Ceiling Fan Light Won't Go On - Electrical - Contractor Talk
Old 07-15-2010, 09:41 PM   #1
Home remodeling
jhcontracting's Avatar
Trade: home remodeling
Rewards Points: 157
I need some help:
I am Doing some work for a couple who are moving in to this house. One of the items is that the light on the ceiling fan doesn't work. I looked at the switch and found the following: They had a double switch hooked up to it, but both switches were linked together, similar to a wall outlet receptacle. When you turned either switch on the fan would come on. But no light, and the fan would go only one speed. I put in a fan/light set of switches and I still can't get the light to go on. In addition, the fan will run only two speeds slow and medium. the wiring in the switch box is as follows, a 12/2 with ground which is the power(I checked and had 120v on it) and a 12/3 with ground which I assume is going to the fan. The fan itself doesn't have any pull chains for the light or the fan. Just a reverse switch for the fan. the fan does have a blue wire and a white wire that the light kit is plugged into. And it does have a tag on them that says for light. Any suggestions.
Thanks
jhcontracting is offline
Old 07-15-2010, 09:44 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,238
Re: Ceiling Fan Light Won't Go On
Call an electrician.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
Electricmanscot (07-16-2010)
Old 07-15-2010, 09:59 PM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 342
Not to be unkind, I have to concur with 480sparky. You haven't given us enough information to diagnose the problem, and worse yet, you assume that the wire you see is going to the fan/light in question.
Rudimentary troubleshooting gets rid of assumptions, proves what actually is, and what's left is the solution to the problem. An electrician, or to be honest a reasonably skilled handyman, could work this one out before he's finished his first cup of coffee in the morning.
And after a year and a half of membership, you still haven't put your location in your profile.
Tinstaafl is offline
Old 07-15-2010, 10:01 PM   #4
Wood Butcher
bhock's Avatar
Trade: Remodels/Custom Cabinets/Granite Countertops
Simple question...is there a remote for the fan?
bhock is offline
Old 07-16-2010, 01:12 AM   #5
avguy's Avatar
Trade: A/V, Renovation
Rewards Points: 250
Get the model number of the fan and find the manual or call the manufacturer.
Philip LaDue
Empire State Light and Sound
646-397-5028
avguy is offline
Old 07-16-2010, 11:07 AM   #6
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
Quick things for you to try, one is pull the chain for the light to see if it is on or off, second is turn the wall switch on for the fan and then pull the chain for the fan to reset it to the high speed. The high speed is the first pull of the chain after a pull of the chain turns it off. Once the high speed is set by the chain the all the speeds from the wall switch should work. Beyond that call an Electrician.
woodchuck2 is offline
Old 07-16-2010, 11:10 AM   #7
480sparky's Avatar
Uh................
Originally Posted by jhcontracting View Post
........ The fan itself doesn't have any pull chains for the light or the fan. ...............
Old 07-16-2010, 11:28 AM   #8
Project Manager HFH..
JumboJack's Avatar
Rewards Points: 2,004
IMO a ceiling fan is pretty basic stuff.If one can't wrap their brain around how to trouble shoot a problem with one then it is time to call a sparkie.
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber
JumboJack is offline
Old 07-16-2010, 11:55 AM   #9
Remodeling GC
kevjob's Avatar
Rewards Points: 392
did you check the bulb? cant tell you how many times my sparkie puts a fan in HO puts dead bulb and we get a call, 75.00 later and new bulb, problem fixed.
kevjob is offline
Old 07-16-2010, 04:34 PM   #10
Head Grunt
woodchuck2's Avatar
Thanks for the correction 480, i did not catch that in his original post.
Old 07-16-2010, 10:15 PM   #11
#1 stunner
Static Design's Avatar
Trade: Design/Build
Call a handyman.......
Will do autocad/ 3d work for food.
SD on facebook... click here
Static Design is offline
Old 07-17-2010, 08:22 PM   #12
pulpfiction32's Avatar
Trade: Electrician
Rewards Points: 75
take apart the canopy and make sure the blue wire is attached to another wire. when you open the canopy if you find something with dip switches on it its time to look for the remote
pulpfiction32 is offline
3-way wiring- ceiling fan with remote for two-wire hookup hevnbnd Electrical 29 08-17-2009 10:28 PM
Raising ceiling joists lou94stang Framing 10 05-27-2009 09:46 PM
Leaky Roof & Cool Light Globe dougchips Off Topic (Non Trade) 4 01-28-2009 12:05 AM
How many forum posters does it take to change a light bulb? woodbutchr Off Topic (Non Trade) 15 01-22-2009 08:16 AM
Suspended Ceiling Costs ?? SBI Drywall 4 08-22-2008 09:50 AM
