Duplex Apartment House Upgrade - Electrical - Contractor Talk
Old 03-15-2016, 08:57 PM   #1
MarkWG's Avatar
Rewards Points: 6
I have a Apartment house(two side by side apartments)that I am doing 100 Amp service panel upgrade for each Apt. I am looking for some in site on the best way to handle the meters would be. I think my best option for meters is to install a Multi-Position Meter Main like (Milbank U5882X). I priced it ordering from local supply house they are at $320. Would any of you want to share how you would approach this.
MarkWG is offline
Old 03-17-2016, 03:09 PM   #2
Electrical Contractor
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
Re: Duplex Apartment House Upgrade
Sounds like you have it covered. What are you asking?
C'est Moi is offline
The Following User Says Thank You to C'est Moi For This Useful Post:
MarkWG (03-18-2016)
Old 03-17-2016, 03:14 PM   #3
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 14
Is the wiring of both apartments completely separated now?
What local codes will you invoke by installing a new service?
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
MarkWG (03-18-2016)
Old 03-18-2016, 09:05 PM   #4
MarkWG's Avatar
Rewards Points: 6
C'est Moi Looking to learn from some more experienced guys here.
480sparky The two apartments currently have separate meters and separate fused panel boards (being replaced).
Local power co has been contacted. It will be inspected by electrical inspector before new service is powered up. I contacted Building code for the address and work being done, no permit is needed.
Required meter box has to be ring-less and horn bypass or lever bypass.
Left side apartment will travel inside the house over 5 feet to panel board so I need an exterior disconnect.
Right side apartment will travel just 2 feet to panel board so no exterior disconnect is needed.
I looked in the electrical text books I have and they do not cover multi position meter cabinets. So I am looking where I can find more information on application for a duplex apartments.
I did see at least one house that had two 100 Amp entrances hooked into the municipal power and running down the house. This does not seem like a good approach to me.
MarkWG is offline
My after work project. Vinyl siding spec house to Victorian Stick Eastlake pm_sup Construction 25 06-06-2016 11:54 PM
When was this house built??? tjfslaughter General Discussion 36 01-22-2013 09:59 PM
1900's House discovery greg24k General Discussion 9 12-16-2012 07:43 PM
Wet basement, just making sure my thoughts are correct HandicappedHome Excavation & Site Work 7 10-12-2012 06:17 AM
Beach House Mitch M Painting & Finish Work 8 05-01-2011 07:16 PM
