Carpenter Has Electrical Question - Electrical - Contractor Talk
Old 12-29-2013, 03:48 PM   #1
Localday's Avatar
Trade: General contractor
Rewards Points: 75
I'M a carpenter not an electrician, not wanting to bother my electrician on Sunday here goes, I wanna run a circuit in my basement for two freezers, I have some 12-2 and a couple receptacles, can i run both freezers on one circuit? I may put a fridge down there some day too. What size breaker or breakers do I need? The box is a cutler-hammer, thanks
Localday is offline
Old 12-29-2013, 04:07 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,316
Re: Carpenter Has Electrical Question
Maybe.
20.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
CarpenterSFO (12-29-2013)
Old 12-29-2013, 04:41 PM   #3
plazaman's Avatar
Rewards Points: 1,254
Careful how you exact questions on here not pertaining to your trade. The tradesman get offended and feel you are taking away jobs from them
plazaman is offline
The Following User Says Thank You to plazaman For This Useful Post:
slowsol (12-29-2013)
Old 12-29-2013, 04:52 PM   #4
Wood Craftsman
PrestigeR&D's Avatar
Rewards Points: 4,642
Arrow
Those days are gone.........
When you have Internet ,......"the information superhighway"
http://www.csgnetwork.com/wiresizecalc.html
http://m.wikihow.com/Determine-Amper...ircuit-Breaker
Punch it in, spit out an answer.....
And yet we still get rudimentary questions....
Just saying.....
B,
PrestigeR&D is offline
Old 12-29-2013, 04:56 PM   #5
480sparky's Avatar
All I can see is how much I can make when I go to his house and find two freezers and a fridge all on one 20a circuit and I get to charge fixing the problem of a constantly-tripping breaker.
cwatbay (01-03-2014)
Old 12-29-2013, 05:28 PM   #6
Electrical Punk...
HARRY304E's Avatar
Trade: Master Electrician
Rewards Points: 572
Before the entire block vaporises......
"A Time For Choosing"
HARRY304E is offline
Old 12-29-2013, 05:32 PM   #7
larry228's Avatar
Trade: residential remodeling
Rewards Points: 8
it seems a false economy to put two essential appliances on one circuit. the cost to sun two dedicated circuits has to be less than the potential loss when the breaker trips and two freezers full of food thaw out.
larry228 is offline
Old 12-29-2013, 05:36 PM   #8
Wood Craftsman
Question
Iowa to Illinois ...... gas..........you would really travel that far .......
For this,.......
B,
Old 12-29-2013, 05:42 PM   #9
90%-er
onmywayup's Avatar
Rewards Points: 2,236
Jesus fellas....a simple 'no' would probably have sufficed.
Maybe even, 'no,' and 'let me explain why since you're trying to learn,' if you had a little extra time
onmywayup is offline
The Following 6 Users Say Thank You to onmywayup For This Useful Post:
Adamsmith007 (12-29-2013), Doctor Handyman (12-30-2013), kiteman (12-29-2013), maxwage (12-29-2013), pinwheel (12-30-2013), slowsol (12-29-2013)
Old 12-29-2013, 05:52 PM   #10
480sparky's Avatar
For this,.......
B,
I'd just sub it out to Ron.......
PrestigeR&D (12-29-2013)
Old 12-29-2013, 06:30 PM   #11
Wood Craftsman
Thumbs up
Oh that was good!"..........
B,
Old 12-29-2013, 06:55 PM   #12
480sparky's Avatar
B,
Then I could take the dollar Leo still owes me out of Ron's check and let Ron chase it instead of me.
Old 12-29-2013, 07:50 PM   #13
diplomat
Golden view's Avatar
Rewards Points: 704
Maybe is a good answer. I see a lot of new fridges and freezers with amp ratings of under 4. So if they're all new, 12 amps total running. Maybe 80 amps momentary starting inrush if they all start at the exact same moment, which also probably won't trip a 20a breaker. Right 480?
Golden view is offline
Old 12-29-2013, 09:04 PM   #14
mstrat's Avatar
Trade: New Construction & Remodeling
Rewards Points: 1,520
Run 2 separate breakers...you'll feel better about your world!
mstrat is offline
Old 12-29-2013, 09:08 PM   #15
Interior Remodeling
Eric K's Avatar
Trade: Interior Remodeling
Rewards Points: 570
I'd run 2 separate circuits. Since you have 12/2 already just use it. 20amp breakers. Make sure your using 20amp recepticles also. Your better to be safe than sorry with electrical. You only want to use 80% of the load capacity of circuit. Can't go wrong over killing it.
Edit
Eric K is offline
Old 12-29-2013, 09:10 PM   #16
480sparky's Avatar
Originally Posted by Eric K View Post
....Make sure your using 20 recepticles also. ....
Why?
The Following 2 Users Say Thank You to 480sparky For This Useful Post:
jproffer (12-30-2013), WarriorWithWood (01-04-2014)
Old 12-29-2013, 09:13 PM   #17
Interior Remodeling
Eric K's Avatar
Rewards Points: 570
Why?
20amp*
-also take my advice as a carpenter with electrical expirence. Not licensed. "20 recepticles" probably not the best idea.
Eric K is offline
Old 12-30-2013, 06:01 AM   #18
Repair/Remodeling Tech.
jproffer's Avatar
Trade: Repair and Remodeling Services
Rewards Points: 180
20amp*
In this case it's not necessary, but in general there's no rule against putting 20 receptacles on a circuit....or 200....or 2000 for that matter. (and they can all be 15A receptacles, BTW. )
Jim P.
jproffer is online now
Old 12-30-2013, 07:14 AM   #19
Interior Remodeling
Eric K's Avatar
Rewards Points: 570
Not sure if its code or not. But I had an inspector make me change a 15a receptacle to a 20a on a 20a circuit. If you plug an electric heater that pulls more than 15 the receptacle could fail. Unlikely it would, but could.
Eric K is offline
Old 12-30-2013, 07:39 AM   #20
480sparky's Avatar
Show me a resi heater with a 20 amp cord cap.
New? Have A Question? Read This First. Seven-Delta-FortyOne General Discussion 58 07-31-2019 02:46 AM
victoria: carpenters apprentice looking for carpenter jimwalter Help Wanted or Looking For Work 0 09-16-2012 05:16 PM
Foil tape question from a carpenter... Jeremy E HVAC 6 12-26-2008 09:52 PM
electrical insurance question roo Electrical 4 04-25-2008 06:09 PM
Question regarding surplus electrical material solcam Electrical 2 07-25-2006 05:31 PM
