What Would Cause This? - Page 3 - Drywall - Contractor Talk
Old 05-03-2014, 06:35 PM   #41
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Re: What Would Cause This?
Originally Posted by BUTCHERMAN
It looks like someone may have pissed off the drywaller. I could be wrong, but I've heard stories that if you put dish soap on a board that paint won't stick to it. Looks to me like someone put dish soap on the board before hanging it. You wouldn't see it till it's painted and the paint peels. It's an old time revenge trick to cause problems after the job is done and everyone is paid. I'm also sure temp changes may have come into play as well. Either way this was deliberate. The patterns are too perfect.
That's not it. First off, I put soap in all of my mud, and not once ever had a problem. Second, I knew the previous owners, and the woman's father built the house for them. He was a builder, but is now retired.
jlsconstruction is offline
Old 05-03-2014, 06:35 PM   #42
stacker of sticks
Rewards Points: 590
And the house was built in 01
Old 05-03-2014, 06:55 PM   #43
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 276
Originally Posted by Sir Mixalot View Post
The finisher used a rag/sponge that had WD40 on it to rag his pointup.
Paul makes a good point. Could have been wet sanded maybe ? With some oily substance in the water .
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
The Following User Says Thank You to blacktop For This Useful Post:
Sir Mixalot (05-04-2014)
Old 05-03-2014, 09:16 PM   #44
icerock drywall's Avatar
Trade: drywaller
Rewards Points: 930
is that from the heated wires ?
dont work hard...work smart
icerock drywall is offline
Old 05-04-2014, 09:28 AM   #45
Ancient Rocker
Ancient Rocker's Avatar
Trade: drywall hanger
Rewards Points: 97
Originally Posted by jlsconstruction View Post
and the house was built in 01
1901?
If you think hiring a professional is expensive, wait until you see what an amateur costs.
Ancient Rocker is offline
Old 05-04-2014, 09:35 AM   #46
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,244
Definitely the edge of the mud joints.
Sand, oil based primer, feather, prime and paint.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 05-04-2014, 09:55 AM   #47
Trade: drywaller
Rewards Points: 930
yes or no
Old 05-04-2014, 09:56 AM   #48
BUTCHERMAN's Avatar
Trade: DRYWALL PROFESSIONAL
Rewards Points: 2,392
There's a difference between mixing in the mud and direct application to the board. I wouldn't do either.
BUTCHERMAN is offline
Old 05-04-2014, 10:02 AM   #49
BUTCHERMAN's Avatar
When did it start to peel? If the house was built 13 years ago and the problem has just recently occurred then it's not construction related unless there a water leak above that's channeling through the seams and butt joints. It just doesn't seem to me to be following a joint pattern.
Old 05-04-2014, 04:21 PM   #50
CarpenterSFO's Avatar
Rewards Points: 2,044
Originally Posted by BUTCHERMAN View Post
... The patterns are too perfect.
It looks that way at first, but if you take a second look, you'll see that the pattern is just the edge of the mud on normally taped and finished drywall.
- Bob
CarpenterSFO is offline
Old 05-04-2014, 06:10 PM   #51
stacker of sticks
Rewards Points: 590
Originally Posted by Ancient Rocker
1901?
2001
Here's some pics if the wall
Old 05-04-2014, 06:21 PM   #52
It was primed poorly or not at all. The mud somehow caused some later condensation and some aspect of the mud made some later condensation or fumes migrate or concentrate at the edges of the mud, and the paint failed. Before I redid just the lines I'd check the field and see if the lines are just a preview of what's going to happen all over.
- Bob
Old 05-04-2014, 06:45 PM   #53
VanGoghFinish's Avatar
Trade: Drywall
Rewards Points: 61
Sorry guys this frozen flats! No of you guys have ever had a spackle freeze in a garage? You can wipe the mud off the wall with your had when it thaws and dries. There is not bond at all when this happens and the paint just creates a shell for a short period of time then begins to flake this this.
VanGoghFinish is offline
Old 05-04-2014, 06:47 PM   #54
Drywall Slave
blacktop's Avatar
Rewards Points: 276
The garage was hung and finished off then sat for many years before paint. The mud turned to chalk . [just a guess]
blacktop is offline
Old 05-04-2014, 06:52 PM   #55
Drywall Slave
blacktop's Avatar
Rewards Points: 276
That would explain all the peaked seams ..yes..but It wouldn't cause the paint to peel like that. I've had many garages freeze and crack but have never seen the paint peel off like that one!
blacktop is offline
Old 05-04-2014, 06:52 PM   #56
Trade: Drywall
Rewards Points: 61
2001
Attachment 111947
Attachment 111948
Look close at the pic and you can see that when it was painted some of the mud lifted at stuck to the roller at the time it was originally painted.
Old 05-04-2014, 06:58 PM   #57
Drywall Slave
blacktop's Avatar
Rewards Points: 276
That would prove my chalk theory true?
blacktop is offline
Old 05-04-2014, 07:09 PM   #58
Trade: Drywall
Rewards Points: 61
In a since yes but not from time. I have repaired countless garages that had never been painted for long periods of time so the home owner could then paint them because builder generally dont. And never have had a problem when paint when on them. Didn't matter how many years old the home was.
Old 05-04-2014, 07:09 PM   #59
During the Cold War the U.S. had various biological warfare programs to bring down the Soviet Union. A number of weaponized organisms, including gypsum worms, were developed to attack Soviet infrastructure and housing. Unfortunately, they didn't do their research, and in the late 70s the Army discovered that Soviet apartment buildings weren't drywalled, but were plastered with portland cement. So the program was abandoned, and the remaining worms were shipped in drums, for safekeeping, to Fort Drum (a little east of Auburn).
Fortunately drywall formulations changed in the 70s, and you only see the damage in very rare situations, where the chemistry is just right (for example along the edge of the mud). You have to be very careful when dealing with it, as the eggs can enter through your ears and cause all sorts of neurological problems. I've only seen it once (I lived in Syracuse when I was younger) and I was very careful not to let any of the eggs get into my ears.
Gypsum worms were developed by the same military research branch that worked on the highway blast deflectors: http://www.contractortalk.com/f22/wh...fences-147179/
- Bob
The Following User Says Thank You to CarpenterSFO For This Useful Post:
TimelessQuality (05-04-2014)
Old 05-04-2014, 07:11 PM   #60
Or maybe the mud froze or something. I sure don't have a clue.
- Bob
jlsconstruction (05-04-2014)
