Conduit Requirements In A Flood Plain - Electrical - Contractor Talk
Old 10-24-2012, 12:59 PM   #1
cwatbay's Avatar
Trade: Electrical Contractor
Rewards Points: 2,434
Help. I have to have an answer today, unfortunately, but that also means I am going to charge more.
The question is: Are there any special requirements for running Schedule 40 or 80 conduit, buried at NEC Code @ 18" below grade for electrical. The low voltage I am not worried about, but the 120vac single phase I am.
Anyone have an idea. Thanks.
cwatbay is offline
Old 10-24-2012, 01:14 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 11,706
Re: Conduit Requirements In A Flood Plain
Nothing I know in the NEC that addresses flood plains.
18" below grade.... that may or may not be legal, depending on the installation.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
cwatbay (10-25-2012)
Old 10-24-2012, 01:34 PM   #3
cwatbay's Avatar
Well, that is good about NEC, saved me a lot of time trying to look it up. 18 inch below grade is per NEC for PVC conduit, at least around here, where they really go by code. I can always go down to 24 inches just to play it safe.
I am guessing that the local jurisdiction may have an answer, but this project is in Puerto Rico and I have no clue.
Maybe some contractors that have had to install conduit and electrical in flood plains around here may have an answer.
cwatbay is offline
Old 10-24-2012, 08:46 PM   #4
jack of all trades
one man show's Avatar
Trade: general
Rewards Points: 75
all equipment electrical, mechanical even any openings into a plubming system are to stay one foot above highest flood elevation
i guess if the local utility only supplies underground feeders that would be on them. they own the service entrance conductors untill it hits your bussing
one man show is offline
The Following User Says Thank You to one man show For This Useful Post:
Old 10-25-2012, 07:53 AM   #5
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 3,068
Code reference?
TxElectrician is offline
Old 10-25-2012, 10:40 AM   #6
Kgmz's Avatar
Originally Posted by TxElectrician View Post
Code reference?
682.2 Electrical Datum Plane (3)
Also in Fema rules and local flood plain rules.
Kgmz is offline
The Following 2 Users Say Thank You to Kgmz For This Useful Post:
cwatbay (10-25-2012), TxElectrician (10-26-2012)
Old 10-25-2012, 11:38 PM   #7
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
Hmmmm, i just did a service 2yrs ago where i had to put trees down on the marsh to keep my mini-ex on top of the mud right next to a swamp. Hole filled with water when i set the pole, the whole ditch was full of water when i dropped the conduit in with the service wire already inside. Inspector told me everything looked fine but he wasnt walking through the mud to put the sticker on the meter socket, he left that to me. Wonder if that falls under flood plain?
woodchuck2 is offline
Old 10-26-2012, 11:07 AM   #8
jack of all trades
Trade: general
Rewards Points: 75
Ground water
Why is wood rotting ? SKC Construction 47 05-27-2018 04:50 PM
Steel Conduit, equipment grounding q? HandicappedHome Electrical 36 08-27-2012 08:28 PM
Flood Plain Bill Z General Discussion 3 04-04-2007 07:01 PM
Mono or stem wall Fl. flood plain Framer33884 Masonry 2 04-08-2006 04:31 PM
Removing old wiring from conduit duke Electrical 3 01-29-2006 11:04 PM
