Who Uses "hot Mud" For Entire Rooms? - Page 2 - Drywall - Contractor Talk
Old 10-02-2006, 11:36 AM   #21
Builder, Remodeler
thill's Avatar
Trade: Builder, Remodeling Contractor
Rewards Points: 25
Re: Who Uses "hot Mud" For Entire Rooms?
I use 90 and 45 for whole houses. (Blue/white bags) But it takes time for the guys to really learn how to use it.
Much lies in how you mix it. Mix thick for filling holes and gaps, medium for taping and blocking at the same time, and thin for skimming.
Once it mostly sets up, run a knife over it to remove any ridges. Once it't dry, it sands like any other mud, when dry, in my opinion. The time you save with it equals $$$ at the end of the job.
Due to time saves, my guys take a room, and do all three coats one after another until they are done that room. Drop a fan, move to the next area. Next day all is dry and ready to sand.
I'll never go back to wet, slow, crumbly, shrinking, cracking, money-sucking ready-mix. Just my opinion, of course.
-TH
thill is offline
Old 10-02-2006, 05:48 PM   #22
Frankawitz's Avatar
Rewards Points: 1,196
I use all Durabond 20,45,90 in the brown bags that easy sand is crap to soft, as for doing whole rooms have been doing them for 21 years . And as for corners your telling me you can't pull both sides one after the other, well you need to practice more I do both sides and I only use a 6" taping knife, Oh I have a couple of those corner trowels for my beginners who can't do corners, but I think I used them one time and then threw them in my tool bag and they have been there ever since. I finish all my ceilings and walls with topping compound it's so much easier to sand, I can use my hand to sand with. I tape and bedcoat then my second coat is with a second batch of 90 then skimcoat with topping compound. let it set up over night and as long as the humidity is below 60% it drys nice and hard. if the humidity is up above 65% we will put a fan in the room to move the air.
Frankawitz is offline
Old 10-03-2006, 08:41 PM   #23
TimNJ's Avatar
Rewards Points: 4,464
Like GregDi, I use it in bathrooms all the time. You have to if you want to make any money on the in and out ones.
TimNJ is offline
Old 10-04-2006, 08:21 PM   #24
mistersmooth's Avatar
Trade: Drywall and Painting
I use brown bag dura-bond for first coat on my corner beads. With corners nailed and dura-bonded they will take a beating. Try peeling ultra-flex off when it is applied with brown bag. Impossible. Easy Sand, it peels right off. To make brown bag sand a little easier, start the batch with 1/3 Easy Sand (light wieght). I alway finish with a creamy bucket of USG green lid.
mistersmooth is offline
Old 10-08-2006, 01:09 PM   #25
ch0mpie's Avatar
Trade: Geotechnical PE
Rewards Points: 250
After reading this tread, I used hotmud for the first time. I used mesh, easysand 90 first two coats, finished with blue lid premixed, then wet sanded it the next day. Very happy with the results thanks guys.
ch0mpie is offline
Old 10-13-2006, 07:51 AM   #26
AtlanticWBConst's Avatar
Rewards Points: 2,000
Originally Posted by troubleseeker View Post
None of the drywall contractors I know of will use hot mud for an entire job. They will bed with it, but always use regular mud on the finish coats. I know from personal experience that although the lightweight hot muds are "sandable" the don't sand anywhere as easily as regular mud, gumming up the sanding pad very quickly. Unless you are good with a mud knife, stay away from the old "Durabond" type mud. This stuff is like trying to sand plaster.
Smooth finish work: We only use it for 1st and second coat. Light weight ready mix for last coat. Comes out better. Easier to sand.
Textured finish: Use all hot mud.
-That's how we do it now, after 21 years of doing drywall.
- Build Well -
AtlanticWBConst is offline
Old 02-20-2007, 07:43 PM   #27
Believer
Dr.Hidegood's Avatar
Trade: Painting, Advanced Faux Finishing & Decorative Painting,Drywall Finishing ,Textures, Paperhanging
I can't begin to tell you how much $$$ hot mud has made me .....I made it myself years ago by adding plaster of paris to ready mix in a pinch when I didn't have any . Adding concrete setting activater will turn ready mix into hot mud also....the more you add the quicker the set. I LOVE HOT MUD.
Dr.Hidegood is offline
Old 02-20-2007, 07:44 PM   #28
Believer
Ditto.
Old 02-20-2007, 09:28 PM   #29
Forry's Avatar
Trade: General Contractor, Remodeler
Rewards Points: 526
Love hotmud... Hot mud for the first two coats... NO SANDING! Just a quick scrape with a knife, and it's ready to top. Then sand and go...
Forry is offline
Old 03-24-2007, 02:43 PM   #30
2qwk4u442's Avatar
Trade: Drywall
Originally Posted by Frankawitz View Post
.............after we prime with block filler then spot out the room with M&H ready patch, then we sand the spackling then prime ........
Hi, Im new here. Frankawitz, where do you buy M&H ready patch!!??
I used this stuff once before and really really liked the results for the job I was doing! Where I bought it previously, no longer carrys it.
In fact, I found this web site by searching the web for this stuff!
HELP! Do you have an old can or something to look at the producer? I cant find anything on the web....manufacturer, etc.
Anybody else see this stuff, or know where to buy it? Black and yellow can with a lid like a paint can. I believe it stated something about being a latex type patching compound.
