AFCI & GFCI On Same Outlet? - Page 2 - Electrical - Contractor Talk
Old 02-16-2019, 09:33 AM   #21
tjbnwi's Avatar
Rewards Points: 2,844
Re: AFCI & GFCI On Same Outlet?
Originally Posted by SLSTech View Post
Breakers finally getting better? Why not just use a combo AFCI/GFCI outlet that feeds all the downstream ones per circuit?
The only thing not to forget is to make sure they are Tamper Resistant also...
Have to look again, but I believe the feeders have to be protected in metal up to the first combo device in this case, due to the AFCI requirement.
tjbnwi is online now
Old 02-16-2019, 09:38 AM   #22
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,426
Feeders are not required to be AFCI protected.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
Old 02-16-2019, 12:13 PM   #23
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,240
Originally Posted by ScipioAfricanus View Post
Holy crap!
Now the code is for GFCI & AFCI?!
Is that just California or National?
This marks the first time I have ever been called on such a thing.
Now I have to look at myself as the retarded one.
Andy.
Remember California is one code cycle behind National for the CEC.
The 2016 CEC is based on the 2014 NEC.
Old 02-16-2019, 04:12 PM   #24
Electrical Contractor
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
If you use a combo gfci and afci breaker then the circuit is protected so no conduit or metal cable is necessary. If you use a gfci/afci receptacle at the first outlet then you would need to use mc cable, conduit, etc from the panel to that outlet.
C'est Moi is offline
Old 02-20-2019, 03:00 PM   #25
manchesterspark's Avatar
Trade: Electrical
Believe he is confusing Feeder with Branch Circuit .
manchesterspark is offline
Old 02-22-2019, 08:21 AM   #26
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 682
Look into Leviton panels. Their panels have permanent terminals for ALL the branch circuit wiring that are not on the breakers. The breakers just stab in. You can push in a 'standard' breaker for construction, then swap it out in seconds during trim with a high-$ breaker. No re-wiring needed.
https://www.leviton.com/en/products/...l/load-centers
Went to a Leviton sponsored class last week. I was very impressed with their loadcenters.
In my area distribution will be a huge hurdle for the to cross.
They are coming out with a smart breaker that will allow a wifi connection to their tech to determine if there is an actual fault, or a nucience trip and be able to adjust the electronics remotely. Or so they say.
Sent from my LG-LS993 using Tapatalk
TxElectrician is online now
Old 04-03-2019, 09:50 PM   #27
back doors to hell put in
Irishslave's Avatar
Rewards Points: 1,314
I think it's unnecessary. Over the years I've seen stuff that should have caught fire but never did. How many FP load centers are out there? Some with aluminum branch feeders. Talk about marginal.
Remember when GFCI first came out? How much shoe leather and tire rubber was worn on dog crap service calls? Same with AFCI.
Irishslave is offline
gfci - breaker or outlet? bob_cntrctr Electrical 12 10-06-2009 12:52 PM
Kitchen - use 20A GFCI at start w/ 15A outlets??? tmdelisle Electrical 25 07-28-2009 12:38 AM
AFCI Protection porject in class electrichelper NEC Discussion 2 07-14-2009 06:31 AM
