240v Amps Measurement - Electrical - Contractor Talk
Old 07-30-2020, 06:10 PM   #1
TommyNet's Avatar
Trade: Home Inspection and Elecrrical
Hi! I’ve seen many guys ask this question on many different forms. The Actual answer they ask never seems to be answered. All of the responses rabbit-hole off in many directions.
THIS IS THE SCENARIO:
A generator is connected to the home properly through rated cabling, interlock, etc.
THIS IS THE QUESTION:
I need to meaure the TOTAL ACTIVE LOAD. (Amps not watts) being drawn from the genset. I need to know how much the A bus and B bus are drawing IN TOTAL (because the A and B bus will be different.
I want to do this with a SINGLE meter which will be permanently installed. Is it possible?
Or must I use 2 meters, 1 per leg?
I fully understand all the electrical principles (except this one, hehehe)
TommyNet is offline
Old 07-30-2020, 06:39 PM   #2
tjbnwi's Avatar
Rewards Points: 5,276
Re: 240v Amps Measurement
You’ll need one pick up per leg. If you want to use just one meter there are 3 phase panel mount amp meters. Use 2 of the pick ups.
tjbnwi is online now
Old 07-30-2020, 06:45 PM   #3
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,978
If you want to get down to brass tacks, use two ammeters... one on each leg.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is offline
Old 07-30-2020, 08:31 PM   #4
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,972
I bought a TED on Inner10's recommendation.
It works perfectly for this situation.
Old 07-30-2020, 10:52 PM   #5
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,877
Install the two induction coils on the service feed wires, wire in series to meter(300-400% of genset Amp output) connection
Fouthgeneration is offline
Old 08-02-2020, 01:56 AM   #6
TommyNet's Avatar
It works perfectly for this situation. <img src="http://img.contractortalk.com/smilies/thumbsup.gif" border="0" alt="" title="Thumbsup" class="inlineimg" />
What is a TED meter?
TommyNet is offline
Old 08-02-2020, 09:10 AM   #7
480sparky's Avatar
https://www.theenergydetective.com/submeter/
Old 08-02-2020, 09:32 PM   #8
Trade: Masonry
If you were the only customer on the the step down transformer, you could meter the High Voltage side of the transformer..... with ONE meter and ONE pickup....
