Bath Fan & Light Dual Switch - Electrical - Contractor Talk
Old 05-25-2017, 09:07 PM   #1
Jay4334's Avatar
Trade: Painting & Wallcovering
Electrical is definitely not my thing, so I could really use some help. In a powder room I had a single switch that controls the light. Old wiring - 1 single 12-2 wire. Not really sure how that works since there isn't a power source in and then wire to the light tied together? at the switch. Anyway so I added a small exhaust fan today while redoing a hall bathroom above. Ran a 14-2 wire from the fan down the wall right to the switch. I didn't want the all or nothing effect so I picked up a double paddle single pole switch. Cannot figure out how to get the power the is used for the light to power the fan? Yes I know it's now lacking a junction box, I picked up new work stuff for the other bathroom and forgot and old work box for this
Bath Fan & Light dual switch-img_20170525_215446704_1495763715715.jpg   Bath Fan & Light dual switch-img_20170525_215743689_1495764429985.jpg
Jay4334 is offline
Old 05-25-2017, 09:22 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,652
Re: Bath Fan & Light Dual Switch
There's really no way we can tell you what to do without knowing far more than what is showing in the photos.
The first thing that scares me (and remember, I'm fearless), is adding 14-ga wire on what could potentially be a 20 amp circuit.
Once I got to that point, I decided your best bet is to call in a pro.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
The Following 2 Users Say Thank You to 480sparky For This Useful Post:
rselectric1 (05-25-2017), TNTRenovate (05-26-2017)
Old 05-25-2017, 09:39 PM   #3
Jay4334's Avatar
I have all my breakers listed on a spreadsheet with each item on them. This line is on a 15amp breaker
Jay4334 is offline
Old 05-25-2017, 09:50 PM   #4
Frank Castle's Avatar
Rewards Points: 610
My guess is the power goes directly to the light with a "switch wire" running down to the switch.
Just my guess.
Adapt, Improvise, Overcome.
Frank Castle is online now
The Following 2 Users Say Thank You to Frank Castle For This Useful Post:
Calidecks (05-26-2017), Inner10 (05-26-2017)
Old 05-25-2017, 10:14 PM   #5
avenge's Avatar
Rewards Points: 298
I think quite possibly you shouldn't be messing with electrical at all.
avenge is offline
The Following User Says Thank You to avenge For This Useful Post:
kirkdc (05-26-2017)
Old 05-25-2017, 10:27 PM   #6
480sparky's Avatar
We have no idea what the existing wire is being used for. Is it power? Is it switched or not? Is it a switch loop? Where does it come from?
Showing us a wire is like us showing you a gallon of paint and asking if it will be enough.
avenge (05-25-2017), TaylorMadeAB (05-26-2017)
Old 05-26-2017, 07:10 AM   #7
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
If there is one wire in the box can't we assume it's a switch loop?
And he ran a new wire into the box hoping to power a fan so can we not assume he's boned and will never get it to work in it's current state?
Inner10 is offline
Old 05-26-2017, 07:34 AM   #8
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,802
Piece of cake. 2 things needed:
1. multi-meter
2. basic concepts of electricity
note: nice hackjob on ripping the switch out of the wall... and no wall box? and why 14-2 wire ? smh.
kirkdc is offline
Old 05-26-2017, 07:45 AM   #9
480sparky's Avatar
Originally Posted by Inner10 View Post
If there is one wire in the box can't we assume it's a switch loop?.........
We can also assume it's a switched neutral.
Old 05-26-2017, 08:27 AM   #10
Inner10's Avatar
Same end result ....he's boned.
Inner10 is offline
Old 06-01-2017, 08:25 AM   #11
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
You are adding another circuit. Can't do that with just switches. I suspect a junction box will need to be added topside and a line run down. Better let a sparky do it, it ain't worth it if things go wrong. What's with the wall damage?
RangoWA is offline
Old 06-01-2017, 09:22 AM   #12
kirkdc's Avatar
I thought black was ground.....snicker.
kirkdc is offline
Light activated exterior lighting wallmaxx Electrical 9 05-10-2013 04:50 PM
Wireless Light Switch or Alternative smokey847 Outdoor Lighting 4 09-20-2011 09:01 PM
Door jamb light switch Jer Electrical 19 08-29-2011 07:48 PM
2 circuits controling a light TNRocks Electrical 4 01-28-2008 09:22 PM
light switch plate blank darren Electrical 12 06-14-2007 07:06 PM
