Electric Shower Head - Electrical - Contractor Talk
Old 03-29-2016, 03:41 PM   #1
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 52
These are used in Central America countries. Bought it home with me a few years back when we where down there. Was wondering if anyway they can be used in the states here.
Randy Bush is online now
Old 03-29-2016, 03:43 PM   #2
Randy Bush's Avatar
Rewards Points: 52
Re: Electric Shower Head
another picture of it.
Old 03-29-2016, 03:49 PM   #3
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 18
Is it listed?
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
rselectric1 (03-29-2016)
Old 03-29-2016, 04:04 PM   #4
Electrical Contractor
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
I doubt they are listed--- The ones I have seen in South America have a wire coming out of the wall and connect directly to the wires coming out of the unit... Just wirenuts.
My son was in Ecuador and said every time he touch the shower head and the handles he got shocked-- I told him that was an easy fix-- don't touch them at the same time
C'est Moi is offline
The Following User Says Thank You to C'est Moi For This Useful Post:
SmallTownGuy (03-29-2016)
Old 03-29-2016, 04:10 PM   #5
rselectric1's Avatar
Rewards Points: 926
Originally Posted by 480sparky View Post
Is it listed?
and 60 hz?
rselectric1 is offline
Old 03-29-2016, 04:23 PM   #6
MarkJames's Avatar
Rewards Points: 116
MarkJames is offline
Old 03-29-2016, 04:28 PM   #7
MarkJames's Avatar
Rewards Points: 116
Old 03-29-2016, 05:24 PM   #8
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
I'm sure it's great if you live in a part of the world that has incoming water temp of 80 degrees.
They sell UL listed versions within the US...
Inner10 is offline
Speedy Petey (03-29-2016)
Old 03-29-2016, 05:30 PM   #9
480sparky's Avatar
Rewards Points: 18
Originally Posted by rselectric1 View Post
and 60 hz?
Frequency doesn't affect toaster elements.
The Following 2 Users Say Thank You to 480sparky For This Useful Post:
rselectric1 (03-29-2016), Speedy Petey (03-29-2016)
Old 03-30-2016, 11:11 PM   #10
Red Adobe's Avatar
Trade: Metal Roofs, Sparky , Remodels and beer specialist
Rewards Points: 92
Think I'd take a cold shower before steppin under one of these.
Water and power NO BUENO!
I supose for some a little shock might be a good wakeup .
#6 awg, like more like #12 to me
Red Adobe is offline
Old 03-30-2016, 11:16 PM   #11
480sparky's Avatar
Rewards Points: 18
Originally Posted by Red Adobe View Post
.......... Water and power NO BUENO! .......
Then ditch your washing machine, the icemaker in your fridge, garbage disposal, electric water heater, hot tub, sump pump, dishwasher and whirlpool.
Old 03-30-2016, 11:26 PM   #12
back doors to hell put in
Irishslave's Avatar
Rewards Points: 1,314
Has a green ground wire what's the big deal?....Hook it to a GFI breaker in the panel and you're good to go.
Irishslave is offline
Old 03-30-2016, 11:29 PM   #13
480sparky's Avatar
Rewards Points: 18
GFCI's don't need to be grounded to function.
Old 03-30-2016, 11:57 PM   #14
Irishslave's Avatar
But GFI breaker is connected to earth ground in the panel right? at neutral bar which is bonded to cabinet....cabinet is connected to earth ground at least it should be I've seen a few that were not
But I'm guessing if this unit is grounded properly there should not be a problem
We had one of those old jacuzzi motors you pop in your tub and plug into the wall.....no GFCI's in those days
Old 03-30-2016, 11:59 PM   #15
480sparky's Avatar
Rewards Points: 18
GFI protection does NOT need grounding to function. GFCI breakers are not grounded at all (no breakers are). GFCI receptacles are grounded for overcurrent and overload protection and have nothing to do with GFCI protection.
The connection you refer to is not a ground...... it is a neutral. It is there so the GFCI can monitor the line-neutral current.
Irishslave (03-31-2016)
Old 03-31-2016, 12:07 AM   #16
Irishslave's Avatar
So a broken ground can occur at anytime and you'd never know? Forget that shower head then
Old 03-31-2016, 12:12 AM   #17
480sparky's Avatar
Rewards Points: 18
Once again......... the ground has NOTHING to do with the function of a GFCI.
NOTHING.
Old 03-31-2016, 12:17 AM   #18
diplomat
Golden view's Avatar
Rewards Points: 1,550
If you pour a full gallon bucket into an empty gallon bucket, but the new bucket doesn't end up full, do you have to look at the ground to know there was a leak or spill somewhere?
Golden view is offline
Old 03-31-2016, 12:18 AM   #19
Red Adobe's Avatar
Rewards Points: 92
hey Im not standing under the other appliances nekkid....just saying
Old 03-31-2016, 12:19 AM   #20
Irishslave's Avatar
NOTHING.
I get that part I was just fishing for a way to effectively ground a unit like this feeling at least in theory if it's properly grounded it's safe to use
Now if I lose a neutral forget it I ain't gettin anywhere near that shower
Non plumber need to fix leaking shower head. BrooklynBravest Plumbing 15 03-27-2016 05:44 PM
Tub Shower Valve for shower only... Repairman615 Plumbing 6 05-30-2011 02:05 PM
Failed joint at shower head wadswob Plumbing 6 07-06-2008 10:41 PM
