Can I Bend PVC Conduit With Wires Inside? - Electrical - Contractor Talk
Old 08-03-2020, 09:16 AM   #1
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 1,558
I have a conduit right in the way of a drain I have to install, it's already wired and everything is installed.
Can I safely hit it with a heat gun to bend it a few inches out of the way?
NYCB is offline
Old 08-03-2020, 11:23 AM   #2
rrk's Avatar
Rewards Points: 18
Re: Can I Bend PVC Conduit With Wires Inside?
I have seen an electrician do it during a pool install, he bent it more than a little bit with a heat gun. Did it like it was no big deal, I know it was not real hot because less than a minute later he touched it with his hand.
rrk is online now
Old 08-03-2020, 11:38 AM   #3
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 13,024
No.
But you're going to do it anyway.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is offline
Old 08-03-2020, 03:43 PM   #4
NYCB's Avatar
Ironically, this is under a pool deck.
NYCB is offline
The Following User Says Thank You to NYCB For This Useful Post:
rrk (08-03-2020)
Old 08-03-2020, 05:52 PM   #5
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 552
I hope so, I just did the same thing a couple weeks ago.
Same deal, was the electric line running out to the pool. Homeowner assured me the line wouldn't interfere with that corner post hole, I was sceptical so we hand dug that one. 18" down found the line running smack dab through the center of the hole lol.
Dug back either side a couple feet, heated it up a bit, and nicely bent it about 3" just out of the way of the post.
mrcat is offline
Old 08-03-2020, 06:11 PM   #6
Box Builder
Morning Wood's Avatar
Rewards Points: 2
It will bend nicer with one of those heating pads made exactly for that purpose.
Morning Wood is offline
Old 08-03-2020, 09:54 PM   #7
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 17,469
PVC bends at 170 to 220. THHN usually has a limit of 194 (90C). So you need to keep the temps on the lower range so you don't damage the insulation.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 08-09-2020, 06:47 PM   #8
Electronathon88's Avatar
Trade: Electrician
Rewards Points: 6
I'd be too afraid to destroy the conduit. Heating and bending PVC is usually done with a bending spring inside the conduit to prevent it from deforming. Even if you successfully bend without destroying conduit, you might want to meg out the wires before and after to verify you didn't melt the insulation. If you must do it this way, have a hose or bucket of water on hand to cool it down soon as you finish the bend.
Electronathon88 is offline
Old 08-09-2020, 06:56 PM   #9
tjbnwi's Avatar
Rewards Points: 5,978
Pull the wire with a pulling string attached, bend, cool, repull wire...
tjbnwi is online now
