Electrical Confusion - Electrical - Contractor Talk
Old 10-23-2018, 09:56 PM   #1
jtomm's Avatar
Trade: Handyman
Rewards Points: 38
Iím not much for the electrical work. I tend to lean toward installing outlets and switches as well as a few other basic services. However, Iíd like to install driveway lights at my property on my own. Ideally Iíd like to tap into my shops panel and run it to the light at the top of the driveway (about 400í away). My current plan is to run some 12 gauge underground wire through conduit to the first post. Planning to have 3-4 lights on the driveway. Havenít decided if Iíll go with LED or not. Also unsure of the wiring to run between lights. A buddy of mine gave me some from his place and it seems to work but want to make sure I have the right stuff. Is this the right gauge wire for this project?
jtomm is offline
The Following User Says Thank You to jtomm For This Useful Post:
micahmye (10-28-2018)
Old 10-23-2018, 10:09 PM   #2
MarkJames's Avatar
Rewards Points: 19,531
Re: Electrical Confusion
Have you considered solar-powered ground sconces, etc, or are you looking for more serious lighting? They probably make solar-powered lamp posts, too.
MarkJames is online now
Old 10-23-2018, 10:10 PM   #3
back doors to hell put in
Irishslave's Avatar
Rewards Points: 1,314
Confusion and Electricity don't play well together
Irishslave is offline
The Following 2 Users Say Thank You to Irishslave For This Useful Post:
Fouthgeneration (10-25-2018), TheConstruct (10-23-2018)
Old 10-23-2018, 11:40 PM   #4
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 158
I'd probably put your friends free wire on a nail and instead run THWN in conduit to a middle hidden post. From there I'd install a 24 volt transformer controlled by a photocell and run my low voltage wires in opposite directions to my lights.
P42003 is offline
Old 10-24-2018, 07:24 AM   #5
diplomat
Golden view's Avatar
Rewards Points: 1,550
Low wattage line voltage lights will give you minimal voltage drop over such a great distance. I don't see an issue with what you're proposing. Underground wire with the added protection of conduit.
But I'm not a sparky.
Golden view is offline
Old 10-24-2018, 07:31 AM   #6
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 12,891
Don't think you are suppose to run UF in a conduit either.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 10-24-2018, 08:03 AM   #7
jtomm's Avatar
Trade: Handyman
Rewards Points: 38
So sounds like I should be okay just running 12 gauge wire 400í feet underground to the first post and then my lights will be powered from there. Hereís a picture of my proposed plan
jtomm is offline
Old 10-24-2018, 08:43 AM   #8
MarkJames's Avatar
What about voltage drop for that length?
Old 10-24-2018, 12:09 PM   #9
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,874
Perfectly legal.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
The Following 2 Users Say Thank You to 480sparky For This Useful Post:
slowsol (10-28-2018), Wile E Coyote (10-24-2018)
Old 10-24-2018, 04:36 PM   #10
jtomm's Avatar
Trade: Handyman
Rewards Points: 38
The lights are positioned on trees or posts next to trees so they wonít get much light.
jtomm is offline
Old 10-24-2018, 09:50 PM   #11
diplomat
If the lights are LED low power it'll be minimal.
Old 10-24-2018, 10:41 PM   #12
tjbnwi's Avatar
Rewards Points: 4,774
Do a ring system.
tjbnwi is online now
Old 10-24-2018, 11:07 PM   #13
jtomm's Avatar
Trade: Handyman
Rewards Points: 38
Originally Posted by tjbnwi View Post
Do a ring system.
Can you explain this?
jtomm is offline
Old 10-25-2018, 12:01 AM   #14
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Feed from both ends.
Inner10 is offline
Old 10-28-2018, 04:26 PM   #15
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,839
Use A 240VAC input transformer, that will cut V drop issues to 1/4th of 120VAC input tranny
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
P42003 (10-28-2018)
Old 10-28-2018, 05:20 PM   #16
diplomat
Seriously. You guys are probably overthinking this with ring system and 240V transformers. If you have a few 11 or 15 watt LEDs, you essentially won't have any voltage drop (as far as the lights are concerned) with 12 gauge wire. Even at 1000 feet.
Old 10-28-2018, 06:37 PM   #17
tjbnwi's Avatar
What he said.
Same power supply, cable enters both ends of the load path.
Just don't cross the +/-.
Unless you're using AC rated LED's you need a power supply, not a transformer.
Old 10-29-2018, 04:11 PM   #18
Trade: Masonry
The beauty of a 240 VAC input power supply lowers the operator cost every hour of night for the life of the system, You could switch to a 14 gauge wire or 10 gauge and have a GFIC outlet for seasonal decorations and wattage for future security devices/ gates......
The "ring" circuit fascinates me... I'd consider using it on work bench outlets and kitchen counter outlets to improve performance.
A ring circuit on one's plumbing might actually yield more noticeable improvements in steady supply rates and temps....
Old 10-29-2018, 05:53 PM   #19
tjbnwi's Avatar
Rings work well in low voltage landscape systems (12 or 24 volt). There’s not much push in the systems so entering both ends really helps.
Ring line voltage systems are very common in the UK.
Old 10-29-2018, 05:55 PM   #20
tjbnwi's Avatar
A lot, if itís a 12 volt system heíll be down to about 9 volts.
How to estimate Electrical job fall99val Electrical 1 01-12-2015 10:12 PM
How to Estimate Electrical job fall99val General Discussion 3 01-12-2015 10:09 PM
Outside Electrical Sales Commission Structure - Advice Needed jabbo930 Marketing & Sales 0 11-12-2014 04:33 PM
Electrical Service Disconnect - Residential wuraider36 NEC Discussion 7 12-20-2010 11:19 PM
