Wall Covering Suggestions For Weight Rm - Drywall - Contractor Talk
Old 12-14-2006, 07:44 AM   #1
housedocs's Avatar
Rewards Points: 250
Hi guys,
Wanna pick some brains here, good friend of mine has just bought his teenage boys a weight bench set-up and they've set it up in an extra bedroom in their new hs. Now he's worried about accidental damage to the drywall from weight bars etc. He asked me about using 1" sheets of styrofoam insulation cut to fi t tightly and just wedged between the floor and ceiling. While this might work I'm thinkin there must be a better idea. Anyone have an idea for this usage?
Thanks
housedocs is offline
Old 12-14-2006, 07:48 AM   #2
Frankawitz's Avatar
Rewards Points: 1,196
Re: Wall Covering Suggestions For Weight Rm
In a weight room you need to have full lenght mirrors on the walls, this way you can watch what muscels your working on plus this way they will be careful not to hit the mirrors with the weights.
Frankawitz is offline
Old 12-14-2006, 08:06 AM   #3
Professional Painter
Richard's Avatar
Trade: Owner/Operator
Frank stole my answer!!!!!!!!!!
I was responsible enough to hold a job at 14 years old, so if they can't avoid hitting the walls as teenagers, um....that's a problem--
Rich
Richard is offline
Old 12-14-2006, 09:48 AM   #4
Dustball's Avatar
Rubber sheeting
Dustball is offline
Old 12-14-2006, 09:27 PM   #5
mdshunk's Avatar
Rewards Points: 2,002
Johnsonite.
mdshunk is offline
Old 12-14-2006, 09:35 PM   #6
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
How about wallpaper with pictures of scantilly clad babes He'll be sure to not destroy the walls then.
It doesn't have to be perfect, it's just a closet!
ron schenker is offline
Old 12-18-2006, 06:16 PM   #7
Bob Kovacs's Avatar
Trade: Consultant
We're doing a new training facility for the NY Jets, and their locker room is going to have diamond plate to around 2' off the floor, with mirrors above. The diamond plate is to protect the walls from the plates that will get leaned against them, and the bars/weights that will inevitably roll into them.
Bob
Bob Kovacs is offline
Old 12-18-2006, 07:13 PM   #8
axnjoe's Avatar
Rewards Points: 75
We just finished a kids footlocker and they had furnished this roll goods which looked exactly like diamond plating but was more like rubber sheeting @1/4 thick. Very cool stuff. It was supplied by corporate and I cant remember who made it.
Good luck.
axnjoe is offline
Old 12-18-2006, 07:46 PM   #9
Teetorbilt's Avatar
Rewards Points: 2,000
Any cheap panelling. This IS temp, right? Maybe luan. Paint or paper over it. Go light on the nails if it's just going to come down in a few years. If you are really worried, jump up to T-1. You can install it reversed too. If they start punching holes in that, they need a lot more supervision.
Albert Einstein
Teetorbilt is offline
Load bearing wall or not??? BMAN Remodeling 26 07-28-2008 06:16 PM
Backyard office, retaining, and privacy wall Team Scream Masonry 8 08-02-2007 10:27 PM
moving centennial wall stacker Masonry 4 10-19-2006 11:12 PM
Low (12" or so) brick garden wall questions bindersbee Masonry 8 04-27-2006 07:31 PM
Wall liner for covering wood paneling? benjmo Wallpaper 1 01-25-2006 11:49 PM
