Depth To Bury Wire For Post Lamp - Electrical - Contractor Talk
Old 05-13-2015, 11:21 PM   #1
improving homes
platinumLLC's Avatar
Trade: Roofing/Remodeling
Rewards Points: 354
I was on a job today and saw the electrician installing a post lamp light. He was using direct burial UF wire from the house to post lamp. All he did was stick his shovel in 4-6 inches and lift the ground up and slip the wire in the hole and then take the shovel out and stomp the ground back down. I'm not an electrician so don't have a clue but 4-6 inches seems like it should be buried deeper so someone doesn't cut it planting flowers. What is the code for how deep UF wires need to be buried to post lamps?
Also, should a post lamp be set in concrete or just in dirt? I went out after he left and it was really loose, as in I could wiggle it very easy. He just piled the dirt back in around it. Just seemed like an all around hack install and I've never even put one in. Just wondering if he was a hack or if what he did is alright?
platinumLLC is offline
Old 05-13-2015, 11:26 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 60
Re: Depth To Bury Wire For Post Lamp
Minimum 24" buried.
Post Lamp needs to be set in concrete or bolted to concrete.
griz is offline
greg24k (05-14-2015)
Old 05-13-2015, 11:46 PM   #3
improving homes
Rewards Points: 354
Originally Posted by griz View Post
Minimum 24" buried.
This guy missed that by a lot. Wow. Wire is 6" at the most and post is just set in hole with dirt piled back in, not even tamped down. I'm going to mention something to the home owner tomorrow, feel sorry for them paying for that kind of work.
So 24" depth is NEC code? Also the concrete is NEC code? Just so I can be sure I'm telling the HO the truth.
Old 05-14-2015, 05:09 AM   #4
Box Builder
Morning Wood's Avatar
Rewards Points: 6
24" for a piece of wire. I wouldn't bother. 6" is definitely not enough. 12" would probably be safe enough. Is the lamp post wood? He probably doesn't have much knowledge on hand tamping and tightening a post. Done right it can be made very tight.
Morning Wood is offline
Old 05-14-2015, 05:21 AM   #5
General Contractor
greg24k's Avatar
Rewards Points: 26
What others said, open wiring not in conduit should be buried at least 24" below the surface and wiring in plastic conduit is 18" below the surface.
greg24k is offline
Old 05-14-2015, 05:57 AM   #6
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Around here 6-10" seems normal for 110v lines to lights and stuff.
Gas lines are anything from 1-2'
Main power coming in is about 3'
Cable and telephone about 3"-6"
Low voltage about 3"-6"
Gas lines are what get me. Some are so close to surface it's crazy.
www.bcconstructionllc.com
BCConstruction is offline
Old 05-14-2015, 06:56 AM   #7
Michael217's Avatar
Trade: Licensed Electrical Contractor
Rewards Points: 198
Could be only 12" if the circuit is 120 volts or less and is GFCI protected and 20amps or less.
No NEC requirements on how the post is installed.
300.5 NEC, 2014 cycle
Michael217 is offline
The Following User Says Thank You to Michael217 For This Useful Post:
C'est Moi (06-06-2015)
Old 05-14-2015, 07:09 AM   #8
deter's Avatar
Trade: Project Managment & hack-of-all-trades
Rewards Points: 44
sadly 99 out of 100 post lights are installed exactly the way described in the OP. I've actually seen electricians run the wire directly on top of the dirt (rough-grade) assuming that someone else will bury it.
deter is offline
Old 05-14-2015, 08:45 AM   #9
GettingBy's Avatar
Rewards Points: 6,486
Seems to me there is supposed to be some kind of plate over the wire so a shovel would hit this barrier before hitting the wire. One of Ray Mullin's books might have said this.
GettingBy is offline
Old 05-14-2015, 10:52 AM   #10
cwatbay's Avatar
Trade: Electrical Contractor
Rewards Points: 2,570
This is correct. Although I personally have my firm bury conduit at 18 inch no matter the amps (residential).
This whole thing sounds like craigs list hack work to me, and, if this was a licensed electrician, someone should yank his license ASAP.
I have seen 20amp 120vac direct burial romex (UF-B) running to light poles via the expansion cracks in concrete walkways at an auto dealership. Nothing much surprises me anymore. I also lost the bid on this job cus I was going to bore under the walkways to run conduit.
cwatbay is offline
Old 05-14-2015, 11:20 AM   #11
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 226
Where do you get so much mis-information from??
Delta
TxElectrician (05-18-2015)
Old 05-14-2015, 11:38 AM   #12
rrk's Avatar
Rewards Points: 174
Delta
His 2 not 1 but 2 degrees.
rrk is online now
Old 05-14-2015, 12:39 PM   #13
GettingBy's Avatar
Delta
I think it was this guy
http://www.amazon.com/Electrical-Wir.../dp/1435498267
It doesn't seem that different from using nailing plates and I'd think you could go less deep if you use rot-resistant protective boards.
It seems I will never be forgiven for my two degrees (not just one) but on the bright side it might distract people from my offensive personality.
Old 05-14-2015, 01:17 PM   #14
avenge's Avatar
Rewards Points: 362
I always run underground wire in conduit.
avenge is offline
Old 05-14-2015, 01:18 PM   #15
avenge's Avatar
Rewards Points: 362
I always run underground wire in conduit and post in concrete.
Evidently I do it twice.
avenge is offline
Old 05-14-2015, 02:27 PM   #16
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
If it's a low voltage light that's kosher.
Inner10 is offline
Red Adobe (05-28-2015)
Old 05-14-2015, 02:56 PM   #17
Trade: Highwayman
Rewards Points: 226
Yeah, that's how I do it.
I did a big commercial job, with 28 lamp posts, about 6000 feet total.
The electrical portion wasn't so bad, but the steel plates in the ground really ran the price up.
Delta
Old 05-14-2015, 07:58 PM   #18
GettingBy's Avatar
Delta
This could be a straw man argument. I'm getting better at spotting them.
If it's any consolation, less than a half percent of my last degree is still relevant today.
Old 05-14-2015, 08:08 PM   #19
rrk's Avatar
Rewards Points: 174
much less
rrk is online now
Old 05-14-2015, 08:11 PM   #20
GettingBy's Avatar
Originally Posted by rrk View Post
much less
On this forum its value may run into negative numbers.
Bury the posts? ckseppa General Discussion 22 04-17-2013 11:28 PM
Finding break in boundary wire mpt1123 Low Voltage 3 05-21-2012 06:46 PM
Wire Transfer? DaVinciRemodel Business 2 11-29-2011 04:23 PM
3-way wiring- ceiling fan with remote for two-wire hookup hevnbnd Electrical 29 08-17-2009 10:28 PM
safe hot wire driver Electrical 13 05-12-2006 10:18 PM
