DC AmProbe - Electrical - Contractor Talk
DC AmProbe
Old 05-25-2010, 03:45 PM   #1
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
DC AmProbe
Learned something new yesterday;
My truck lately has been a bit hard to start in the mornings, giving the typical "lug-lug-lug" sound before starting up, even though my battery is just a year old.
I put my inexpensive model of Fluke around the ground to see if there was current leaking while the truck was off. I saw nothing, but to test the idea I flipped on the headlights while watching the meter. The meter jumped instantly, then just as fast read zero again.
I scratched my head and realized my amprobe only see fluctuations in current such as with AC.
With DC it only sees the initial rush of current and while the current is steady it cannot see it.
I found it somewhat interesting, and am now curious if there is an amprobe out there (perhaps someone out there owns) that will read DC?
About the truck; I dug out my old Radio Shack analog meter and found out nothing about the truck because I got too busy playing with the meter and eventually burned the fuse out.
Joe
Sparky Joe is offline
Old 05-25-2010, 06:04 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 13,036
Re: DC AmProbe
Fluke, Amprobe, UEI, and GB, et al, all make what you're looking for.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
Old 05-25-2010, 10:53 PM   #3
Kgmz's Avatar
Re: DC AmProbe
I bought one just for use with my motorhome. Nice to know how many amps something is drawing so you can determine how long the batteries will last, etc. since we normally dry camp with ours with no hook ups.
I got a alert from the RV forums a few years back on one at Sears that was on closeout for $29, and that little meter actually works great and is accurate. I have compared it with the several meters I have collected throught years, Fluke, Amprobe, UEI, etc. and it reads within less than 1% of them on AC. Don't know who makes them for Sears.
Here is a link to the newer version at Sears for $59.
http://www.sears.com/shc/s/p_10153_1...2369000P?mv=rr
Kgmz is offline
Old 05-27-2010, 07:23 AM   #4
s.kelly's Avatar
Trade: electrician
Rewards Points: 150
Re: DC AmProbe
I have a clip on analog meter that is made just for battery and starter draw measurements. Cannot remember where I got it, but it must have been either an auto parts shop or a tool truck. When I get out to the garage I'll try and see if it has a name on it. I am sure it was cheap, only used it once or twice, but nice to have when you need it.
It is about the size of a credit card, and about 1/2"thick.
Have also used a meter with DC for trouble shooting like 480 describes. As an electrician you may find other uses so a more versatile meter might be more the ticket. I was not an electrician when I got mine so I was too cheap to get a real meter with the DC probe.
s.kelly is offline
Old 05-28-2010, 03:08 PM   #5
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
Re: DC AmProbe
I was a mechanic for a GM dealer and for a Chrysler dealer so i have spent some coin on meters but believe it or not i never bought a fluke. I have always wanted a fluke but coudnt see spending the money. I did buy an off brand "cant remember the name" clip on digital meter that could read amp draw up to 200amps for ac and dc and this i used several times checking car alternators and amp draw on starters. The dealers also had equipment too but sometimes it wasnt worth waiting for when there were 13-15 other guys trying to use it. I also use this meter for adjusting the hertz settings on generators. In all i have around 8 meters, i keep one in each truck, a couple in the trailer, one at home, one at my other house which i run my business out of and a couple in my mechanics tool box.
woodchuck2 is offline
Old 05-28-2010, 04:43 PM   #6
CE1's Avatar
Trade: Electrical
Re: DC AmProbe
Joe
Here is an old one..... AC or DC
CE1 is offline
Old 05-28-2010, 05:22 PM   #7
480sparky's Avatar
Re: DC AmProbe
Instead of buying a high-$ meter, why not pay your electrician to come over and take a reading with his high-$ meter?
Old 05-29-2010, 09:20 AM   #8
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 24
Re: DC AmProbe
Originally Posted by 480sparky View Post
Instead of buying a high-$ meter, why not pay your high-$ electrician to come over and take a reading with his high-$ meter?
Fixed it for ya.
Tinstaafl is online now
Old 05-29-2010, 07:07 PM   #9
Moderator
Double-A's Avatar
Rewards Points: 2,000
Re: DC AmProbe
The electrician we use is old school. He calibrates his tongue with a 9V battery and then just licks the post or bare wire to check amperes. He's only been wrong twice, and that was because he was laying unconscious, with his tongue smoking.
New York Times, July 20, 2006
Double-A is offline
Old 06-11-2010, 05:32 AM   #10
mikhen's Avatar
Trade: Solar Electrician
Re: DC AmProbe
We use Fluke 336 at work to check our solar panels. They measure constant amps on DC.
mikhen is offline
Wire tracer info PAterminator Electrical 18 09-30-2007 08:07 AM
