Basic Electrical Questions - Page 3 - Electrical - Contractor Talk
Old 09-01-2007, 12:47 PM   #41
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Rewards Points: 1,244
Re: Basic Electrical Questions
Originally Posted by mdshunk View Post
You see, that's where I have to part company with your method. I use a similar method, but I use a black Shapie.
Ever use purple? That messes everything up!
Speedy Petey is offline
Old 09-02-2007, 08:26 AM   #42
Baltimore Electrician
JohnJ0906's Avatar
Trade: Electrician
I do the same as Speedy, but I like the variety pack Sharpies.
Different color each month.
John from Baltimore
"One Day at a Time"
All replies based on the 2008 NEC
Originally Posted by celtic
Deny Everything, Admit Nothing, Demand Proof
JohnJ0906 is offline
Old 09-02-2007, 10:03 AM   #43
mdshunk's Avatar
Rewards Points: 2,002
Since we're on the topic of Sharpies, what do you guys use for marking layout lines and such on rough surfaces like concrete floors? You can wear the tip off a Sharpie in short order. I havn't really found anything I like real well for that purpose yet.
mdshunk is offline
Old 09-02-2007, 10:36 AM   #44
mickeyco's Avatar
Trade: Squirrel Handler
Rewards Points: 2,000
I use these things, Sanford Berol China Markers Black 173T, they'll mark on just about anything, great on cement/concrete, thick or thin line. I just looked them up and they are available in a variety of colors to keep you electricians happy. I also have a few of those thin, hard, chalk sticks in the tool box.
12 for $10
http://www.artcity.com/drawing---ill...a-markers.html
here's some on eBay, 48 for $15:
http://cgi.ebay.com/48-SANFORD-BLACK...QQcmdZViewItem
mickeyco is offline
Old 09-02-2007, 11:02 AM   #45
Trade: Electrical
I use both china markers and Sharpies. I like china markers because they will write on anything rough like wood and concrete. They wear out super quick though. I buy both by the box so it really doesn't matter.
I more often use a Sharpie. I keep one dull one on me for rough-in markings and one new one for panel labeling.
John, I saw the variety pack. It scares me.
Old 09-02-2007, 11:21 AM   #46
mdshunk's Avatar
Ahhh.. China markers. I know them as "grease pencils". My butcher uses one to write the price on the white paper he wraps up the meat in. Never gave those a thought. I had a couple lumber crayons once, but they never seemed to make an accurate enough mark to please me, plus they broke all up.
mdshunk is offline
Old 09-02-2007, 02:39 PM   #47
Philadelphia electrician
RobertWilber's Avatar
Trade: Electrical contractor
Rewards Points: 250
That is for "b" phase on 480 volt high cycle capacitor applications ...
RobertWilber is offline
Old 09-03-2007, 03:31 PM   #48
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
We've only worked on these applications once or twice and were forced to use red and blue sharpies.
Sparky Joe is offline
Old 09-04-2007, 03:03 PM   #49
Liquid Force's Avatar
Trade: Electric
Rewards Points: 25
I've used Gonzo Grape Bubblicious bubblegum in a pinch
Liquid Force is offline
Old 09-04-2007, 08:41 PM   #50
Union Electrician
Sparky Joe's Avatar
Old 03-13-2008, 08:50 PM   #51
T R 98's Avatar
Trade: electrician
Probably Late With Ur Answers But I Just Joined. As Far As Kitchen Circuits Anything With A Motor In A Kitchen Requires A Direct 2o Amp Circuit.. For Roughing In Wires They Make A Great Fastener Called Colodo Jims Once U Use Them Its An Easy Decision They R Fast And Look Very Proffesional
T R 98 is offline
Old 03-13-2008, 10:21 PM   #52
220/221's Avatar
Trade: electrician Phoenix AZ
Eh...since you brought it back........
In AZ:
1) Do most of you run a separate circuit for the Refrigerator vs. using the small appliance circuit?
Small appliance circuit
2) Can the Garbage disposal and dishwasher be on the same circuit?
YES. DW and Disp are cord connected to 1/2 switched outlet under the sink
3) How do you handle the 110 wire from the wall to the furnace as far as conduit etc.
We used to pigtail them and plug em in but recently they have asked for hardwire/mc
4) Are two NM cables stapled side by side allowed on the side of a stud as long as they are the required 1 1/4" from the edge?
I put in how ever many will fit but I NEVER bang them tight. I have seen too much staple damage over the years from over zealous installers. I put in enough to tack the wires away from the drywallers.
5) What is your theory when building a switch or receptacle box? Such as do you always bring the load wire in a certain hole and feed wires out another etc.
I bring the lines/loads in close together (left side...I am right handed) and I bring the switch legs in above the appropriate spot relevant to the switch location. This keeps the make up cleaner and helps identify the switch legs in case the original marks get lost.
