Checking Wiring Integrity - Page 2 - Electrical - Contractor Talk
Old 05-21-2015, 08:46 PM   #21
hdavis's Avatar
Rewards Points: 2,252
Re: Checking Wiring Integrity
Originally Posted by GettingBy View Post
I doubt that even a TDR unit could find this.
The nick is a high resistance area but of almost zero length
TDRs pick up sudden impedance changes. I don't think any are made specifically to pick up this situation.
hdavis is online now
Old 05-21-2015, 11:41 PM   #22
back doors to hell put in
Irishslave's Avatar
Rewards Points: 1,314
Thanks a lot davis ......now you have me thinking.....I have a few issues here at home...I got a bad traveler in a 3-way......couple of burn marks on a few recepticles......a sometimes I get a good spark when plugging stuff in......What would cause this?.....Plus there's some "homie" add ons here when I bought the house
Irishslave is offline
Old 05-22-2015, 08:52 AM   #23
hdavis's Avatar
Outlets are cheap. By the time you pull one to check it out, you may as well put a new one in. You can get sparking from plugging something in that's on - that's normal. I've seen outlets that were installed poorly and left loose - wiggle them and you can short and trip a breaker. Or, the receptacle could be worn so it doesn't make good contact with the plug all the time. Even a "small" problem is cause for concern,because insulation can eventually cook or a conductor can oxidize and that makes it something of a time bomb.
I'd just replace the outlets and get after what's happening with the 3 way. Just hope it isn't rodent damage - that can mean a much bigger problem.
Irishslave (05-22-2015)
Old 05-22-2015, 09:30 AM   #24
Champion Thread Derailer
Jeff G's Avatar
Trade: Home Renovations
Rewards Points: 380
This thing should pay for itself quickly
http://www.idealind.com/media/pdfs/p...structions.pdf
Yeah, that one is around $100 more than the one I purchased, and it has exactly the same functions as the Extech analyzer I have. I have used mine extensively to find problems (loose connections, faulty wiring, nail/screws in nm cable, faulty GFCI outlets, etc) and make things much safer for any and all occupants. If more folks had this tool, I honestly believe there would be fewer house fires due to electrical issues.
Jeff G is offline
Old 05-29-2015, 06:34 PM   #25
senorfish's Avatar
Trade: lighting design
Rewards Points: 36
How about swapping out all your breakers to arc faults? I did that for the whole house, not just bedrooms, and I sleep well at night. They can be had on ebay for about $25 a piece when bought in bulk.
senorfish is offline
The Following User Says Thank You to senorfish For This Useful Post:
hdavis (05-29-2015)
Old 06-04-2015, 04:16 PM   #26
GettingBy's Avatar
Rewards Points: 6,486
Watch for nuisance tripping if you live near radio transmitters. They may send you a filter if you report this problem.
For troubleshooting, Siemens makes a device to do this.
GettingBy is offline
Old 06-11-2015, 12:35 AM   #27
Emma Taylor
sparrow4's Avatar
Trade: Electrician
Rewards Points: 4
The only test you can do at this time is an insulation resistance test, which that is accomplished by applying voltage for a certain amount of time to the wire, but a normal volt meter is not a right tool for that. Technically, it is a form of destructive testing. I recommend you to discuss your problem with some Electrician professionals.
sparrow4 is offline
Todays wiring rotarex Electrical 11 06-15-2013 03:41 PM
Restocking takes a bite outta the checking account pinwheel Flooring 34 06-10-2013 08:32 PM
Weird wiring numbers on a ceiling fan? DemRem Electrical 15 04-17-2013 01:34 AM
Explanation for wiring? CarpenterSFO Electrical 42 04-05-2013 10:50 AM
