Water Damage Cove Ceiling - Drywall - Contractor Talk
Old 12-01-2009, 08:08 AM   #1
Frankawitz's Avatar
Rewards Points: 1,196
Well I started another water damage Job yesterday, here'ssome pictures
Water Damage Cove Ceiling-19095-mott-001.jpg   Water Damage Cove Ceiling-19095-mott-003.jpg   Water Damage Cove Ceiling-19095-mott-007.jpg
Frankawitz is offline
Old 12-01-2009, 04:39 PM   #2
David
RenovatorLLC's Avatar
Trade: Remodeling/Repairs,Renovation
Rewards Points: 25
Re: Water Damage Cove Ceiling
Background? Besides flat white, ha ha.
RenovatorLLC is offline
Old 12-02-2009, 06:33 AM   #3
Frankawitz's Avatar
Dave WTF? what are you talking about? well here's how the tear out went.
Water Damage Cove Ceiling-19095-mott-008.jpg   Water Damage Cove Ceiling-19095-mott-014.jpg   Water Damage Cove Ceiling-19095-mott-021.jpg
Old 12-02-2009, 06:47 AM   #4
Frankawitz's Avatar
Here are some pictures for you younger guys who are taking on water damage jobs, I have come across repairs done by other guys, well so many think that when you see waterstains well you can just sslap some Killz on it and it's a done deal well here's some pictures to show you what is going on on the back side of the ceiling, When I was starting out the old timers use to tell me kid just scrape and float it! I would ask what about the back of the ceiling and all the water that came in? It will dry out
Well here's what that it will dry out looks like.
Water Damage Cove Ceiling-19095-mott-011.jpg   Water Damage Cove Ceiling-19095-mott-010.jpg   Water Damage Cove Ceiling-19095-mott-015.jpg
Old 12-02-2009, 12:48 PM   #5
Meetre's Avatar
I hate band-aid patches, fix the problem before you cover it up!!
Great job getting the damage out of the way! If only everyone would do this.
Meetre is offline
Old 12-02-2009, 06:51 PM   #6
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
Hey frank another water damage job huh? It looks like a pretty good one compared to your last. Reminds me of a flat roof water damage I did this fall. The "fix" was 1" rigid foam insulation and another layer of drywall. .
Paulie is offline
Old 12-02-2009, 08:37 PM   #7
d's's Avatar
Trade: Drywall
Rewards Points: 75
I'm very curious to see how you progress with the repair. I've just completed a building restoration that included patching plaster walls. I ended up back to bare framing, building up the patches with 2 layers of drywall, confill and mesh, and finishing compound. Worked well enough but I'd love to learn the plaster way - is it better in terms of time&materials?
I've got a question for you which I'll start in another thread re: plaster textures.
Appreciate your posts - it's important for the trade these skills aren't lost!
D'S
d's is offline
Old 12-03-2009, 06:54 AM   #8
Frankawitz's Avatar
here are a couple areas on the walls that started to peel.
Water Damage Cove Ceiling-19095-mott-002.jpg   Water Damage Cove Ceiling-19095-mott-023.jpg   Water Damage Cove Ceiling-19095-mott-026.jpg
Old 12-03-2009, 07:19 AM   #9
Frankawitz's Avatar
Paulie, yeah I had this guy call me back in Sept but I was having a hard time getting a hold of him, But now I have started it, I will go in today and base coat then skim coat. Boy that ceiling looks bad. did you take it all out? Flat roofs suck unless they covered with rubber, there are a few guys in this area that do real good flat roofs, cause a lot of houses have these sunrooms with a flat roof that also is a upper deck. did the home owner fix the roof? kinda of a waste of money if they didn't huh?
Hey I see you have those poles that hold up the plastic how much did those set you back, I checked out getting the Zipwall kit. they wanted $265.00 for some little extension poles with pads I was figuring that they would be around $80.00 or something like that, Unreal what they want. so I put up my own zip wall masking tape and 9'x 12' plastics about $5.00 bucks
Water Damage Cove Ceiling-19095-mott-025.jpg   Water Damage Cove Ceiling-19095-mott-024.jpg   Water Damage Cove Ceiling-19095-mott-027.jpg
Old 12-03-2009, 07:31 AM   #10
Frankawitz's Avatar
D
I see your up north, can you get a hold of Durabond? or are you looking to do stucolite and plaster? The thing with repairs most home owners want the job done quick, I found that when using plaster the jobs can take longer to finish cause of curing of the plaster, with Durabond I know it will set and I can skim then finish the painting up, Today I'll hang the board and then base coat with Durabond 90 then I'll skim coat with topping compound, and I should be able to give it a light sanding tomorrow prime and it will be ready for paint.
Old 12-04-2009, 07:44 AM   #11
Frankawitz's Avatar
I went in and hung the board and base coated I didn't get the skim coat done, I'll do that today should be a short day.
Water Damage Cove Ceiling-19095-mott-034.jpg   Water Damage Cove Ceiling-19095-mott-036.jpg   Water Damage Cove Ceiling-19095-mott-029.jpg
Old 12-05-2009, 07:29 AM   #12
Frankawitz's Avatar
I went in and skim coated the cove and ceiling
Water Damage Cove Ceiling-19095-mott-037.jpg   Water Damage Cove Ceiling-19095-mott-039.jpg   Water Damage Cove Ceiling-19095-mott-043.jpg
Old 12-09-2009, 04:28 AM   #13
Frankawitz's Avatar
Well I finished this ceiling up, customer is going to do finish prep and painting,
Water Damage Cove Ceiling-19095-mott-044.jpg   Water Damage Cove Ceiling-19095-mott-046.jpg   Water Damage Cove Ceiling-19095-mott-047.jpg
Old 06-24-2010, 08:16 AM   #14
sherllin's Avatar
Trade: flood damage
ohh these should be cured ASAP. these could be more dangerous to your property. do consult with expert. this can damage your whole property.
Flood Damage Repair
sherllin is offline
Old 06-24-2010, 04:35 PM   #15
Frankawitz's Avatar
The Following 2 Users Say Thank You to Frankawitz For This Useful Post:
Axecutioner-B (06-24-2010), rogerhattman (06-26-2010)
3-way wiring- ceiling fan with remote for two-wire hookup hevnbnd Electrical 29 08-17-2009 10:28 PM
Ins water damage Msargent Drywall 2 01-03-2009 09:40 AM
help w/ water damage claim lintjosh Plumbing 4 06-30-2008 05:38 PM
help w/ water damage claim lintjosh General Discussion 3 06-25-2008 05:37 AM
Roof warranty and interior water damage Travis Roofing 16 04-20-2008 05:56 PM
