Bulb-Eaters....... - Electrical - Contractor Talk
Bulb-Eaters.......
Old 05-22-2020, 09:42 PM   #1
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,692
Bulb-Eaters.......
I run into these light fixtures all the time, for the past 20 years.
There'll be one, that just eats bulbs.
Incandescent, florescent, whatever.
I put a new ballast into an older fixture in a walk-in closet. Kept eating bulbs.
So I put a new fixture in. It eats bulbs. Changed out the ballast in the new fixture, still eats them.
I've checked voltage, looked for vibration, checked the bulb sockets, all appear to be fine.
The entire house is protected by surge arrestors. Nothing else in the house has any problems, to the best of my knowledge.
Another, new installation in a garage. Florescent. Bulbs die about once a month. New ballasts, all the usual checks.....Nothing.
Been researching this topic for 20 years, and I still haven't figured out why some fixtures or locations just have problems.
Old 05-22-2020, 09:54 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,724
Re: Bulb-Eaters.......
Didja ever check the supply voltage?
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
Old 05-22-2020, 10:14 PM   #3
KAP's Avatar
Trade: Custom
Rewards Points: 40,122
I don't know what the problem is either, but these LED bulbs have turned into the biggest screw you I've seen... they're supposed to last years, and after replacing them all, it feels like I'm replacing them at the same rate as incandescents...
KAP is offline
Old 05-22-2020, 10:18 PM   #4
hdavis's Avatar
Rewards Points: 1,606
Temperature, they're getting hot. LEDs are even more sensitive to it than florescent.
hdavis is online now
Old 05-22-2020, 10:44 PM   #5
KAP's Avatar
Trade: Custom
What do you mean by hot? Ambient or the fixture?
KAP is offline
Old 05-22-2020, 10:50 PM   #6
Trade: Highwayman
Yep.
At the fixture, and at the panel, just for gits and shiggles.
120.8V
Old 05-22-2020, 11:16 PM   #7
hdavis's Avatar
At the bulb or fixture.
A combination of ambient temp and airflow. LED bulbs are just electronics, they don't like heat. Same thing with CFLS, they have electronics in the base
Florescent have electronic ballasts, same thing.
You can have a location that doesn't allow for natural air currents, and the heat can build up. Closed fixtures are obviously worse. Bulb orientation even makes a difference. CFLs and LED replacements for incandescent bulbs do best if the bulb is upright IIRC.
Old 05-22-2020, 11:22 PM   #8
Fire up the BBQ
griz's Avatar
Rewards Points: 2,174
fug it...
go to candles & kerosene lamps...
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
KAP (05-23-2020), Seven-Delta-FortyOne (05-23-2020)
Old 05-22-2020, 11:55 PM   #9
Fire up the BBQ
griz's Avatar
kidding aside...
had this problem several years ago in a school...
architect brought in a really down to earth & VERY cool guy, electrical engineer to evaluate the problem.
all manner of voltage/line tests, recording meters etc...
verdict was vibration, from mechanicals...
some isolation dampers were installed and the problem went away...
EE said vibration could come from a long ways away & cause the problem which could making the diagnosis more complicated...
griz is online now
hdavis (05-23-2020), Seven-Delta-FortyOne (05-23-2020)
Old 05-23-2020, 12:31 AM   #10
Dirtywhiteboy's Avatar
Rewards Points: 4,950
There are entities in there that don't want the light on.
Dirtywhiteboy is offline
Old 05-23-2020, 06:20 AM   #11
KAP's Avatar
Trade: Custom
Originally Posted by griz View Post
kidding aside...
Isolation damper for light bulbs? Tell me more...
Now I have to buy MORE stuff to get the stuff that was supposed to work in the first place to work?
KAP is offline
Old 05-25-2020, 11:04 AM   #12
Talking Head
EthanB's Avatar
Rewards Points: 438
I have a fixture where one of the two bulbs burns out really fast. Can't figure it out for the life of me.
Planer.....
EthanB is offline
Old 05-25-2020, 12:13 PM   #13
hdavis's Avatar
Sometimes you have a socket that doesn't have a good connection, so it runs hot.
Old 05-25-2020, 08:26 PM   #14
Trade: Highwayman
I must say, though....
I haven't yet disconnected any of these fixtures, and Ohm'ed out the circuit from the bulb socket to the power feed.
Although that won't tell me if the bulb-to-socket connection is high resistance.
hdavis (05-25-2020)
Old 05-25-2020, 08:33 PM   #15
hdavis's Avatar
Non contact thermometer or thermal imager.
If I have a problem fixture, I just change fixtures.....
Old 05-25-2020, 08:37 PM   #16
Trade: Highwayman
Did that on one of them.
Kept on burning out florescent bulbs.
Old 05-25-2020, 08:39 PM   #17
480sparky's Avatar
Put a voltage recording meter on that circuit. You may have an intermittent open neutral (either in a MWBC or the entire service) that causes voltage spikes.
The Following 2 Users Say Thank You to 480sparky For This Useful Post:
hdavis (05-25-2020), Seven-Delta-FortyOne (05-25-2020)
Old 05-25-2020, 09:20 PM   #18
hdavis's Avatar
I like this.
I've never seen it because I never looked.
