Alu Wire - Electrical - Contractor Talk
Alu Wire
Old 03-24-2011, 07:20 PM   #1
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
Alu Wire
I'm getting a home built in '70 and it has alu wire throughout.
What concerns should I have about this? What precautions should I have when adding on with copper?
I imagine that instead of tying in to a circuit with wire nuts, I can use those screw down connectors like I have seen in Europe.
For some history lesson, somone please explain why we were using aluminum instead of copper during that time period. Did it have something to do with the unrest in Chile?
cleveman is offline
Old 03-25-2011, 11:01 AM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Re: Alu Wire
Better check with an electrician about using Chocoblocks, I know you can get AL/CU blocks but I was under the impression that its for AL-AL and CU-CU.
Only other methods I know are Copalum crimps or noalox filled wire nuts.
Inner10 is offline
Old 03-25-2011, 11:15 AM   #3
John Valdes's Avatar
Trade: Electrical
Rewards Points: 146
Re: Alu Wire
These are the best connectors on the market in my opinion.
John Valdes is offline
Old 03-25-2011, 11:22 AM   #4
Inner10's Avatar
Re: Alu Wire
John I've never seen those before, who makes em?
Inner10 is offline
Old 03-25-2011, 11:44 AM   #5
Superior Firepower
skyhook's Avatar
Trade: GC HVAC/R Lic. since 1985
Rewards Points: 3,880
Exclamation
Re: Alu Wire
One big problem was wire strippers nicking the conductor.
The nick creates a weak spot.
Bend it once or twice (stuffing the box) and it will break where it was nicked.
Some guys use the pencil sharpening method. I prefer heat stripping.
skyhook is offline
Old 03-25-2011, 02:06 PM   #6
Carbon Dioxide Producer
DuMass's Avatar
Trade: EC
Re: Alu Wire
I use those AlumiConn connectors as well. IMO, they make a more secure connection and have more possible wire combinations. As long as you use a torque screwdriver with them, they make a UL listed splice. I also have some of the Ideal 30-065 purple wirenuts around here somewhere, but I don’t use them anymore.
Last I heard, the Marrette AL connectors were only CSA listed, so not an option here in the states.
In my area, for what it would cost for the Tyco/Amp Copalum connectors and a Certified installer, if you could even find one, you could probably rewire the house for less, so I don't really consider them an option anymore.
http://www.alcopstore.com/
DuMass is offline
Old 03-25-2011, 09:59 PM   #7
cleveman's Avatar
Re: Alu Wire
Thanks for the replies so far. Those connectors are what I call the "euro" style connectors. Looks like I had better look for some rated for AL-CU. Thanks for the information about nicking the wire. Don't know how much electrical work will have to be done on the house, but thought I should be prepared.
cleveman is offline
The Following User Says Thank You to cleveman For This Useful Post:
skyhook (03-26-2011)
Old 03-25-2011, 11:18 PM   #8
jack of all trades
one man show's Avatar
Trade: general
Rewards Points: 75
Re: Alu Wire
there is absolutely nothing wrong with al wire. the metal expands and contracts more than copper so when replaceing recepticals and switches, use devices listed for AL.
if your panel is rated al./cu. then you can add copper conductors to the panel. of course insulation rating is applicable
one man show is offline
Old 03-26-2011, 12:17 PM   #9
gevensen's Avatar
Trade: JRDM Construction NYC any remodelling/repairs
Rewards Points: 14
Re: Alu Wire
they outlawed it in ny area for fire hazard if i remember correctly
the connectors are a must and it has to be properly done, done properly
its fine but the problem was many were not done properly. I had many a service call in the 80's with AL wire, saw too many burned connections
gevensen is offline
Old 03-26-2011, 05:41 PM   #10
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Rewards Points: 2,002
Re: Alu Wire
There's actually plenty wrong with aluminum branch circuit wiring, that's why you can't buy 10/2 or 12/2 aluminum coils anymore.
The choice is yours, why risk it?
Magnettica is offline
The Following User Says Thank You to Magnettica For This Useful Post:
skyhook (04-12-2011)
Old 04-12-2011, 01:39 PM   #11
Inner10's Avatar
Re: Alu Wire
John great recommendation, just got some alumiconns and they are awesome.
Inner10 is offline
Old 04-12-2011, 01:44 PM   #12
gevensen's Avatar
Rewards Points: 14
Re: Alu Wire
30 years ago when AL wiring was big, ge used to have an oven with what they called a hot wire relay. when that thing went ping pong ping pong we always checked for aluminum wire and in most cases found it, it was weird. saw plenty of burnt junction boxes causing that
gevensen is offline
Old 04-24-2011, 10:18 PM   #13
pat c's Avatar
Trade: ELECTRICAL
Rewards Points: 75
Re: Alu Wire
[quote=cleveman;1160427]
For some history lesson, somone please explain why we were using aluminum instead of copper during that time period[/quote]
In the mid 1960s when the price of copper spiked, aluminium wire was manufactured in sizes small enough to be used in homes. One thing that was known at the time was that aluminium wire requires a larger wire gauge than copper to carry the same current.
pat c is offline
The Following User Says Thank You to pat c For This Useful Post:
thom (04-28-2011)
3-way wiring- ceiling fan with remote for two-wire hookup hevnbnd Electrical 29 08-17-2009 10:28 PM
Can I split thermostat wire??? Jambruins HVAC 5 01-13-2009 06:29 PM