Thanks! Great site!
Rob
2qwk4u442 is offline
Old 03-24-2007, 09:28 PM   #31
Yet another carpenter
Ted W's Avatar
Trade: Carpenter Woodworker
Rewards Points: 250
Reading this thread I just want to comment, I worked for a company some years ago. When taping one guy was relegated to mixing hotmud while 2 or 3 others were busy applying it. The 'mixer' was set up with a couple of buckets of clean water, a bucket for dumping rinse water and a couple of clean buckets for the compound (20, 45, whatever at the time). We flew through taping like you wouldn't believe. The nice thing is the ones applying the mud wouldn't have to breake stride till lunch time or quitin time.
Also, we sponged it smooth. NO DUST!
Carpentry and Woodworking - Chicago / North Shore - Ted's Carpentry
"I don't know everything but at least I think I do, and that's what really matters."
Ted W is offline
Old 03-25-2007, 06:59 PM   #32
1KingOfDrywall's Avatar
Trade: Drywall, Plaster,Interior Demolitions,Small Repairs
Rewards Points: 150
Traditionally a drywall finisher using machine tools would tape 1 day, bed the second,skim the third and so on.......
With 45 or 90 we always mesh everything than hand feed the mud box and bed the entire job the first day. I let the taper fall behind and tape angles by himself with the taping tube.....so at the end of day 1 we are always finished with the bed coat. When we skim, we use plus 3 and just pull it skin tight and it needs almost no sanding. On jobs where its less than 50 sheets, we just got 1 guy steady mixing 20 minute pan by pan with a mini mixer..............45 and 90 makes me money.......I love those 2 guys.
1KingOfDrywall is offline
Old 03-25-2007, 07:13 PM   #33
NJPainter's Avatar
Trade: Painting-Drywall-Restoration-Pressurewashing-
Rewards Points: 77
Watch out for those cuts. Hot mud will tear up your skin something fierce if you use it on the regular. Still love the stuff- it's a great product.
NJPainter is offline
Old 03-26-2007, 03:22 AM   #34
Frankawitz's Avatar
Rob
You can pick up M&H Reday Patch in the Black and Orange can at most Home Depots and Lowes in the paint dept or check out SW or BM paint stores also carry it.
As for the cuts on your hands the Durabond will dry out your hands because of the Mica in the mix this is what makes it dry out it will remove all moisture from board mud and your skin, I use vasaline on my hands when they get really bad also have started wearing leather gloves or those new machinc type gloves that are nylon keep the hands out of the mud, ends of my fingers don't split, like having a deep paper cut more of a pain in the but. Then it hurts.
Old 03-26-2007, 05:05 PM   #35
Wow...I posted on this thread last October and it's still going....
- Build Well -
Old 09-08-2007, 06:25 PM   #36
hutch04's Avatar
Trade: DRYWALL
Rewards Points: 25
hot mud on first coat of butt joints and corner bead is all needed... then skim wit regular mud then touch up and spray... very easy process
hutch04 is offline
Old 09-09-2007, 08:29 PM   #37
all drywall's Avatar
Trade: Drywall contractor
Lightbulb
Originally Posted by Mike Finley View Post
Steve you can turn 90 minute mud into 45 minute mud by mixing it with warm water. A little tip there.
not only can you use hot water but you can use dirty water to (as far as water you use from your 5 gal.you use from your water sanding bucket ie.wet sponges)in a pinch and not next to water... there you are...
all drywall is offline
Old 10-10-2007, 07:48 PM   #38
MudDobber
MudDobber's Avatar
Trade: Specialty Drywall Contractor
Nothing better than hotmud...If you know how to use it.
We've been using it for years. It does wonders. We even add accelerator which I love because once it sets for a few minutes, with accelerator
(USG Gypson Plaster Accelerator-comes in 1.5 lb container),
it's like play-doh. You can rub out the lap marks and manipulate it.
We use mesh tape on everything except angles. After taping angles hot mud can be used everywhere. We NEVER sand. Never. The stuff is that good. Although experience with it helps. We do whole houses and repairs with it. Love it. Oh, juggling pans is quick.... wash your hands once in a while. And keep the pans and knives clean.
MudDobber is offline
Old 08-16-2012, 01:39 PM   #39
icerock drywall's Avatar
Trade: drywaller
Rewards Points: 930
I use durabond on my tapecoat in small jobs all 3 coats and mix dirty water to make the 90 set to 20 if I want too. Bigger jobs I use 90 on my seams only.
icerock drywall is offline
Old 08-17-2012, 08:52 AM   #40
Profit is not dirty.
AARC Drywall's Avatar
Trade: Residential Drywall and Taping
Rewards Points: 268
We use hot mud, but only synco 90 as it sands way easier....some say they sand easy...but no...found that out the hard way. If we are pushed for time, we will tape normal, fill with hot mud, 10" box, and skim out with 12" box , sand and prime. DONE... I have done whole houses that way, works awesome.
Profit is NOT a dirty word....Cheap is....
AARC Drywall is offline
jiggly rooms............ painterofeveryt Painting & Finish Work 5 01-06-2007 06:13 PM
Looking to build more glass rooms Glasshousebltr Construction 5 04-17-2004 04:26 PM
Somebody sell some Gass Rooms Glasshousebltr Construction 2 03-04-2004 10:46 AM
