Trade: Fire Prevention & Safety
Fire Suppression System Micro Switch
I need help explaining to an electrician how to connect my micro switch to the elect. I've already installed the micro switch in my controll head. I can't not find a schmatic for him and just telling him Red is common, Yellow N.O. & Black N.C. and that all the elect under the hood needs to shut down except the exhaust fans stay on ... is not enough. Any suggestions?? All I have is a pic of the microswitch and not a schmatic.
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
#2 | |
Capra aegagrus
![]() ![]() Trade: Remodeler
Rewards Points: 517
Re: Fire Suppression System Micro SwitchQuote:
Also, forgive my bluntness, but if you can't whip out a schematic for that on a paper napkin in about 5-10 seconds, maybe you shouldn't be fooling with the job in the first place. Advertisement |
I own stock in FotoMat!
Rewards Points: 11,248
Fire suppression systems many times need to do more than just shut down the MAU. They also must shut down any electrical under the hood (typically required with the new wet systems, no so much w/the old halon), and may even need to trigger the fire alarm system. Pretty tall order for a part with a wholesale cost of $1.37. There are some systems that have a sum total of two microswitches, but it still falls on the electrician to make the system function as required.
If the electrician on site is unable to figure out how to accomplish all this, perhaps the owner/GC should find someone qualified.
If there's a highway to hell and only a stairway to heaven, that pretty much tells you what the traffic patterns are expected to be. |
The Following User Says Thank You to 480sparky For This Useful Post: |
Tinstaafl (04-11-2011)
Trade: Fire Suppression Equipment Sales & Service
Rewards Points: 324
I do not understand how you could design and install a suppression system with out the install manual. Every install manual I have shows how to have the electrician wire the switches. If the electrician is not on site when I am ready for him, I print the schematic pages and leave them in the panel. I also print in BIG letters, "Make NO electrical connections in this mechanical panel. This panel is not listed for electrical connections. Make all connections outside this box".
What brand system is this? |
Ansul ~ which shouldn't make any differance for the electrical hook up ...
I've already installed the micro switch in the panel with the wires feed outside the panel with instructions to make the connection outside the mechanical panel ~ which is my job ... what is not my area is hooking it up to the elect. I've checked 4 of the manuals that I have and not one system manufactures has instructions for the elect hook up only on installing the microswitch in there mech control head.
Head Grunt
Rewards Points: 2,196
Still quite easy to figure out if this electrician is competent. At most he may have to use a meter and figure out which side of the switch is open or closed and then figure out if he is using shunt trip breakers or is he using relays?
#8 | |
Unless the system isn't 'standard', I rarely interact with the hood installers, even when we're concurrently on-site. And a single microswitch is about as standard as it gets. Sounds like a very incompetent electrician has been hired by an almost equally incompetent builder. Sparky: (Looking at microswitch wondering what the 3 wires are for, and how to connect his 2-wire circuit to it, thinking "this looks like a switch, and I know enough not to hook a hot and a neutral to a switch because that will cause a short. I'd better ask for some details before I proceed otherwise I'll look like an idiot) "Hey, Mr. Builder, I need you to call the Hood Guys for a wiring diagram on this!"........... Builder: "OK, I'll call 'em!", (reaching for his phone, not knowing what to ask for or who to talk to and not having the gumption to ask Sparky otherwise he'll look like an idiot.....)
haha I love it ... thx and btw today didn't go well at all since there were other electrical issues with connects from the brakers. Another electrician is coming in the morning sooo, hopefully he can get it done lol Thank You!
Advertisement |
Tags |
electrical
fire suppresion system
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Ansul system wiring | rad04 | Electrical | 16 | 07-27-2017 10:18 PM |
New Fire Protection Guy | banderson | New Member Introductions | 7 | 11-15-2010 06:23 AM |
Fire Alarm system needed in Hatfeild, PA | pinakin | Help Wanted or Looking For Work | 0 | 08-02-2010 07:44 AM |
fire system | rbring | New Member Introductions | 1 | 06-11-2010 12:47 AM |
light and fan switch | red_cedar | Electrical | 17 | 02-24-2010 07:54 AM |
Go to Page... |
