AM
GFCI breaker - that sensitive? geospec Electrical 14 07-24-2010 10:05 AM
AFCI breaker and GFCI receptacle ? Bubbles Electrical 7 10-18-2007 08:40 PM