Just because it's within code doesn't make it safe.
Just because it's against code doesn't make it unsafe.
220/221 is offline
Old 03-14-2008, 08:41 AM   #53
jcalvin's Avatar
Rewards Points: 534
Originally Posted by davidchomes View Post
Hey guys. I have a few basic questions as to how some of you do things. Hopefully someone won't mind answering them.
I like to put them on the small appliance circuit. My reason is that if for some reason the fridge circuit kicks off, you are more likely to notice it if you have more outlets not working. I have never had a problem with circuit tripping in the kitchen by overloading. PS make sure to put the GFCI on the first receptacle AFTER the fridge.
I usually do. I run a circuit to a recepticle behind the dishwasher out of there to a switch box on the wall beside the sink. I buy an extension cord, cut the female end off and hook it in the dishwasher to serve as a user friendly disconnect. I build a switch in the other box on the wall to service the disposal.
I like plastic flex. I can cut it with my knife and I never have a bottle of pipe glue in the truck that isn't already set-up.
On a 2x4 wall? Stud-3.5" wide, 1.25"x2 for code set backs, .5" Viking 100 staple this 3.5-1.25-1.25-.5-.5 = 0..... yes, two wires can fit side by side.
another etc.
Always good to pick a method of where to put what wire. I always put the "hot" wires in the hole closest to the stud and each switch leg goes in the hole closest to where I want to install the switch on the trim out. This makes it easy to troubleshoot if you have any problems and eliminates labeling.
Thanks for any input.
To each his own.
Cal
You hired WHO
jcalvin is offline
Old 03-19-2008, 08:50 PM   #54
chefsparky's Avatar
Trade: eletrcal apprentice
Hi guys,
I have a question. Can anyone tell of a good way to learn to bend conduit? I run pipe all the time at work and just want to get better is there a class or something i can take? Any answers and or help would be most helpful. Thank you.
chefsparky is offline
Old 03-19-2008, 09:36 PM   #55
Timster's Avatar
Trade: General
Rewards Points: 75
Originally Posted by chefsparky View Post
Hi guys,
Buy the Benfield manual and 100 feet of 1/2 inch conduit... And practice, practice, practice.
Benfield manual is here: amazon.com/Benfield-Conduit-Bending-Manual-Jack/dp/0872885100/ref=sr_1_1?ie=UTF8&s=books&qid=1205980372&sr=8-1
Others will agree that this is a great conduit bending manual. Go out in the backyard and make really cool and difficult bends on your own time with some tea or beer. 100 feet of conduit will teach you a lot for starters...
Timster is offline
Old 03-20-2008, 07:41 PM   #56
chefsparky's Avatar
Thank you I will order it on the next payday. Do I need the dvd or workbook or anything else. Now for different question my back to back 90's keep get twisted no matter what i try is it me or the bender?
Old 03-20-2008, 11:28 PM   #57
Union Electrician
Sparky Joe's Avatar
Are you just bending EMT?
Unless the bender's a POS then it's you, but don't feel bad it happens to everyone form time to time. Sometimes the lighting can make something look lined up when it's just a bit off and lighting always sucks on job sites.
But if it's just EMT you just push, pull, yank, slap and twist it into shape by hand until it looks good (note: those are all tricks of the trade that you won't pick up in any book, just years of working with a 'get it done' attitude)
If your using something other than a hand bender you'd use something called a 'no-dog'
Old 03-21-2008, 02:39 PM   #58
Stickman's Avatar
Trade: Tradesman / Electrician
Rewards Points: 75
As far as marking things during the rough, I do that. However once cut in those markings are gone. There for I always bring my feed in and out in closet to the stud, and once my splices are made each feed & switch leg is wrapped by its ground and folded back at it desired location. I also always mark inside the box HR if it is a homerun, helps later when tracing things out. I don't always get the best of helpers so anything to help later is done now!!
Stickman is offline
Old 03-25-2008, 01:17 PM   #59
mdcorreia's Avatar
Trade: Electrician - Self empl.
Rewards Points: 75
So you think it is ok to write all over the sheath with such chemicals? Hello?
mdcorreia is offline
Old 03-25-2008, 02:33 PM   #60
Trade: Electrical
You mean like with a Sharpie marker?
Electrical License in PA ABLE1 Low Voltage 29 10-25-2010 11:20 AM
What the worst electrical safety issue you have seen? SuperiorBuilt Electrical 63 01-02-2010 12:28 AM
Add your questions for a basic knowledge test for new hires! Mike Finley Carpentry 85 03-02-2009 09:04 PM
Couple basic tiling questions fast pasquale Flooring 10 06-26-2007 01:40 AM
Basic Tile Questions vegaskurt Flooring 4 10-19-2004 08:15 PM
