AFCI & GFCI On Same Outlet? - Electrical - Contractor Talk
Old 02-15-2019, 11:57 AM   #1
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 194
Have any of you electricians ever had to put both AFCI and GFCI protection for the same outlets?
I have this plan checker that seems to want both AFCI and GFCI on the kitchen outlets and the bath outlets. This seems incredible to me.
I get these corrections that show in red an AFCI call-out, written by the plan checker, next to where I show my GFCI call-outs. I am not sure if he wants me to change the GFCI to AFCI or to make the outlets both.
Normally I would call up the plan checker and see if I am somehow misunderstanding what he wants or if he is simply retarded. But I can't in this case as I am not the primary designer on this job.
Andy.
ScipioAfricanus is offline
Old 02-15-2019, 12:01 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,316
Re: AFCI & GFCI On Same Outlet?
Originally Posted by ScipioAfricanus View Post
.......I have this plan checker that seems to want both AFCI and GFCI on the kitchen outlets and the bath outlets. This seems incredible to me..........
It's required now.
210.8(A)(1) and (6), 210.12(A).
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is offline
The Following 4 Users Say Thank You to 480sparky For This Useful Post:
ScipioAfricanus (02-15-2019), Seven-Delta-FortyOne (02-15-2019), Sisyphus (02-16-2019), TxElectrician (02-22-2019)
Old 02-15-2019, 12:09 PM   #3
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,028
Yep. Required.
AFCI breaker, and GFCI outlet feeding downstream receptacles is how I do it.
I think there are some combo breakers. I'll have to try and find them. I'll post if I do.
Old 02-15-2019, 12:11 PM   #4
Trade: Highwayman
Here ya go.
https://www.homedepot.com/p/Siemens-...0DFP/205488018
Old 02-15-2019, 12:12 PM   #5
480sparky's Avatar
Give the NFPA (National Forest Prevention Association) enough time, we'll need GFCI, AFCI, RFCI, WFCI, BFCI, PFCI, QFCI, MFCI, LFCI, VFCI, 4FCI, @FCI and ¢FCI protection everywhere. Even on the doorbell and your TV's remote.
The Following 6 Users Say Thank You to 480sparky For This Useful Post:
cwatbay (02-16-2019), DaVinciRemodel (02-16-2019), greg24k (02-15-2019), griz (02-15-2019), hdavis (02-15-2019), Rio (02-15-2019)
Old 02-15-2019, 12:13 PM   #6
Trade: Highwayman
Here is the one I meant to post.
90% of the panel I work in use BR-style breakers.
https://www.homedepot.com/p/Eaton-BR...20CS/303770425
The Following 2 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
Rio (02-15-2019), ScipioAfricanus (02-15-2019)
Old 02-15-2019, 05:32 PM   #7
Eater of sins.
Rewards Points: 194
Holy crap!
Now the code is for GFCI & AFCI?!
Is that just California or National?
This marks the first time I have ever been called on such a thing.
Now I have to look at myself as the retarded one.
Andy.
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
Old 02-15-2019, 05:42 PM   #8
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 454
It's national, except it's not national where it hasn't been adopted yet.
PA is still on the 2008 code, so you could come here to do your electrical layouts.
Tinstaafl is offline
Old 02-15-2019, 07:00 PM   #9
tjbnwi's Avatar
Rewards Points: 1,834
Holy crap!
Andy.
AFCI and GFCI only in areas that require the GFCI. Most other areas, AFCI only.
tjbnwi is offline
Old 02-15-2019, 07:15 PM   #10
480sparky's Avatar
Holy crap!
Andy.
NFPA. But Commiefornia is a whole other country.
The Following User Says Thank You to 480sparky For This Useful Post:
Old 02-15-2019, 08:27 PM   #11
General Contractor
greg24k's Avatar
Rewards Points: 8,480
Holy crap!
Andy.
It's nuts, every year they come out with more and more s^*t
greg24k is offline
Old 02-15-2019, 08:41 PM   #12
480sparky's Avatar
Originally Posted by greg24k View Post
It's nuts, every year they come out with more and more expensive s^*t the manufacturers end up getting required
Fify.
Philament (02-16-2019)
Old 02-15-2019, 09:58 PM   #13
rselectric1's Avatar
Rewards Points: 872
It would be nice if the manufacturers had all the bugs worked out of these products PRIOR to us being required to use them as well.
On my last 4 additions and one new house (on 2017 NEC) I had to put up signs to use only specified temporary receptacles I had provided for construction tools since the AFCI's trip if you look at them wrong-especially the GF and AF combos. Nobody followed that ever. Calls every day complaining that "my" circuits kept tripping for no reason.
I've now just recently starting loading the panel with standard junk breakers with a big note to the rough inspector that "yes these will be AFCI/GFCI breakers when you do your final". I had to start putting the note for the inspector after the first one failed me on rough since I didn't have AFCI's and GFCI's in the panel yet.
This is not good for legitimate contractors who have to skyrocket their prices like I've had to the late last year.
Next door though the contractors who can't pull permits will continue to use lamp cord for can lights.
rselectric1 is offline
The Following 3 Users Say Thank You to rselectric1 For This Useful Post:
greg24k (02-16-2019), hdavis (02-16-2019), Tinstaafl (02-15-2019)
Old 02-15-2019, 11:54 PM   #14
480sparky's Avatar
Why are you energizing general house circuits during rough?
Old 02-16-2019, 07:46 AM   #15
Rewards Points: 872
Lighting and temporary receptacles only.
Old 02-16-2019, 07:56 AM   #16
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 156
Breakers finally getting better? Why not just use a combo AFCI/GFCI outlet that feeds all the downstream ones per circuit?
The only thing not to forget is to make sure they are Tamper Resistant also...
SLSTech is offline
Old 02-16-2019, 08:26 AM   #17
480sparky's Avatar
So you're temping receptacle and lighting circuits with AFCI breakers?
Old 02-16-2019, 08:28 AM   #18
Rewards Points: 872
I USED to. Not anymore.
Old 02-16-2019, 08:47 AM   #19
General Contractor
greg24k's Avatar
Fify.
Where it came from
greg24k is offline
Old 02-16-2019, 08:53 AM   #20
480sparky's Avatar
Look into Leviton panels. Their panels have permanent terminals for ALL the branch circuit wiring that are not on the breakers. The breakers just stab in. You can push in a 'standard' breaker for construction, then swap it out in seconds during trim with a high-$ breaker. No re-wiring needed.
https://www.leviton.com/en/products/...l/load-centers
The Following 3 Users Say Thank You to 480sparky For This Useful Post:
Dan_Watson (02-16-2019), hdavis (02-16-2019), rselectric1 (02-16-2019)
gfci - breaker or outlet? bob_cntrctr Electrical 12 10-06-2009 12:52 PM
Kitchen - use 20A GFCI at start w/ 15A outlets??? tmdelisle Electrical 25 07-28-2009 12:38 AM
AFCI Protection porject in class electrichelper NEC Discussion 2 07-14-2009 06:31 AM
