Diagnosing A Bad Outlet On A GFI Circuit - Electrical - Contractor Talk
Old 06-11-2010, 07:25 PM   #1
Duck042's Avatar
Rewards Points: 75
I have 5 outlets on a GFI circuit, two of which are actual GFI outlets (i.e., they have the Test and Reset buttons) and the other three are regular outlets.
I've run into dead GFI outlets before, but this time the two GFI outlets are fine, both test and reset properly. It appears one of the other three is intermittently tripping one or both of the GFI outlets, even though none of the 3 outlets have anything plugged into them.
All the outlets have been in place for some time, so no recent event causing the failures, which is why I think it's one of the outlets dying naturally. Any quick way to figure out which regular outlet is dying without just trying to replace each in turn?
TIA!
"Trees cause more pollution than automobiles do." -- Ronald Reagan, 1981
Duck042 is offline
Old 06-11-2010, 07:30 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2
Re: Diagnosing A Bad Outlet On A GFI Circuit
If it's an intermittent, the only quick way is luck.
Do you have one GFCI being fed by another GFCI?
Tinstaafl is online now
rselectric1 (06-11-2010)
Old 06-11-2010, 07:34 PM   #3
rselectric1's Avatar
Rewards Points: 926
Are the standard receptacles loaded on one of the gfci receptacles?
rselectric1 is offline
Old 06-11-2010, 07:36 PM   #4
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 18
Just three receps? Wow. That'll cost you about $1.47+tax down at the hardware store to buy new ones. Swap 'em all out and see if that solves the problem.
While you're in each box, check for moisture, corrosion and nicked insulation.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
Old 06-11-2010, 07:53 PM   #5
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
X2, check that the ground is not intermittenly touching the line too. I have seen this several times when the recepticle was installed and the wires got crammed inside the box. Is it a steel box? Be sure the recepticle mounting screw is not rubbing on the line side, seen that too.
woodchuck2 is offline
Old 06-11-2010, 08:02 PM   #6
Duck042's Avatar
Rewards Points: 75
Thanks for the quick responses, guys.
I don't know if the load of the first GFI is feeding the other GFI, I'll have to check tomorrow. If it is, should I feed the second from the Line terminal of the first?
Would it cause false trips otherwise?
EDIT: I'll have to pull the cover to check for sure, but I'll bet all the other receptacles, including the second GFI, are all fed by the Load side of the first GFI.
Duck042 is offline
Old 06-11-2010, 08:05 PM   #7
480sparky's Avatar
Rewards Points: 18
Depends on how they're wired to begin with. It's not illegal to protect a GFI with another GFI, but not a good design.
When the one GFI trips, check to make sure you know what all goes dead. Then troubleshoot just that part of it.
Old 06-11-2010, 08:18 PM   #8
Duck042's Avatar
Rewards Points: 75
I've seen multiple GFI outlets on the same circuit in a lot of cases, including new construction. I assumed they did it intentionally for redundancy. What's the downside of having two GFI outlets on the same circuit, do they interfere with each other?
Duck042 is offline
Old 06-11-2010, 08:37 PM   #9
480sparky's Avatar
Rewards Points: 18
Not really. But it can make finding the offending GFI difficult. Most people don't wire them that way, so power goes out, you check the GFI you're plugged into, it's still on, so you naturally go the the panel.
Three hours later, you find a GFI in the middle of the run tripped.
Old 06-13-2010, 12:35 AM   #10
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,394
Easy way to test that is to pull out the GFI you think is tripping the other ones and twist the wires together to bypass it. If they stop tripping, you were right.
Are GFI's wired correctly? If they are miss-wired they will pop. I use Leviton GFI's, they are easy to wire, it says where to put everything on it. Supply power goes to the bottom two screws, load line on the top two.
KennMacMoragh is offline
Old 06-13-2010, 11:11 AM   #11
John Valdes's Avatar
Trade: Electrical
Rewards Points: 146
All GFCI's are labeled as far as connections go. It is silly and expensive to use more than one GFCI on a circuit. Silly.
John Valdes is offline
Old 06-22-2010, 07:36 PM   #12
Duck042's Avatar
Rewards Points: 75
So, as usual, the source of the problem wasn't what I initially thought. On the same circuit as the bathroom GFI's was an outdoor outlet (nearly invisible between two bushes, naturally ).
When I pulled out the receptacle, the backstab clip holding the hot wire gave way in my hand, yelling "free at last, free at last!"
Deoxed the wires, tightened them securely the side screws of a new receptacle - problem solved...
Duck042 is offline
Old 06-22-2010, 07:47 PM   #13
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2
Always great to hear the rest of the story.
Now waddle quietly away so you don't have to hear us telling you that violates code.
Old 06-22-2010, 10:23 PM   #14
480sparky's Avatar
Rewards Points: 18
Originally Posted by Tinstaafl View Post
...............Now waddle quietly away so you don't have to hear us telling you that violates code.
If it was wired prior to the adoption of the 1999 NEC, it's perfectly legal.
Old 06-22-2010, 10:38 PM   #15
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2
Depends on what the job was. My AHJ says "You touched it, you fix it."
Old 06-22-2010, 10:41 PM   #16
480sparky's Avatar
Rewards Points: 18
Replacing a bad GCI should not warrant a complete rewire. Otherwise, people would be completely rewiring their houses every 3 years.
Old 06-22-2010, 10:53 PM   #17
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2
Agreed, but [slaps ruler!] pay attention. I said "Depends on what the job was."
Granted that the Duck didn't mention doing so, but if I modify (as opposed to just repairing) the circuit, I have to bring it up to code.
mrmike (06-23-2010)
Old 06-23-2010, 01:23 PM   #18
Duck042's Avatar
Rewards Points: 75
Didn't touch the wiring at all, in fact.
The only reason I got sucked into this initially was because I thought I introduced the problem when I took the faceplate off one of the bathroom GFI's to put in a new backsplash. The clip in the receptacle chose that day to give up the ghost, evidently.
Btw - what do you all think of the backstab-type receptacles?
Duck042 is offline
Old 06-23-2010, 01:29 PM   #19
480sparky's Avatar
Rewards Points: 18
.............Btw - what do you all think of the backstab-type receptacles?
They suck.
But because of all the others who use them, I love 'em. Keep using them, guys..... I make a lot of money on service calls!
Old 06-23-2010, 01:33 PM   #20
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2
They suck.
Oh. Somebody already said that.
Adding external controller and pump to water heater circuit? protechplumbing Electrical 5 05-12-2010 11:31 PM
Flat Panel TV - Power Outlet Issues gury Electrical 23 12-26-2008 03:58 PM
Dead Outlet, Circuit LNG24 Electrical 32 11-07-2008 06:35 PM
New Basement Circuit dcapone Electrical Picture Post 16 09-30-2008 03:13 PM
Need help with 240 circuit Elast Electrical 6 10-19-2007 03:03 PM
