What Would Cause This? - Page 2 - Drywall - Contractor Talk
Old 04-29-2014, 03:51 AM   #21
Big Shoe's Avatar
Rewards Points: 2,070
Re: What Would Cause This?
Obviously,it's at outer edge of mud bed. Crappy or no primer. Humidity. Equals peeling paint.
Scrape loose paint off. Sponge/wash that area w/bleach water solution. Skim,sand and paint.
Expect the Unexpected
Big Shoe is offline
The Following User Says Thank You to Big Shoe For This Useful Post:
m1911 (05-03-2014)
Old 04-29-2014, 07:07 AM   #22
hdavis's Avatar
Rewards Points: 2,156
One other possibility. If they used setting compound and it dried before it set half decent, you can get almost a chalky effect where the compound was thinnest - right at the edges. The thicker parts dry slower, so they're usually good. Then, if the primer doesn't really penetrate into it, it doesn't have the adhesion it needs.
hdavis is online now
Old 04-29-2014, 07:54 AM   #23
Railman's Avatar
Trade: Railing
Rewards Points: 895
Probably a heated garage with no ceiling insulation, & no attic ventilation. The result would be lots of condensation on the attic/top side of the board. From there, everything expanded/swelled. How else would the board edges squish out the mud/tape at the long board seams? The mud had to be wet! Lots of moisture from somewhere!
As fun as it is, ya can't blame everything on the painter!
Joe
Railman is offline
Old 04-29-2014, 10:09 AM   #24
hdavis's Avatar
I interpreted the joint bump the same way you did - condensation typically happens first at the joint because the drywall is effectively thinner there as long as the boards were tight. Every time I've seen it start to come off from backside moisture, joints go first, and they tent down - the paint stays on until the mud gets pretty soft - either the joint between the boards, or the edge of the tape delaminates first.
I'm not really blaming the painter on this one - not many drywall primers these days actually have good adhesion, and clearly the primer was good enough for the bare board surface, and most of the mud job.
Either way, the more guesses the better on this one
Old 04-29-2014, 03:30 PM   #25
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
[QUOTE=Railman;2006543]How else would the board edges squish out the mud/tape at the long board seams?
But, wouldn't the lines be kinda straight?
Looks like billy-bob was learning to use a rotozip...
jaydee is offline
Old 04-29-2014, 03:39 PM   #26
Home Repairs
D.E.P.S.'s Avatar
Trade: Home Improvement
Rewards Points: 424
Looks like someting was glued to the paint.
D.E.P.S. is offline
Old 04-29-2014, 03:59 PM   #27
ToolNut's Avatar
Trade: Painting & repairs
Rewards Points: 508
When those smart guys answer you let us know. I don't have a clue.
ToolNut is offline
The Following User Says Thank You to ToolNut For This Useful Post:
blacktop (04-29-2014)
Old 04-29-2014, 05:04 PM   #28
Marven's Avatar
Trade: Accountant/Builder
Rewards Points: 165
Not sure what caused it but I had a terrible time with my garage ceiling when the tape started falling off after it was 5 years old. Everytime I fixed it and went to prime it, the edges pealed again. If you fix this and try to paint it as mentioned above, try a small area first. Otherwise do what I did and add another layer of rock.
Marven is offline
Old 04-29-2014, 05:11 PM   #29
hdavis's Avatar
Big Shoe knows how to fix that, so do some do some others.
Big Shoe (04-30-2014)
Old 04-29-2014, 05:29 PM   #30
Stoneyard's Avatar
Trade: Journeyman Carpenter
Rewards Points: 249
They failed to primer it would be my first guess...
Stoneyard is offline
Old 04-29-2014, 05:59 PM   #31
Box Builder
Morning Wood's Avatar
Rewards Points: 10,290
Never seen that before. Weird. I am definitely not one of those smart guys.
Morning Wood is offline
Old 04-29-2014, 06:48 PM   #32
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Originally Posted by blacktop View Post
The rock was hung and finished ..Then many years later It was painted.
They painted over yellow rock. Betcha!!
I believe we have a winner...
JLS, get over there and ask them when it was first painted
-Steve
TimelessQuality is offline
Old 04-29-2014, 09:08 PM   #33
VanGoghFinish's Avatar
Trade: Drywall
Rewards Points: 61
Not so fast! Lol my guess it was taped during cold months with no heat. The edges that are the thinnest froze this cause the compound not to stick to the rock. Hence the peaked flats everywhere!
VanGoghFinish is offline
The Following User Says Thank You to VanGoghFinish For This Useful Post:
TimelessQuality (04-29-2014)
Old 04-29-2014, 09:17 PM   #34
interesting...hmmmm
-Steve
Old 04-29-2014, 09:54 PM   #35
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 8,469
Originally Posted by jlsconstruction View Post
Attachment 111669
Attachment 111670
Attachment 111671
It's the ceiling in an unheated garage.
My thinking was that's where the mud stopped?
The finisher used a rag/sponge that had WD40 on it to rag his pointup.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 70,000 Subscribers and over 11,000,000
My Latest Video: https://youtu.be/E23Y-fw4KCM
YouTube Channel: https://www.youtube.com/paulpeck
Twitter Facebook Instagram YouTube
Sir Mixalot is offline
Old 04-30-2014, 03:53 AM   #36
Big Shoe's Avatar
I peel 100% of tape off. Add screws to tighten board. Wipe down seam w/sponge. Spray with 3M adhesive. Apply 2'' mesh into old tape recess. Fill in with quick set and top with mud then sand and paint.
We guess it has something to do with finisher adding too much water to bazooka mud plus humidity in open garage. As it does not happen inside the air conditioned house.
As far as the OP...........That is the really bizarre. I've seen paint peel before, but not to that extent.
Double up drywall........... Overkill.
Big Shoe is offline
hdavis (04-30-2014)
Old 04-30-2014, 07:20 AM   #37
icerock drywall's Avatar
Trade: drywaller
Rewards Points: 930
I like OSB in the garage ...with fire paint
dont work hard...work smart
icerock drywall is offline
Old 05-02-2014, 09:47 PM   #38
BUTCHERMAN's Avatar
Trade: DRYWALL PROFESSIONAL
Rewards Points: 2,392
It looks like someone may have pissed off the drywaller. I could be wrong, but I've heard stories that if you put dish soap on a board that paint won't stick to it. Looks to me like someone put dish soap on the board before hanging it. You wouldn't see it till it's painted and the paint peels. It's an old time revenge trick to cause problems after the job is done and everyone is paid. I'm also sure temp changes may have come into play as well. Either way this was deliberate. The patterns are too perfect.
BUTCHERMAN is offline
Old 05-02-2014, 09:51 PM   #39
BUTCHERMAN's Avatar
Most of these comments don't jive. The walls look fine. It was only the ceiling. This was done on purpose.
Old 05-02-2014, 11:40 PM   #40
Trade: Drywall
Rewards Points: 61
Are you kidding me? Who in there right mind wood do something like that to there on work and risk ruining there rep?
blacktop (05-03-2014)
