Any Ideas For Fixing The Left Conduit - Page 2 - Electrical - Contractor Talk
Old 06-28-2015, 05:02 PM   #21
GettingBy's Avatar
Rewards Points: 6,486
Re: Any Ideas For Fixing The Left Conduit
Originally Posted by Speedy Petey View Post
Says who???
At least one Cable & Wire Company brochure. If any debate this with you, they are humoring you.
As to fault. . .???. . .it'll take me a day or so to figure out your reasoning and your worldview. Maybe longer.
If water & cable 'don't get along' I guess you could change the water into some other compound or change the cable design or change both.
Seems like a cable design change is the most practical.
Neither the water nor the cable have intentions AFAIK so I guess neither is 'to blame'.
BTW, being 'worried' about capillary action is somewhat like being 'worried' about gravity.
If God designed water I guess you could sue Him or Her or It.
For making something that drowns people.
Or other bad things that happened.
And also capillary action (but the surface tension that allows this can be removed with detergent so if the insulation is impregnated with detergent the problem should be lessened).
You smokin' sumpin? Were you always so sure of yourself? And sell your motorcycle, it's dangerous.
GettingBy is offline
The Following User Says Thank You to GettingBy For This Useful Post:
bartstop (06-30-2015)
Old 06-28-2015, 05:29 PM   #22
trussme's Avatar
Trade: Remodeling Company
Rewards Points: 562
I would sink a 3/8's threaded rod into the slab that was 3'' highier than the receptical. Build a 6" x 6" box with a wood plate on top. Silicone the foot print of the hollow box. Slip the assembly over the whole ball of wax. With the threaded rod poking out the top tighten it down with a nut on the threaded rod. The will compress the silicone making it water tight on the slab. Then fab up a cap for the top or simply buy a 6x6 fence post cap. Install a new receptical cover on the side of the post and Bingo! A nice looking point of power.
trussme is offline
Old 06-28-2015, 06:09 PM   #23
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Rewards Points: 1,244
After reading this post I'll say the same thing.
You smokin' sumpin?
Again, after reading this I'll ask you the same thing.
Speedy Petey is offline
Old 06-28-2015, 06:58 PM   #24
GettingBy's Avatar
Do an online search and evaluate your results using the guidelines in http://www.amazon.com/unSpun-Finding.../dp/1400065666
Need everyones help! Ideas for Drywall Art! PrecisionTaping Drywall 18 02-17-2014 07:27 AM
Some of you should try being left handed DemRem Tiling 41 07-12-2012 08:39 PM
Ideas on for setting cap Captainsls Masonry 15 05-10-2012 09:43 PM
Needing design ideas for period correct 1930's chair/wainscoting FrehouseRemdlin Finish Carpentry 5 08-15-2011 04:23 PM
Need ideas for insulating 2nd story floor wallyofthenorth Insulation 2 08-07-2011 01:01 PM
