15 Kw Pool Heater - Electrical - Contractor Talk
15 Kw Pool Heater
Old 06-12-2012, 04:15 PM   #1
pat c's Avatar
Trade: ELECTRICAL
Rewards Points: 75
15 Kw Pool Heater
my customer got a 15 kw pool heater, electrical laws of quebec require a gfci breaker for heater if its less then 10 feet away from the pool. i built a system with a contactor using the power of the pool passing by a 15amp gfci breaker and coming back to feed coil, but when i test to make sure breaker will cut off incase of a leak it doesnt, only cuts off when i touch the coil.. What can i do to protect it.
this is what i did. from L3 of contactor i went to fuse holder(15amp) then i went to a sub 4 circuit panel on the line, i put a 15 amp gfci breaker and from breaker i go to the coil of contactor, i had figured to do it this way using same power to ground fault everything but it doesnt work.
pat c is offline
Old 06-12-2012, 04:44 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 11,736
Re: 15 Kw Pool Heater
The only GFCI protection you have is what's on the 15a GFCI breaker.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is offline
Old 06-12-2012, 05:04 PM   #3
txgencon's Avatar
Rewards Points: 432
Don't know how they let you load breakers in Canada but couldn't you have just used a 60 or 70 amp 240 volt GFCI breaker?
txgencon is offline
Old 06-12-2012, 05:08 PM   #4
pat c's Avatar
Trade: ELECTRICAL
Rewards Points: 75
i need a 70 amp gfci, biggest ive seen is 60...
pat c is offline
Old 06-12-2012, 05:29 PM   #5
txgencon's Avatar
Rewards Points: 432
Yeah, seems like I've run into that before. Pretty sure I've used a 60 amp and didn't get a callback even though the spa spec'd a 70 amp breaker.
You could always go this route:
http://groundfault.com/gfci/?gclid=C...FSrDtgodOxM_Mw
If you needed 70 amp line current protection, you could always feed this device with a 70 amp plug in breaker.
txgencon is offline
Old 06-12-2012, 10:03 PM   #6
Kgmz's Avatar
Leviton 6895 and a relay for up to 80 amps
Kgmz is offline
Old 06-13-2012, 07:38 PM   #7
pat c's Avatar
Trade: ELECTRICAL
Rewards Points: 75
thanks < that model there is discontined the replacement is 8895, i orderd it takes a week delivery, cause its not stock. ill keep you guys posted. thanks alote buddy i realy appreciate it.
pat c is offline
Pool Heater Handy Guy Pool Construction & Enclosures 3 04-11-2012 12:32 PM
Local SEO NickWasHere Marketing & Sales 48 04-01-2010 06:48 AM
Pool Heater? Salty Dog Electrical 11 02-13-2010 07:19 PM
