Black Soot Above Receptacles - Electrical - Contractor Talk
Old 09-07-2015, 06:57 PM   #1
jb4211's Avatar
Rewards Points: 2,306
Does anyone have any thoughts as to the cause?
There are a few receptacles like this: interior, partition walls as well as exterior. New home owner.
Jon
jb4211 is offline
Old 09-07-2015, 07:01 PM   #2
diplomat
Golden view's Avatar
Rewards Points: 1,516
Re: Black Soot Above Receptacles
Dust/dirty air entering at the receptacle. Seal it with foam, a gasket.
Golden view is online now
Old 09-07-2015, 07:09 PM   #3
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 870
I've seen plug in DC transformers do that, not exactly sure why.....guessing the combination of heat and dust attraction? Though I'm sure I'd open them up to check the wiring/receptacle to be sure.
dsconstructs is online now
Old 09-07-2015, 07:11 PM   #4
jb4211's Avatar
I thought about that.
But, if that was the case, wouldn't it be more generally indicated around the entire receptacle as opposed to mainly above?
Jon
jb4211 is offline
Old 09-07-2015, 07:15 PM   #5
jb4211's Avatar
Also, electrical service was upgraded, but the home was built in 1925.
Jon
jb4211 is offline
Old 09-07-2015, 07:32 PM   #6
jb4211's Avatar
Four receptacles in living room. Two out of the four are like this.
The new HO hasn't used them. It's been that way since she purchased the house.
Jon
jb4211 is offline
Old 09-07-2015, 07:44 PM   #7
Rewards Points: 870
I'm still going with my guess
Old 09-07-2015, 07:51 PM   #8
Frank Castle's Avatar
Rewards Points: 602
I've seen this happen behind the nightlights plugged into the outlet.
Adapt, Improvise, Overcome.
Frank Castle is offline
Old 09-07-2015, 07:58 PM   #9
Germantown's Avatar
Trade: Flooring kitchen bath remodeling
Rewards Points: 22
Ive witnessed this in my own house before I Rewired . Mine did the same thing due to the circuit being overloaded . Its a miracle my house did not burn down . A simple check with an infrared temp gun will confirm . My situation was a result of using two space heaters on the same circuit . Whoever wired my home ran most all of the receptacles to one circuit.
Germantown is offline
Old 09-07-2015, 08:23 PM   #10
builditguy's Avatar
Rewards Points: 2,066
Kind of a different thought, but could it be coal dust being sucked out of the walls. I've seen alot of older homes, that had been heated with coal, have a ton of coal dust inside the walls.
Probably off the mark, but who knows.
builditguy is offline
The Following User Says Thank You to builditguy For This Useful Post:
SmallTownGuy (09-07-2015)
Old 09-07-2015, 08:50 PM   #11
jb4211's Avatar
Just more info: the house has gas radiator heat and cold forced air. The ducts were added by the previous owner for the air conditioning.
Jon
jb4211 is offline
Old 09-07-2015, 10:21 PM   #12
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 934
I think the fact that it's on partition walls tends to rule out air leaks. Looks like a heat signature from wall warts or just heavy current draw, where heat creates an updraft and concomitant "contamination" of the wall surface.
If it's cleaned up and/or repainted, and nothing unusual plugged in there, I wouldn't expect it to recur.
Tinstaafl is online now
Old 09-07-2015, 10:37 PM   #13
aptpupil's Avatar
Rewards Points: 1,894
Did you pull the receptacles to check for any obvious wiring issues?
aptpupil is offline
Old 09-07-2015, 10:43 PM   #14
jb4211's Avatar
No.
I was originally there for windows and some water damage...kinda snowballed from there.
My plan is to clean the area and replace the receptacles with new, at which time I'll check in wires for signs of overload.
The back-drafting idea sounds plausible as does the previous owners using plug-in air fresheners.
Jon
jb4211 is offline
Old 09-07-2015, 11:14 PM   #15
hdavis's Avatar
Rewards Points: 1,024
Night light or air freshener. Or, bad outlet.
hdavis is online now
Old 09-08-2015, 07:43 AM   #16
Electrical Contractor
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
This is due to excess heat at the receptacles. You could have a loose connection or it could have been caused by something that was plugged in. I have seen a defective vacuum cleaner do this. Customer was sure it was the receptacle but the vacuum was the culprit because the cord had a loose connection.
Wal wart is a possibility but if this is happening at 3 outlets it makes me think of a loose connection
C'est Moi is offline
Old 09-09-2015, 03:43 PM   #17
mski's Avatar
Trade: home improvements
Rewards Points: 502
I would go with the air freshener. Seen this a few times with the Glade plug-in air fresheners. People plug them and never replace them.
mski is offline
Old 09-09-2015, 04:07 PM   #18
MarkJames's Avatar
Rewards Points: 18,807
I've seen that in all sorts of random receptacles, recently in a kitchen on a couple backsplash outlets. If the backside of the plate is fine, I don't worry, as long it's not actual charring. It usually wipes off easily with windex or a magic eraser.
MarkJames is online now
Old 09-10-2015, 07:01 AM   #19
99cents's Avatar
Trade: Electrician
Rewards Points: 12
Almost guaranteed it's an electrical issue, most likely back stabbed receptacles or a remote chance that it's aluminum wiring. It might just be old receptacles. I have had old receptacles crumble when I remove them.
Combine that with a high current load like a space heater or high amp vacuum and you've got smoke. Like some guys have said, a night light might even cause it.
Changing existing switches and receptacles on a reno job is a nice little upsell. Not only does it give the job a nice, finished look, it takes care of some safety concerns as well.
99cents is offline
The Following User Says Thank You to 99cents For This Useful Post:
hackwire (09-15-2015)
When the thin blue line becomes black killzoneq2 Sandblasting 6 04-24-2013 04:33 PM
Architectural Craftsmen techniques.....Bakery Black Board PrestigeR&D Architecture & Design 0 02-18-2013 08:49 PM
I need a laser mechine to cut black rock ranil General Discussion 3 11-19-2012 09:17 PM
Black soot on ground wire. wedoanything Electrical 26 10-04-2010 11:54 PM
