Dishwasher Hookup - Electrical - Contractor Talk
Dishwasher Hookup
Old 01-28-2019, 08:38 PM   #1
dale rex's Avatar
Trade: painting and carpentry
Rewards Points: 187
Dishwasher Hookup
Bought a new dishwasher for my house and the sales person at the appliance store told me that it is now required by code to have a plug and outlet hookup instead of hardwiring the dishwasher. Is this true? If so, do I need to install GFCI outlet under the sink for the dishwasher?
dale rex is offline
Old 01-28-2019, 08:46 PM   #2
Box Builder
Morning Wood's Avatar
Rewards Points: 6
Re: Dishwasher Hookup
If you’re doing it yourself you can do whatever you want. I don’t like to hardwire them. I can’t remember ever seeing a gfci buried inside a cabinet.
Morning Wood is offline
Old 01-28-2019, 08:52 PM   #3
tjbnwi's Avatar
Rewards Points: 246
Must have a disconnect means since 2014, normally a receptacle in the sink cabinet.
2017 NEC 210.8(D) requires GFI for dishwashers.
tjbnwi is offline
dale rex (01-28-2019), Rio (02-11-2019)
Old 01-28-2019, 08:54 PM   #4
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 14
Silly me. I just use a deadfront GFCI above the countertop.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is offline
The Following User Says Thank You to 480sparky For This Useful Post:
Fouthgeneration (01-29-2019)
Old 01-28-2019, 08:57 PM   #5
PCI
PCI's Avatar
Trade: contractor
Rewards Points: 848
Some of the inspectors around here are requiring the gfci to not be buried in the cabinet as it is "not accessible ".
PCI is offline
Old 01-28-2019, 09:06 PM   #6
woodspike's Avatar
Rewards Points: 932
i don`t know if its everywhere , but in south florida, all appliances in the kitchen have to have a plug.
basically , that way , a home owner can replace their own appliance , without having to call a service guy. they can just unplug it , buy and plug in the new one .
never was asked about the receptacle inside the cabinet being g.f.i.
don`t think so , i mean the fridge isn't dishwasher isn't ,
woodspike is offline
Old 01-28-2019, 09:30 PM   #7
rrk's Avatar
Rewards Points: 68
or a lock on the breaker so it can be locked out
rrk is offline
SmallTownGuy (02-12-2019)
Old 01-28-2019, 09:31 PM   #8
rrk's Avatar
Rewards Points: 68
I can just hear the homeowners screaming about that
rrk is offline
Xtrememtnbiker (01-28-2019)
Old 01-28-2019, 09:35 PM   #9
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 108
Here do a duplex mounted in the wall under the sink. One is switched for GD and the other is always hot for the DW to plug in. Both served by a gfci breaker.
Big Johnson is offline
Old 01-28-2019, 09:38 PM   #10
Rewards Points: 108
https://www.lowes.com/pd/Utilitech-S...-Cord/50142346
Old 01-28-2019, 09:57 PM   #11
480sparky's Avatar
Rewards Points: 14
Homeowners scream about everything. If you give one a $100-bill, they'll bitch it's not five 20s.
Old 02-11-2019, 09:34 AM   #12
hack of all trades
dielectricunion's Avatar
Trade: Electrician
Rewards Points: 2,206
I usually run emt up into the sink cabinet to a square box with a switch and a short whip of MC going out to the dishwasher.
I'm not completely sold on this method, the switch might be kind of pointless but if the dishwasher is malfunctioning and you need to shut it fast, it works. Also, I've seen lots of rodent damage on cords and romex cables to dishwashers in the past.
I've never been required to protect dishwasher with gfci here by inspectors but they let a lot slide in this little town.
dielectricunion is offline
Old 02-11-2019, 03:14 PM   #13
Electrical Contractor
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
I'd bitch cause I would want 6- 20's.... or more
C'est Moi is offline
Old 02-11-2019, 05:48 PM   #14
manchesterspark's Avatar
Trade: Electrical
if your adding a receptacle for the dishwasher it will need to be GFCI AND AFCI protected
manchesterspark is offline
Old 02-11-2019, 09:59 PM   #15
hack of all trades
Trade: Electrician
Not necessarily. A lot of jurisdictions are still using older code cycles that don't even require GFCI let alone AFCI on a dishwasher. It doesn't mean you shouldn't protect it if you feel like it's important though.
Old 02-11-2019, 10:05 PM   #16
480sparky's Avatar
Rewards Points: 14
GFCI protection is for receptacles only
AFCI protection is for the entire circuit.
Old 02-12-2019, 06:52 AM   #17
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
I know you know this but gfci is not only for the receptacle but it is required for the dishwasher even if it is direct wired. I think that is what Manchester meant
(D) Kitchen Dishwasher Branch Circuit. GFCI protection
shall be provided for outlets that supply dishwashers installed
in dwelling unit locations.
The Following User Says Thank You to C'est Moi For This Useful Post:
manchesterspark (02-20-2019)
Old 02-12-2019, 08:04 AM   #18
rrk's Avatar
Rewards Points: 68
We just change the breaker to gfci and install a lockout, makes for a much neater install.
rrk is offline
Old 02-12-2019, 09:32 AM   #19
tjbnwi's Avatar
Rewards Points: 246
By definition, the connection is still made at an outlet on a direct wire install.
tjbnwi is offline
Old 02-12-2019, 09:34 AM   #20
tjbnwi's Avatar
Rewards Points: 246
I believe if you're adding any single pole 15 or 20 amp circuit under the last few NEC code cycles they have to be AFCI protected. If it is an existing circuit you do not have to add the AFCI only the GFCI.
Local amendments may change the requirements.
tjbnwi is offline
Giveaway! Enter To Win Kenmore Built-In Dishwasher! Cricket General Discussion 61 04-12-2016 05:15 PM
Tiled In Dishwasher Kowboy General Discussion 2 01-20-2013 01:20 AM
Dishwasher in my own home Cjeff Plumbing 25 12-16-2011 09:12 PM
2 dishwasher hookup, one drain CGallagher Plumbing 7 03-24-2011 05:25 PM
Dishwasher recall - please read and forward on to others SuperiorBuilt General Discussion 2 03-17-2008 01:37 PM
