Wall Covering - Drywall - Contractor Talk
Wall Covering
Old 07-13-2010, 01:10 PM   #1
Griffino's Avatar
Trade: General Contracting
Rewards Points: 25
Wall Covering
I'm finishing out a large garage where machinery will be stored wet, loaded with ice and snow. Snowmachines and track vehicles mostly. This structure will have infloor heat and will melt the snow and ince cause high humidity situation frequently. I'm looking for a substrate to use on the walls and ceiling, like a DensShield just cheaper and smoother. Any ideas??
Griffino is offline
Old 07-13-2010, 08:27 PM   #2
Big Shoe's Avatar
Rewards Points: 2,070
Re: Wall Covering
I'd say regular 5/8'' firecode drywall, good finish job and an excellent primer and paint. If you want to step it up a notch use exterior board. Keep the board off the floor at least 1/2''.
Don't cheap out on the paint.
We don't get much snow here in Florida, just high humidity.
Big Shoe is online now
Old 07-20-2010, 01:14 PM   #3
Griffino's Avatar
Rewards Points: 25
Re: Wall Covering
In a way, it's almost the same thing
I have seen this senario in the past and the vapor will accumulate on walls and every other surface colder then air temperature. The problem in a cold climate is dew point; the vapor differentiation is so great, it accumulates on the vapor retarder and the 10% or vapor that passes through will rot/mold/mildew the structure.
I'm thinking of putting a humidistat and fan in.
Griffino is offline
Old 07-21-2010, 04:38 AM   #4
Big Shoe's Avatar
Re: Wall Covering
Griffino.........Try posting this in General discussion. you may get some more responses from guys from the North country.
Good luck.
Bees in wall ChainsawCharlie Pest Control 7 06-11-2009 01:48 AM
CMU wall repair mcgyverdc Masonry 6 12-04-2008 04:48 PM
removing a retaining wall Cache Excavation & Site Work 30 07-16-2008 04:57 PM
Load Bearing Wall SLAVE DRIVER Construction 7 05-24-2008 08:27 AM
